Spotting on Windshield from Lawn Sprinkler
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by inverness, Aug 11, 2009.
  1. inverness
    inverness New Member
    reston virginia
    My 2010 got "watered" by a lawn sprinkler yesterday and I'm having a devil of a time trying to remove the resulting water spots from the windshield. Plain ole rubbing w/a soft cloth does nothing; nor does cleaning w/Windex. I'm hesitant to try anything other than glass cleaner.
    Any suggestions? (the spots on the side windows - which are treated to repel water - came off fairly easily w/the Windex, but no amount of elbow grease will remove them on the windshield).
  2. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    Hard water spots can usually be removed from glass with a little diluted vinegar or straight vinegar if necessary.
  3. nullxposur
    nullxposur Junior Member
    70
    San Antonio, TX
    seconded! I would buy some 5% distilled vinegar from the store and some very fine steel wool. simply wet the steel wool with some distilled vinegar and rub the white spots from the windshield. wash with a water hose after and it'll be like new... it's just stink like vinegar for a bit :D
  4. inverness
    reston virginia
    Thanx! I'll give it a try. Never thought we had hard water in Fairfax County, VA!
  5. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    On some other boards I frequent they recommend Bon Ami and some water to make a paste that'll clean off water spots, but I've never seen Bon Ami in any of the grocery stores around here.
    Bon Ami
  6. jay_man2
    1,246
    144
    Manassas, VA
    Here in Manassas I lived on the other side of the main drag through the 'hood for 12 years and had hard water. Less than a mile across the way, been here 10 years and the water's soft as can be. Weird.
  7. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    :help: Surely you jest steel wool on glass, do you want the guy to ruin his windshield. Steel wool will definitely scratch the glass in my opinion. No way would I use steel wool on glass. ammonia glass cleaner maybe.
    Someone else chime in on this.
  8. jay_man2
    1,246
    144
    Manassas, VA
    I wouldn't get steel wool anywhere near the vehicle. Or wool for that matter. :p
  9. texas112
    texas112 Junior Member
    45
    DFW
    Same problem here, I've complained to the apartment management, but it will take another day or two before they adjust the sprinklers. Hmm, it didn't seem to bother me when I had my clunker truck :)
    I tried Windex and it made little difference, so I tried Stoner's Invisible Glass as suggested on one of the other threads here -
    http://priuschat.com/forums/gen-iii...ing/62907-my-favorite-detailing-products.html
    - and it made a big difference. Just a little more elbow grease than normal cleaning, but the spots are gone. Well, they're gone until the next watering night :)
    And it's safe for tinting. I picked it up at Wal-Mart.
    Invisible Glass | Miracle Cleaning Products | Glass Cleaner
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    my car gets the same thing DAILY. idiot homeowners association wastes water like its nobody's business. every morning i get to sidewalks nearly drowned from the drenching they receive every night.
    as far as steel wool?? no... no... u are lucky if its only the glass. i have it all over the entire front of my car. better off to clay bar it or something.
  11. jay_man2
    1,246
    144
    Manassas, VA
    Between the Stoner's, an application of Rain-X, and Rain-X washer fluid, I have no issue with water spotting on the windshield. I didn't even think to mention Stoner's when I first posted.:eek:
  12. angelrob
    angelrob New Member
    94
    Rochester, NY
    I have a friend who used to work at a dealership. He told me the same thing. That's what they use to get the glass sparkling. Great for removing bugs. But ONLY THE GLASS! That said, those were other brands and earlier years so there may be coatings on the Prius glass to make it shed water (I don't think the tinting is a coating, right?!)
    In case it needs to be said: Don't use it on your paint job no matter how fine the steel wool :eek:
    Robbin
  13. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
  14. nullxposur
    70
    San Antonio, TX
    lol there's different levels of hardness. make sure you get the fine steel wool. i used to detail for a dealership and did this many times. i've even used it inside the glass to remove tint glue leftover residue. it's awesome once you try it, but the finest one you can find as it'll be soft and not hard.
  15. JRitt
    JRitt Bio-Medical Equip. Tech
    133
    St Louis, Mo
    I had that happen to mine also but the next day we had a hard thunderstorm and it took it right off
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    talked with sis who works in car biz, she asked detailer and they said best thing is windex and aluminum foil. take crumpled aluminum foil, spray a good window cleaner on it, anyone will do and use the foil in a swirling pattern and then squeegee clean
  17. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I've heard the same thing with newspaper, which leaves no streaking.
  18. jay_man2
    1,246
    144
    Manassas, VA
    When I called to cancel my subscription to the Washington Post a few years ago, the customer service lady asked if there was anything I liked about the Post. I told her I liked how it left my windows streak-free, and she agreed that that was one good thing about the paper. :p
  19. NoMoShocks
    1,292
    83
    Camas, WA
    I used to use newspaper to dry my windows, but then I noticed a blue haze developing on the inside of the window. Now I don't use newspaper and still get the blue haze.
    For fun with fine steel wool, make sure you are not near any combustable materials and drop some on the terminals of a 9 V transistor radio battery. Start with a small peice unless you want a real confligration on your hands.
  20. PriusRoadWarrior
    76
    Wisconsin
    VINEGAR ONLY- SKIP THE STEEL WOOL, use a soft cloth
