Install Shark Fin on 2010 Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by nemrut, Aug 9, 2009.
  1. nemrut
    nemrut New Member
    57
    san francisco
    Anyone do this to their 2010 Prius? Did it change the reception quality at all?
  2. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    I've been wondering the same thing... in particular, if there's a different antenna I can use to improve the XM reception. Anyone have any experience with alternate antennas?
  3. miketee
    miketee Junior Member
    52
    Prince George's County, Maryland
    Not yet...they don't have all of the 2010 colors. As soon as they offer one in Blizzard Pearl, I'll order it and report back.
  4. rachaelseven
    616
    212
    Adams, MA
  5. cpatch
    cpatch New Member
    383
    81
    Carlsbad, CA
    There's a thread somewhere else that said the reception was worse with the shark fin.
  6. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    There are a lot of threads and posts elsewhere saying that on the Gen II, the radio reception with the shark fin is noticeably worse than with the Gen II whip antenna.
    I would expect the same on the Gen III (unless the reception on the Gen III is similarly weaker anyway because of its semi-stubby antenna which is a lot shorter than the Gen II's antenna).
    Notwithstanding its weaker reception, I'm keeping my shark fin antenna on my Gen II. I got it for its looks. But if I ever move out of New York City, I'll probably put the OEM whip antenna back on.
  7. Cassandra
    Cassandra ELECTRIC VEHICLE
    57
    Victoria, Canada
    I'm going to put one on mine. It looks nasty cool. Hopefully the reception isn't THAT bad.
  8. rachaelseven
    616
    212
    Adams, MA
    I've heard this as well, but I wonder what non-shark-fin alternatives can do reception wise? I realize its a bit off-topic, but are there high power whip antennas that will actually improve reception?
  9. Boo
    5,051
    488
    97
    Flushing, NY
    Cassandra,
    If you're going to put one on, I have installation suggestions as I found the Visual Garage instructions to be a little lame and arguably wrong.
    I would suggest that after you've centered the shark fin, that you measure and mark the spots where the two rear corners should touch down -- the two corners should be exactly the same distance away from the crevice formed by the roof and hatch.
    Then, after you've removed the paper from the adhesive tape, I would start by lining up and pressing down the rear corners first, i.e., work from back to front and not front to back as the Visual Garage instructions say. If you follow the Visual Garage instructions and stick down the pointy front first, you can easily end up with a shark fin that's at least slightly crooked.
    2 people like this.
  10. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    Tom, Do you find the FM alot weaker with the shark fin? We live in Brooklyn and am just wondering.
  11. Ryanpl
    780
    158
    Brooklyn, NY
    nevermind, I found my answer
  12. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    Using shark fin allows you to use a roof rack and carry large loads like skis & ski boxes. Sat antenna sits above windshield on the left or right side and usually gets good reception.
  13. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    Post deleted, I figured out the answer.
