bars in the gas meter
Discussion in 'Gen 3 Prius Main Forum' started by Fussion101, Aug 13, 2009.
  1. Fussion101
    Fussion101 Junior Member
    81
    NYC
    Anyone know the estimated amount of gas each bar signifies in the gas meter?
  2. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Just based on my personal experience, where each time that I have filled up (with 6850 miles on my Prius V) I have added approximately 10 gallons. Since there are 10 'pips' on the fuel display, I have used that to indicate that there is approximately 1 gallon per pip.
    That said, I know that sometimes I will drive over 150 miles before the first pip drops, and that I have seen the last two pips go in 50 miles, so it varies. There are other posts here that mention that, do a searh to find them.
  3. nullxposur
    nullxposur Junior Member
    70
    San Antonio, TX
    I'm with stupid (hehe). I'm using the 1 pip per gallon technique too. I'd also look at how many miles it calculates till empty and divide that by what you normally average per gallon. I say this because the other day I drove it till the 2nd pip turned to 1 and I had about 40-50 miles left till empty, which coincided with my mpg's for that tank.
  4. topkick
    topkick Member
    166
    Oklahoma City
    Each vehicle is going to be different. On my first bar I get about 85 miles and each one is different after that. My ninth gets about 50 and the tenth gets about 20 before it starts to flash.
    I have only ran it down to the flashing tenth bar once and with my 2010 like my 2007 I usually get gas when I am down to two bars left.
    Some say that when you have the tenth start flashing you should have over 50 miles left, but I never want to chance it.
  5. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    Why are they called pips, and did Gladys Knight approve its use? :D
  6. Slovewell
    Slovewell New Member
    95
    Va
    If they were real pips they would be a different color. I have found my computer is 10% off. When it says I'm getting 55mpg and I calculate it with the calculator, I find I am right at 50mpg. Every time, it is lower than what the car thinks I'm getting.
  7. jay_man2
    1,246
    144
    Manassas, VA
    There's a whole other thread or 7 about the inaccuracy of the consumption display.
  8. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    What I have done several times (as I usually will wait for the last one to start flashing myself), is drive another 100 miles or so after the flashing began. Then, when I fill up, I am only able to get 10 gallons into my tank. This means that if I am averaging 500 miles per fill-up, which I have not yet had a tank lower than that, and if I can only put in about 10 gallons, there must be 1.9 gallons left in the tank, or another 100 miles or so.
    While i usually try to fill-up as soon as I can after the flashing starts, I am not too worried. I only ran out of gas once in my life, when I was 17, and with my girlfriend. (But as she was wiser than I, I could not even take advantage of her.. j/k ;)) Her dad had to come help us, and I never did that again.
  9. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    I got down to a "blinking one" pip and it held 9.2 gallons at fill-up.
  10. qbee42
    3,082
    Pip Pip, n. [Formerly pippin, pepin. Cf. Pippin.] (Bot.)
    A seed, as of an apple or orange.
    [1913 Webster]
    -- From The Collaborative International Dictionary of English v.0.48
    Pip Pip, n. [Perh. for pick, F. pique a spade at cards, a
    pike. Cf. Pique.]
    One of the conventional figures or "spots" on playing cards,
    dominoes, etc. --Addison.
    [1913 Webster]
