What needs to be done to pass failed emissions test?
Discussion in 'Gen 2 Prius Technical Discussion' started by stevor, Aug 10, 2009.
  1. stevor
    stevor Junior Member
    Connecticut
    What needs to be done to pass a failed Connecticut emissions test? 2005 160,000 miles This is the car's test results: EMISSION TEST RESULTS:Overal OBD Result: FAILMIL Engine off: PassReadiness Result: N.AConnector Voltage: 12Catalyst DTC: N/ATEST TYPE: OBDll Connector Status: PassMIL Engine On: PassDiagnostic Trouble Codes: N/ARPM:Communications Status: FAILMIL Commanded On: N/A
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Has this car passed CT emissions before ?
  3. Politburo
    Politburo Active Member
    971
    208
    As I understand, the inspection computer wasn't able to talk to the car's computer.
    It looks like CT does private inspections. Other people who had this problem many times had success just by going to another shop. It may be worth $20 to have it tested somewhere else just to make sure..
    ETA: This document has some diagnostics for the possible issue. http://74.125.47.132/search?q=cache...ail&cd=9&hl=en&ct=clnk&gl=us&client=firefox-a
  4. stevor
    Connecticut
    SageBrush, this is the first ever emissions test for this car.
  5. richard schumacher
    7,664
    1,046
    United States
    Try a dealer next. If they can't talk to the car at least you'll be in the right place to get the communications problem fixed. I would bet that there is actually no emissions problem with the car and that there was some problem with the inspection device.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Engine off: Pass
    Catalyst DTC: N/A
    TEST TYPE: OBDll
    Engine On: Pass
    RPM:
    Commanded On: N/A
    Formatting the information properly makes a huge difference.
  7. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    Clunkerville. That is the whole idea behind the CARS program.
