just drained my CVT.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by boppo, Jul 29, 2009.
  1. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I bought a used 2006 3/13/09 with 43,050 miles on it and I didn't know if the CVT has been changed. I now have 46,559 so I thought it would be a good thing if I changed it. Thanks to the info on this site it was a cake walk to drain it. I bought a long noise funnel and a 3 foot pc of clear tube with a OD of .50 inchesto refill it. Now that the ATF is dripping out I will go to the toyota dealer in the morning and get 4 quarts of ATF type WS.
    Thanks,
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I think it was Jayman who suggested loosening up the fill plug before draining the fluid.
  3. boppo
    boppo Active Member
    799
    139
    Owego, NY
    SageBrush,
    I did loosen the filler plug but the next time I will take it off first so the fluid will run out better.
    Thanks,
  4. Patrick Wong
    18,214
    6,531
    Nice work. For those who depend upon their Prius for daily transportation, I recommend you buy all needed supplies before draining the old fluid...
  5. SageBrush
    11,627
    2,533
    Southwest Colorado
    That's what I say to myself, too. But enough time passes between these maintenance items that I forget the lessons I learned :rolleyes:
  6. qbee42
    3,082
    Kind of reminds me of changing spark plugs by first pulling all of the wires, and later wondering where they go.
  7. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Hi Guys,
    In my defence, I wanted the CVT to drain for a day or so and my dealer is 12 miles away and we had to go that way today so that's how that worked out.
    This is where I put my funnel and plastic tube to fill the CVT, I tie wrapped it to the hood and it worked great.
    Thanks for all the help,
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    You know you have the wires back on the cap in correct order, when it stops misfiring/backfiring
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    How does the 1/2 inch OD tubing fit in the fill hole? I have some tubing that's 5/8 OD and wonder if it would fit. Thanks! :)
  10. Patrick Wong
    18,214
    6,531
    No defense is needed. I understand the process that you intended to follow. The only issue would be if your local dealer, for some reason, didn't have ATF WS in stock.
  11. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Good question! I have a shed full of rubber hoses. But most funnels have a large opening.
  12. ETP
    2,806
    1,170
    Auburdale FL
    yep, bought my fluid first and waiting for 7K!
  13. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i should STILL do this... i'm on original fluid.. tsk tsk on me.
    it's funny seeing you guys comment about spark plugs and wires. this car won't run with an unplugged or misplugged spark plugs.. not to mention the wires are all pre ran.. so it's almost impossible to mix up or else they won't all connect. shrug. but yeah.. wrong order and such.. it won't even fire. it just throws red triangles.
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    You're probably too young to remember distributor caps and separate ignition wires. I once made the mistake of whipping the plug wires off a 289 motor, replacing the plugs, cap/rotor, points, etc, then when everything was buttoned up, it barely started and misfired/backfired
    I made a boo-b00 and used the firing order for a 351 motor.
  15. V8Cobrakid
    3,790
    152
    too young?... i've own a 302 too... i learned just about everything on that small block.
    point being... it doesn't apply to a prius... shrug.
    i've had the entire firing order wrong.. then i had 1 and 4 mixed... it's fun times.
    i have ran my prius without plug 2 fireing.. it's really odd.. knocks like crazy.. yet still works... kinda...
  16. boppo
    boppo Active Member
    799
    139
    Owego, NY
    1/2 od has some room so 5/8 od might work for you.
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    I bought tubing with a diameter slightly smaller than the funnel. Not on purpose, of course. To gain a nice fit, I slipped a couple of rubber rings on the hose left over from plumbing adventures. Worked nicely.
    Sorry for the lousy sytax above. Almost sounds hai-kuish.
  18. ambrothe
    ambrothe Junior Member
    99
    Columbus, OH
    5/8 OD tubing fits like it was made for the job.
  19. qbee42
    3,082
    I'm still trying to figure out the firing order for our single cylinder marine diesel engine. :rolleyes:
  20. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    Yo Tom,
    1st of all if it is single, then there is only one, because it's diesel you have none spark plug wire so there is no wrong order...applies!!
