Protect or not your plastic interior?
Discussion in 'Gen 3 Prius Main Forum' started by shaunj, Aug 7, 2009.
  1. shaunj
    shaunj New Member
    22
    Maryland
    Do the Prius 2010 windows effectively minimize UV radiation damage of the dash and interior plastic. This seems to be the case for my 2004 Sienna dash plastic (different texture to that in my 2010 Prius), which still looks new, despite not being treated with Armor All or any other UV protectant solutions for the last 5 years. Treat or no treatment?
  2. seanu
    seanu New Member
    West Palm Beach Fl
    I soaked mine with 303 the day it got home, cheap insurance in my mind. I think most will tell you to stay away from armor all, does more harm then good.
  3. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    Also if you've got the Blu Logic bluetooth system, their FAQ warns you against using anything that might weaken the glue that holds the microphone on to the dash.
  4. DrJon
    DrJon New Member
    140
    Pinetop, AZ
    I think all the OEM windows these days have built in UV protection. I believe part of the reason that dash/ plastic/leaather looks bad after after years is due to interior high heat and low cold fluctuations over the years.
    That is one reason I got the IV w/ solar. It will help to keep the interior cooler in the summer heat. Use a sun shade (got mine online from the Prius Chat store) on the front and tint the windows to your liking.
    Hopefully, I'll keep my Prius as long as I kept my "clunker for" - 17 years!!:D
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Another myth to bust. Glass doesn't pass UV except the very long wave type, which is pretty much harmless. It's the heat cycling that damages the plastic. The volatiles boil off, and the plastic becomes brittle and falls apart. UV damage usually shows up as fine cracks in the plastic (all over, not just one or two), something you don't see in a car. Instead you see the plastic dull and large cracks eventually appear.
    "UV coatings" on glass and plastic lenses is just another way to extract money from customers. e.g. - we want to measure UV. Guess what, we have to use a quartz window to pass it to the sensor.
  6. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    I have a nice dash mat that I like, but what's 303? Just curious...
  7. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
    303 Aerospace protectant.
  8. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Great stuff--I've been using it for many years--it's great as a tire dressing as well:
    303 Products, Inc.: 303 Aerospace Protectant
