prius w/small trailer and moped
Discussion in 'Gen 2 Prius Main Forum' started by debos, Jul 30, 2009.
  1. debos
    debos New Member
    45
    Southern California
    ive seen some discussions on here about pulling trailers with prius's, which i know your not supossed to, but anyone have thoughts on me attach a small utility trailer with my moped on it? (probably about 100 pound in total weight) any input would be appreciated...
  2. smartalec89
    smartalec89 The Official Alaskan
    133
    anchorage, alaska
    You should be able to tow atleast 500 if not more. I have seen a couple here in AK pulling 4wheelers and snowmachines. If your looking for a hitch I suggest Costaltech.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    You sure about your estimate? What model of trailer and moped is it?
    Without looking it up, how much do you think your Prius weighs?
  4. debos
    debos New Member
    45
    Southern California
    i get the first part of your question. its a rolling frame without and engine so probably about 50 pounds. the trailers a small utility one that probably comes in about 50-75. about 100 pounds give or take.
    the second part is just insulting. im tired of asking reasonable questions on here and getting a lot of push back. answer the question or dont chime your 2 cents in.
  5. ChrisViking
    ChrisViking New Member
    Virginia
    I doubt you'll have any trouble at all, with a trailer that light. I just put a hitch and wiring on my 2007 Prius today and look forward to trying it out.
    My current utilty trailer is the 'standard' steel mesh 4 ft. x 8 ft., 300 lb. My next trailer will be a modified aluminum boat trailer, with some sort of waterproof enclosed body (like a roof-mounted enclosure off an RV or SUV).
    Be sure to use powered trailer wiring, where the trailer lights are powered by the car's battery, and the car wiring merely signals what trailer light should be on, rather than powering the trailer light directly with the car wiring.
    best,
    Chris
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    Chris.. your trailer sounds like mine. steel mesh. very heavy.
    OP.. you shouldn't have any problems.. except for reduced mpg while towing.
  7. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    No, from your initial post, I felt your estimates were too low.
    Long ago, I had a conversation w/a friend of mine about car weights and when I gave her some example curb weights, she was surprised. She thought cars were only ~1000 lbs. She was an engineering major at MIT and used to do OS kernel programming, so she's no dummy, just not a car enthusiast.
    I know nothing about moped but from quick searches, I've seen weights range from 75 lbs. to 500. People will be able to better answer your question once you have actual figures instead of guesses.
  8. patsparks
    10,664
    567
    Adelaide South Australia
    Chris,
    be careful with one of these plastic boxes on a trailer. I made a trailer to tow behind my motorbike using a car top box and due to the harsher ride on a trailer compared to the roof of a car or SUV the box cracked and some of my stuff was lost. Thule, the maker of the box refused warranty because I didn't mount it on a car.[​IMG]
    By patsparks at 2007-04-04
  9. Froley1
    Froley1 New Member
    167
    Roswell, New Mexico
    This is a very cool hack--no matter the result.
    Froley
