Does the Prius V have better handling?
Discussion in 'Gen 3 Prius Main Forum' started by Dewnay, Aug 2, 2009.
  1. Dewnay
    Dewnay New Member
    From an article by Wes Siler on Jalopnik.com:
    "When I reviewed the 2010 Prius I found the standard, 15" wheel model had a much improved driving experience, on par with the 2010 Honda Insight, but it's really the 17" wheel Prius V, with its revised steering ratio and firmed up dampers that questions the traditional poor-driving hybrid stereotype. It's actually fun to drive and will set you back $27,270."
    "If we were to spec a Prius, it'd be the 17" wheel Prius V with nothing but the Navigation Package. That includes all the bells and whistles we'd want - leather, LED lights, fog lamps, nice stereo - but most importantly, it drives like a European hatchback while returning far greater fuel mileage."
    Is the statement about the revised steering ratio and firmed up dampers true?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Yes, it does have a tighter steering ratio. Not sure about the firmed up dampers, but many here can attest to the superior handling of the 17" wheel Prius.
  3. Tideland Prius
    16,597
    I don't think the suspension is any different (all models get the "euro" tuned suspension) but the steering ratio is quicker for sure on the 17" model. I think part of the better handling is due to the tyres. Lower profile tyres will have less flex when cornering.
  4. indianagreg
    indianagreg Member
    122
    33
    NE Indiana
    This must be the V w/o ATP... does anyone actually own one? Maybe they'd buy if for the lights and wheels.
  5. Mitchellsprius
    Mitchellsprius New Member
    91
    monterey
    I test drove the V with 17" wheels really liked it. I bought the III with 15" wheels. On my drive to get good MPG on the V I got 57.5 MPG. On the III drive, the first drive on the way home I got 60.4 MPG mostly highway a little mixed. I like the fact that replacing the III tires are 80.00 thats great. The V tires cost can be 225.00 that hurts. I did notice on the highway the 15" ride was slightly less grip and firmness to the ride. But to go for the V it look like 30,000.00, I paid 23,000.00 for the III discounted. I hope to replace the tires when the time comes with an upgraded 15". But I must say I'm not sure why Toyota went with the hub caps and 15" wheels even though in the pearl white with it doesn't look bad. But the whole car has such nice tounches why go with the hub caps. Maybe their is a good reason anyone know. I really got tired of all the options and marketing tactics involved in pricing.
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Agreed.
    As I indicated in a previous post, according to Prius Team, the pre-release cars had the "euro" shock absorbers on the V only, but all US production cars will have them--see Doug Coleman's post here:
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/60065-wheels-steering-shocks-oh-my.html
    To the OP--search is your friend--this has been discussed a lot! ;) Click here: search is your friend :D
  7. ManualOnly
    ManualOnly New Member
    193
    28
    Throw in a strut bar, your 17" 2010 can eat corners for lunch ( & dinner).
  8. montesalpha
    montesalpha New Member
    30
    San Francisco
    I have a IV and I would like to improve cornering. Is it possible to replace my 15" wheels with 17" wheels? Do you know how much that might cost?
    Also how much would it cost to put in a strut as you suggest?
  9. accordingly
    accordingly Member
    268
    63
    Madison, WI
    Pretty easy to replace the wheels. Cost will vary depending on what you buy as there are hundreds of wheels and tires out there to choose from. On the lower end will be about $1000 for new wheels and tires installed. You can get used on eBay for less, OEM Scion Tc wheels and tire sets go for under $500, though I would look locally as well because shipping is expensive. Check local tire shops. You can use the same tire pressure monitor system.
  10. Jon S
    Jon S Member
    185
    84
    The Aloha State
    to me... the steering ratio is just as important if not more. the steering ratio on the 2010 II-IV models takes too long to turn the wheels. I do not know of any other car that takes as many turns as the Prius does. The Prius V feel more normal.... I wonder if that could be retrofitted?
