Mobil One 0 W 30 / synthetic,
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alfon, Jul 30, 2009.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Would Mobil 1 0 W 30 synthetic be a better choice than regular 5w20 oil?
    Walmart has 0w30 in 5 quart jugs for 23.00 or so. They do not have
    0 w 20 weight in 5 .quart jugs.
    Is there that much difference in 0w20 as opposed to 0w30. Seems that 0w30 would be a more prudent choice in hot weather 100 degree and above.
    alfon
  2. toyotechwv
    toyotechwv Toyota Technician
    474
    252
    Princeton, WV
    Toyota recommends 0w20, I would stick with that.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Mobil 1 0W-30 is a good oil. However, it won't meet the xW-20 requirement for the +2010 Prius, so in theory Toyota could deny warranty coverage on that basis
  4. seanu
    seanu New Member
    West Palm Beach Fl
    I bought the 5w 30 in the big jug, i cant imagine it makes a difference, toyota would have to prove it caused the failure. It wont, the ow is the important part for all the start stop, in florida its bloody hot I want the extra protection a 30w provides
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    No, it shouldn't make any difference. You could probably run 0W-40 and it wouldn't make any difference. One summer I ran heavy duty 15W-40, my fuel economy declined around 2 mpg
    I've always believed in matching a viscosity to the ambient climate. In bitter cold temps, especially consistent -30 and colder, you want the thinnest synthetic possible. Eg 0W-20.
    In summer, I don't know of any mass produced vehicles that need an xW-50 oil. Some new supercharged Ford Mustangs come with Mobil 1 15W-50, but I wouldn't consider that to be a "mass production" car. The Dodge Challenger SRT/8, with a 6.1 litre hemi, comes with Mobil 1 0W-40. Again, not a "mass production" car by any stretch
    At first, I ran Mobil 1 0W-30 in my Prius, with very good results. I then gave the 0W-20 a try, and had slightly better used oil analysis results. So I ran the 0W-20 year round, for over 100,000 miles, using at most half a litre of oil over 10,000 km.
    If you run a Prius motor on synthetic from new, you should be safe to use a thinner synthetic. If you wait until the motor has +50,000 miles on it, you may have oil consumption
  6. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Unless I'm mistaken Toyota recommends 0W-20, but there is a blurb about higher weight oil may be more approiate in high temps, heavy use or something similar in the owners manual. Kinda opens the door for 0W-30 to me.
  7. jim256
    jim256 Member
    317
    69
    Eastern NC
    It's not in my manual:
    Recommended viscosity: SAE 0W-20 SAE 0W-20 is the best choice for good fuel economy and good starting in cold weather. If SAE 0W-20 is not available, SAE 5W-20 may be used. However, it must be replaced with SAE 0W-20 at the next oil change.
  8. jestoy7
    jestoy7 New Member
    238
    25
    Jacksonville, FL
    I just bought Toyota 0W-20 and an oil filter. Each quart was $7.79 which is costly compared to the jug of Mobil 1.
    I'll probably continue forking it out while it is under warranty and then make the switch to Mobil 1 oil with Toyota oil filters for the rest of the car's life.
  9. emnesto
    emnesto New Member
    Arkansas
    I talked to Customer Service at Mobile Oil. They don't even package 0W20 in 5 quart containers, but they will as soon as retailers like Wal-Mart and Autozone request it. Right now demand for 0W20 is not there. Maybe as the 2010's 5K maintenance schedule gets going, the demand will increase and we'll see those 5qy jugs. Right now you can still get Mobile 1 0W20 in quarts.
  10. TKY
    TKY Member
    232
    25
    Colorado
    Emnesto, Great point. If we buy oil at Wal-Mart, we should take the time to find the Auto Dept. manager and ask him/her for 0W20 in the 5 quart jugs. With enough requests, they will ask Mobil, or any supplier, for the product customers are asking to buy. --TK
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    I would like to see a virgin oil sample of Toyota 0W-20. Virgin oil samples of Mobil 1 0W-20 have already been done, it would be nice to see a comparison
  12. a64pilot
    771
    62
    Albany Ga.
    Page 552 last sentence on the page.
    "An oil with a higher viscosity may be better suited if the vehicle is operated at high speeds, or under extreme load conditions"
    As I said, kinda opens the door for a higher viscosity oil to me, especially say like Fl. where cold is 50 deg F.
  13. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    I don't know that high ambient temps have much of anything to do with "high speeds" or "extreme load conditions."
    I'd hate to present the argument justifying 5 W 30 (or so) by saying "I speed, all the time; usually at least 20mph above the speed limit" or "I usually have five overweight adults in the car" or "I have a Class 3 hitch and pull my bass boat at least two or three times a week."
  14. a64pilot
    771
    62
    Albany Ga.
    It's 0W-30 was the question, which actually has the same properties when cold as 0W-20. "high speeds" how fast is high? If your that worried about using 0W-30, then don't. But don't act as though Toyota won't allow anything but 0W-20 in the car, because they will allow other oil viscosities, and I saw nothing about boat pulling being required.
    SInce they apparently left it up to opinion, my opinion 70 mph highway speeds are "high speeds" and high ambient temps are "extreme load conditions". who is to say I'm wrong? You?
    Your opinion carries no more weight than mine, I'll bet, possibly less depending on your qualifications of course.
    Opinions are like Belly buttons right? everybody has one.;)
    I guess the REAL answer will only come if one of the Guy's that apparently represent Toyota chimes in.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    For the North American market, Toyota will claim to use whatever oil is listed in the owner manual. That means for 2004-2009, a 5W-30. 2010, a 0W-20.
    What we need is for a 2010 Prius owner in the EU to scan his owner manual section on oil recommendations. They probably allow 20W-50, if the temps are high enough
