Need help getting better MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by untitledblue, Aug 8, 2009.
  1. untitledblue
    untitledblue New Member
    17
    Houston
    I'm slightly frustrated since I do not know what I am doing 'wrong' in regards to MPG. A little background info...
    I've had my car since March '09. A typical travel to work is 15 miles (there and back home)-that's 5x a week on the highway doing mainly 60-65mph. Weekday I normally stay local or don't drive, but when I do it's normally on the city streets from 20-35mph.
    I am currently averaging 36.3mpg. When I try to get better mpg there's always a car up my tail so it's hard to practice (I live in Houston where there's a decent amount of congestion). I've tried to read articles online but it seems too confusing to me. Can someone explain in layman's terms how I can get better mpg? I am about to fill up on gas and start from scratch.
    I also kinda got pissed off when I saw this guy:
    Pulse and Glide plus Warp Stealth in the Prius II for maximum FE … - CleanMPG Forums
    Any tips are much appreciated!
  2. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    What tire pressures are you running?
    The Prius, IIRC, has a suggested pressure of 35 psi front and 33 psi rear. Many Pris drivers increase that, sometimes quite a bit. I run 40 front/38 rear.
    When I added more air, I noticed two immediate effects: An increase in gas milage and an improvement in handling. The car now wallows less and handles more crisply.
    I also notice that the traction control system activates more easily, but I have never felt unsafe or in danger of losing control when this happens.
  3. untitledblue
    17
    Houston
    I accidentally filled them up to 40/35 ('cause I stink at filling up my tires) but didn't see a change in mpg. Right now they are at standard levels since I just came back from my first check up at the dealership.
  4. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Start with this.
    Who p***ed you off in the CleanMPG article and why?
    Increasing tire pressure above "standard" (i.e., placard) pressures will indeed improve your fuel economy. If you're going to request advice, you might consider heeding it.
  5. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
  6. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I am certainly no expert (1900 miles on my G3, IV), but I agree with the above comment. Is the drive to and from work the only time you drive the vehicle? That will be tough!
    I suggest you monitor the Hybrid System Indicator (HSI) screen. Make every effort to keep the "ECO" light on. The sliding illuminated bar wants to be to the left of center as much as possible, however, it can go to the right of center, and as long as the ECO light it lit, you will be doing OK. Avoid being all the way to the right .... PWR.
    Make every effort to drive steady. Accelerate with the flow, but try to avoid speeding up, changing lanes, slamming on the brakes (I know, I have driven in Houston).
    The HSI screen will also give you an indication of how your fuel economy is doing. Once the engine is warm, driving a steady 35-45 mph, the scale should be well over 50 mpg. Then as you get off the accelerator and coast, it should read 100 mpg. At a dead stop, it obviously reads 0 mpg. It's OK for it to read 25 mpg when accelerating, but as you stay with the flow of traffic, it certainly should be well above 50 mpg. You just need to drive sufficient miles in that mode for the average to improve.
    Houston is a tough driving environment. My Sister lives there, and I ask her ... why do you live here?
    Good luck. I think the Prius requires some time to "learn" how to drive it economically. Go for a Sunday drive down to Galveston. If you drive steady on the Gulf Freeway, you should get 52-53 mpg. Then drive to the West down the seawall drive at 35-45 mph and you will approach 55 mpg. I am convinced it is not necessarily slow driving, but steady driving that is important.
  7. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Houston through summer will be tough on mileage due to AC use and Houston traffic (used to live there.) With a short commute if you have the AC blasting you are going to lose a lot, particularly at low speeds or when stopped. I try to run the AC on low blower settings, and only when I need it. This keeps the ICE off for short stops/at lights. Houston has two advantages: very mild winter, plus it is flat.
    I run 42/40 on my pressures, this is within the sidewall rating and seems to work better with the tires than the placard pressure.
    City street speeds of sub 35 mph are ideal for pulse and glide IF you don't have to stop or brake alot. You want to keep the car from regenning as much as possible (as it does when you are completely off of the accelerator) as well as avoiding doing extended yellow arrow EV drives. Drive like you don't have brakes, do regular ICE acceleration and learn how to do the "no arrow" glide. While the Prius mpg peaks somewhere around 20 mph that is without the AC on...with the AC I suspect the peak is closer to 30 mph depending on settings.
    I change my own oil and use 3 quarts instead of the nearly 4 quarts that Toyota lists (which results in an overfill condition.) Some have observed mpg reduction with the standard Toyota overfill quantity. Have you checked your oil level?
    For acceleration the target is instantaneous mpg of ~1/2 of your speed. This gets you into an efficient operating zone. Too low of an acceleration is actually detrimental to mileage, as is flooring it.
    Make sure your car tracks true. If it is pulling to one side or another then you will lose gas mileage and need an alignment (free within the first year or so.)
    The 7.5 mile commute is better than the 6 mile commute our Prius regularly sees and its getting 54 mpg on the current tank, despite hills, many stops (mostly at the bottom of the hill, arggg), and highway intermixed. At 60-65 mph, you should be seeing about 55-60 mpg while cruising, but on short commutes this will be seriously derated for warm up and initial acceleration.
    It takes awhile to break in the car, tires, and driver.
  8. Vic Doucette
    Michigan
    Do you reset the average for each tank? If you don't, it may take a while -- perhaps a long while -- to see any changes.
  9. untitledblue
    17
    Houston
    Oh crud! Really? I didn't mean pissed as in "pissed" so to speak, more on the lines of aspiration (it's a compliment).
    As for the tires, you guys are probably right. Last time I did it it was my first time-I was completely incompetent and they were uneven so that's most likely why there wasn't much change.
  10. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    No problem, I took it as such.:cool:
  11. tsunami
    tsunami Junior Member
    27
    Raleigh
    I don't think a short commute always means less mileage. My commute is 5.7 miles each way and I am averaging right at 53 mpg. I was in 46-47 range until I became a pulse and glide convert. I also changed my route to residential neighborhoods with very few stops and a 30 mph speed limit. My experience (which is limited at this point) on highways is that once your get to 65 or over the mileage does back off some. If you are doing stop and go on a highway, meaning stoping and than getting back to 65 and than stopping agian, that would kill your mileage. One thing to keep in mind, regardless of your mileage in your Prius, it is probably 2-3 times what you were getting in your previous ride.
    Kirk
  12. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    A short commute for one person is not necessarily a short commute for another. e.g. your 5.7 mile commute at 30 mph gives the engine a bit of time to warm up. However, the same distance on a hwy means the engine has less time to warm up (granted, it is pushed harder/hotter on the hwy).
  13. richard schumacher
    7,682
    1,061
    United States
    Short path economy zen:
    Accelerate briskly. If everyone else passes you when pulling away from a stop you're doing it too slowly, and thus not using the engine very efficiently.
    Gliding (no arrows on the "Energy" display) is better than coasting
    Coasting is better than braking
    Braking is better than stopping
    Doing the above three without becoming a victim of road rage is a challenge.
    Do Not use "B" in normal driving. There's no place within about 500 miles of Houston where it is needed.
    Make certain that the battery system vent next to the rear seat is never blocked. And *do* use the air conditioner, because if you're too hot then the battery system is also too hot.
    42/40 PSI front/rear in the tires will help. Check pressures at least monthly.
  14. icarus
    icarus Senior Member
    4,884
    976
    earth
    Buy a scan gauge, and plug your grill. Even in Houston cold starts, and short trips will make it hard to ever get to operating temps. I drive with the top grill 3/4 blocked all the time, the bottom 100% block when the ambient is below ~60f. We get ~52 mpg on average. Scan gauge reveals temps have never gotten over 205F in the heat of summer, (last week was nearly 100f) and the A/C going. Normally it struggles to get to 185, where the T-stat BEGINS to open.
    PLUG THE GRILL!
    Icarus
  15. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I have seen this repeated many times but after driving for some time now I wonder how true it is. :confused: Whenever I accelerate with higher RPM the instantaneous MPG bar on the MFD always drops lower. :rolleyes: I don't know how the efficiency of the engine is measured but after all it is MPG that counts I think. ;) If there is data showing higher RPM giving better MPG I would love to see it. Thanks! :)
  16. 2009Prius
    2,705
    512
    63
    Do you block the center 3/4 or the two sides (leaving the center open)? Thanks! :)
  17. timberwolf
    timberwolf New Member
    220
    31
    UK
    Confused +1
    The brisk acceleration advice to my mind has always conflicted with the 1/2 MPG to MPH rule (although I do wonder whether I am doing it correctly) as the latter seems to require very gentle acceleration?
  18. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Have you read this yet?
    http://priuschat.com/forums/gen-ii-prius-fuel-economy/14701-new-owner-want-mpg-help-read-first.html
    With a 7.5mile commute 60+mpg is possible, but not if you're going 65mph on the highway. Tire pressure will help. Consider putting in an engine block heater on a timer so you start out warmed up in the morning at least (and from work if you can plug in there)...that'll buy you a few more MPGs.
    Don't sweat the guys riding your butt. Stick to the speed limit, drive in a consistant and predictable manner and they'll figure out how to get around you.
    The biggest thing you need is to understand the concept of conservation of momentum. Anticipate traffic, don't follow too close, you should drive like the brakes don't work--start slowing down way before places you know you're gonna have to stop...if you stay on the 'go pedal' and brake at the last minute you're burning gas for 1/4 mile, losing regnerative braking and costing yourself mileage. If you have to stop anyway, what's the rush to get there? And better yet if you can slow down enough to wait out a red light until it turns green so you don't ever come to a full stop and just keep on rolling you're doing even better.
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Any car gets better gas mileage cruising at speed than it does accelerating. To maximize time spent cruising, you want to minimize time spent accelerating (within reason). To spend less time, you need to accelerate quicker.
    In a gasoline engine, the throttle plate can cause restrictions in the air flow, larger throttle openings have fewer air friction losses. (at some throttle opening, often full throttle, most gas engines choose a richer gas to air mixture, this will offset air friction losses)
  20. JimboK
    2,817
    190
    49
    Chesterfield, VA
    I don't care much for subjective terms like "brisk," "moderate," or "gentle." What is moderate to one person may be either brisk or gentle to others.
    Instead, I promote the 1/2 MPG to MPH rule for acceleration -- i.e., keeping iMPG at least half the vehicle speed. That, BTW, is not what I call brisk. I agree with Richard that if everyone passes it's not brisk. I disagree that to let everyone pass you is inefficient. As much lead as others seem to have in their right foot, it might be inefficient to keep up with them!
    The subject of how much go-pedal to give during ICE-on conditions is a matter of substantial discussion. Low-RPM conditions are thought by many to be inefficient, and the theoretical power curves of the Prius ICE seem to confirm this. But anecdotally, I and other hypermilers have reported good results with keeping RPM as low as 1200 or 1300. That pushes the iMPG well above vehicle speed, perhaps up to x1.5. It also is gentle acceleration by anyone's definition. Most assuredly, virtually every other car will be passing.
    I have done some preliminary testing comparing various acceleration rates during pulse and glide, and the results suggest that rates in the range of 1300 are at least as efficient fuel economy-wise as those in higher ranges. The key word is preliminary, however; the test environment was less than ideal (traffic disrupted my glides on the two-lane rural road I was using), and I'd like to repeat the tests in a different environment.
    Meanwhile, Hobbit has experimented using fuel injector timing as a surrogate indicator of engine load. The ICE really is inefficient when it's not running under load, and his view seems to be that as long as injector timing has reached a certain operational plateau, the ICE is loaded. Quoting him:
    "Even a fairly gentle startoff from the line yields injector times of high sixes or 7.x at ridiculously low RPMs like 1250, as high torque is produced to help takeoff."
    My own recent experience applying this and using injector timing as my load criterion (monitored in CAN-View) suggests that in ICE-on conditions at low speeds it's actually difficult for the ICE not to be under load. Especially from a dead start, after "goosing" the go-pedal just enough for the ICE to light, I show injector timing levels well above the "loaded" threshold even with these low RPM.
    Therefore, it seems the iMPG can be well above MPH with the ICE still under load and, therefore, the car accelerating efficiently.
