What every newb should know
Discussion in 'Newbie Forum' started by richard schumacher, Jun 8, 2008.
  1. tomr2210
    tomr2210 New Member
    Arizona
    2001 Prius
    Thanks, here in Az heat, I'm told that most batteries only last 2 yrs on average. So good to know. It is easy to mistakely leave the accessories on. I am guessing, that is when using a smart key. Hard to believe that Toy would not put in some safety trigger to shut things off, if the veh is not in use after a certain time frame. TOM
  2. zonie911
    zonie911 Member
    585
    Nashville, Tennessee
    Hello, Alex......
    :yo:
  3. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Yep. :)
    As long as you turn the car OFF before opening any of the doors! ;)
    (If you for some reason decide to open your door before turning the car off, then the headlights will not automatically be turned off. For the Gen 2, anyway. I think they changed this for the Gen 3, so in your case it may not even matter.)
  4. John-W
    John-W New Member
    Thanks for all the info here. It took me all morning to read through it. I just picked up my Prius yesterday so spending half a day on the Internet seems like a waste of time but I'm glad I read some of the important points here. The only thing I can add is every owner or potential owner should watch the Toyota videos on YouTube (they are easier to find on iTunes if you search Toyota Prius and look in the podcast results). Scroll down a bit to find the Prius related videos.
    www .youtube. com/view_play_list?p=216B6614C99927A4
    (sorry I can't post links yet)
    After watching those I knew more than my salesman about the car.
  5. beauimoto
    beauimoto New Member
    Vancouver
    Why always lock the door? I leave mine open at night in case some one wants to break in at least they won't break the glass
  6. dogfriend
    7,512
    1,190
    Carmichael, CA
    If you accidentally leave a door open so that the dome light is on, when you try to lock the car, it will warn you with one long beep instead of the normal short beep. This could prevent you from running down the battery.
    Same thing if you accidentally leave the car in "Ready" or any other mode besides "Off".
  7. abibby3rd
    abibby3rd New Gen III Prius Owner
    Kissimmee, FL
    Thank you so much for this post!
    Yesterday I tried "pushing" my G3 Prius to the limits. My "guess" gauge was down to 10 miles and I thought I could make it home (approx 2 miles).
    No sooner did I get to the next intersection than the guage said 0! :eek:
    I quickly turned and headed to the nearest gas station. I made it and learned my lesson. :p
    I also have a habit of topping off, so I will stop that as well. I really am enjoying my new Prius and would not want to do anything to damage it.
    Thank you again,
    Alex
  8. rmjp
    rmjp New Member
    Detroit
    Thank you for the counsel Richard. I just got my 2010 Prius II a week ago, and after searching the forum, I'm writing to you because this seems like another simple issue that all Prius owners should understand.
    I bought the car a week ago, went on a long trip at highway speeds, and now my car won't function solely in electric for more than 10 seconds when sI start up before the engine kicks on. Th eengine used to kick on about after a minute or so. If it's because I'm low on battery (although that doesn't seem to be the case) is there a way to "help it" recharge other than by feathering the throttle, etc?
  9. Krautnribs
    Krautnribs Junior Member
    North Carolina
    I just bought a new to me 2004 prius, thanks for the advice. I let it get down to the blink and drove 17 miles to the next gas station. I'll not try that trick again, the next time the gas station may be out of range.
  10. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The 2010 does not have a bladder in the gas tank so topping off is not a major problem.:)
  11. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Or leave a fob in the car.
    Richard's advice is insurance against doing something stupid. Needless to say, my Prius has beeped at me quite a few times.
  12. angelrob
    angelrob New Member
    94
    Rochester, NY
    LOL! After reading 27 pages of posts, and getting all worried about the bladder, I now find that my soon-to-be new Prius doesn't have one :rolleyes:
    susiemw likes this.
  13. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    No bladder solves the problems the GEN II had with filling, but topping off still isn't a good idea. It's still a closed system, and topping off could saturate the charcoal canister and screw up the emission control system, I believe. And you run the risk of splashing gas down the side of the vehicle, which is never good for the paint.
  14. angelrob
    angelrob New Member
    94
    Rochester, NY
    Thanks, Jay. I have never been a fan of that practice for any vehicle. I hope to take delivery early next week depending on a note from Uncle Sam :) I do hope that the no bladder makes it a bit easier to manually calculate mileage. My Jeep has a mileage calculator but it is always overestimating.
    Robbin
  15. outdoorswoman
    outdoorswoman New Member
    Oneonta
    I'm a newb and glad I found this chat site. I will never let the pip flash again. and jumping the engine? I'll have to research it. I was just looking for a way to put some bike racks on the top of my pruis. Is there any special equipment I need? Is there any special products I should look for? Is this the wrong place to post this? I am also a newb on chats, so sorry if I do not follow the flow
  16. devante
    devante New Member
    Ny
    Great info..
    Thanks for sharing.
  17. Kesch
    Kesch Junior Member
    Albuquerque, NM
    I got my first Prius a few weeks ago. 2005 Tideland Pearl (it took a while to figure out what color it was; the dealer had it listed as either green or grey), AM package. I'm enjoying it immensely, and while having all this information available is great, it's a huge drain on my time!
    In the first week I had to jump-start a friend's car. At the time I didn't even know the battery was in the rear, and I just used the terminals in the fuse box under the hood. It worked with no ill affects, but after reading a better description of the system here, I'll know better next time.
    My mom is afraid to drive it. She loves the hatchback, but is somewhat technophobic.
    Now if they would just stop stalling and bring out a Sienna hybrid...
  18. richard schumacher
    7,676
    1,058
    United States
    That would be a nice feature. Toyota must have decided that it wasn't worth burdening every car with the extra cost.
  19. richard schumacher
    7,676
    1,058
    United States
    Try searching or asking in the "Modifications" area. Several people have added racks and will be happy to help. It does reduce MPGs, but oh well...
  20. 60MPG
    60MPG Junior Member
    24
    38° 53′ 42.4″ N, 77° 2′ 12″ W
    Mmmmmm, a Sienna hybrid ... tasty!!! :hungry:
