Help me with my Prius rental car
Discussion in 'Newbie Forum' started by Karl102, Aug 11, 2009.
  1. Karl102
    Karl102 New Member
    Washington DC
    I was upgraded to a Prius by the rental company. Cool. My first time in a Prius. It has about 27000 miles on it so I guess it is a 2009. Runs great.
    Can someone direct me to, or tell me, a quick guide to turning it on and off?
    Short version --
    I have trouble taking the parking brake off making it go. I end up turning the main power switch on and off 3-4 times. Then, I can select drive or reverse.
    Longer version --
    When I stop and turn it off, the screen says to put on the parking brake -- something about charging the battery. I figured out the parking brake is the rectangular P button with the green light. I push that. I also push the mechanical foot pedal brake. So turning it off is fine.
    Turning it on and making it go is still a problem. I cannot shift it out of park without turning the main power on and off several times -- that can't be the right way. Seems I should be able to push the parking brake button again to turn it off, but it does not go off when I do that.
    Any tips appreciated.
    Thanks.
  2. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    You cannot turn on the Prius and get to READY unless you are pressing the brake pedal. Once you get to READY, release the mechanical parking brake, put it in R or D as necessary, and drive.
    More specifically:
    1. Press brake pedal
    2. Press Power button
    3. Release mechanical parking brake
    4. put it in gear and go.
    That's it.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    to start your Prius follow the advice above.
    To switch it off just stop then press the power button, no need to put it in park by pressing the P button, it does it automatically.
    I do advise pressing the park brake pedal with your left foot.
    Release the park brake by pressing the pedal firmly again.
    If you want to listen to the radio without "starting" the car just press the power button without pressing the brake pedal. A second press with you feet off the brake pedal will allow you to use the fan but you still cant select a gear, a third press and it all goes off again.
  4. recessionroadie
    recessionroadie New Member
    Washington, DC
    Did you get it from the Hertz at National? Is it black? If so, I had the same one with the same problem last month. Traded it back in for a new one.
  5. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    clarification:
    the parking brake is the thing on the floor on the left you push in with your foot to hold the car in position while parked.
    the park button is the button on the dash that you push with your finger to take the car out of gear
    the brake pedal is the wide pedal towards the middle on the floor that you depress with your foot to slow the car when in motion or to keep the car immobile upon start up and initially placing the car into gear
    the car won't turn on or off or allow you to change from one gear to another (while stopped) unless you are depressing the brake pedal
    so - parking brake (aka emergency brake), park button, and brake pedal.
  6. Karl102
    Karl102 New Member
    Washington DC
    Got it using MJFrog's steps. I wasn't pushing the brake pedal first thing. No problems now. Thank you.
    Yes, I use the parking brake (emergency brake) whenever it is off.
    I got it from Avis in Chicago. A blue car.
    Thank you all for your kind help
  7. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Enjoy your time with a Prius! You're now past the only real "quirk" of the Prius vs a "normal" car. The rest is pretty much the same. The gasoline engine (what we call the ICE, or Internal Combustion Engine) will turn itself on and off seemingly at random if you're using the air conditioning, but ignore it - that's normal. Also, the engine will rev with no apparent connection to travel speed when accelerating at highway speed - again, that's normal for any constantly variable transmission, or CVT (it feels like driving a boat where the revs aren't directly coupled to speed). Ignore that too. Don't ignore the good mileage, though, and what is essentially a great car even without the hybrid drive train!
  8. richard schumacher
    7,664
    1,045
    United States
    Important safety tip: always lock the car after you park it. If something is wrong (not turned completely OFF, interior light on, door or hatch not completely shut) it will give a long warning beep. Of course all cars should always be locked anyway to avoid insurance problems.
