2008 Prius just reached 30K - Mainentance?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Compdunz, Aug 3, 2009.
  1. Compdunz
    Compdunz Junior Member
    40
    Southwest MI
    I just gave my Prius it's fifth oil change and was thinking about taking it in to the dealership for its final oil change before it's warranty runs out. Is there anything I should ask them to look at or do? Just want a little advice from those who have more experience. Thanks in advance.
  2. icarus
    icarus Senior Member
    4,884
    976
    earth
    I wouldn't pay one cent for dealer 30 k service package. It is almost exclusively BS. They go me almost $300 for a basic oil change and "inspection" Included engine air filter but no cabin air filter.
    Icarus
  3. richard schumacher
    7,666
    1,047
    United States
    Open the Scheduled Maintenance Guide to the correct miles/months page, show that to the service writer and say, "do this and nothing else". It should cost less than $100. Don't ever say, "gimme yer X miles service", 'because you'll get serviced all right. And that's really about it. One exception: based on used oil analysis some owners change the transmission fluid in the range of 30k to 60k miles, and not the 100k shown in the Scheduled Maintenance Guide.
    Consider changing the engine and cabin air filters yourself. They're really easy (just be sure to put the new ones in the same orientation as the old ones). The parts department will be happy to sell them to you.
  4. Patrick Wong
    18,210
    6,513
    When inspecting the 2G engine air filter, please note that the dirty side of the engine air filter is on the bottom. Some owners remove the air filter housing cover, see the clean side of the air filter which is exposed, and erroneously assume that all is well.
    Lift up the engine air filter and hold up to sunlight. If you can see light coming through the filter, then it is OK to use (compare to a new filter if necessary.) If you can't see light passing through, then replace the filter.
    If you decide to change the engine air filter, note the tab on the rubber gasket which points towards the rear of the car. Make sure that tab fits into the indentation in the air filter housing and that the rubber gasket fits securely into the air filter housing.
  5. Compdunz
    40
    Southwest MI
    Thanks for all of the input.
  6. michaelrider5
    michaelrider5 New Member
    Atascadero CA
    I concur with Richard Re: Transmission fluid changes. The CV trans is still relatively new technology, best to err on the safe side, especially with a replacement trans $4000 from the dealer! That said they have a reputatoin for durability. I change mine every 30,000.
  7. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    From lab testing 30k is a bit over the top. I would suggest the first refresh of Type WS ATF at 30k miles and then every 60k miles thereafter. My first exchange of ATF at 61k miles on my 2004 Prius showed a lot of metallic load (AL and FE), but at 120k miles the report was much better as the gears had "lapped" in and less metal was lost. I will be doing my third exchange at 180k miles at the end of this summer. Report to follow.
    JeffD
