They have no idea what's wrong with my car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ny biker, Aug 14, 2009.
  1. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    As mentioned in this thread...
    http://priuschat.com/forums/gen-ii-...bleshooting/66582-new-headlight-computer.html
    ... my 2007 (with less than 22,000 miles on the odometer) started having headlight problems last month. They changed the HID bulbs but it still had problems, so after more diagnostics they determined the computer needed to be replaced. That was on backorder for a week, and after it came in on Tuesday 8/11 they installed it and found that it did not solve the problem. At 7:05 pm yesterday (8/13), they left me a message telling me they are still trying to figure out what's wrong with the car.
    They consider it unsafe to drive until it is fixed. I've been driving a loaner (2009 Matrix) since 8/4, which is frustrating because it's costing me more in gas money than the Prius would cost.
    But most importantly I just want my car to be working properly. I don't know what else to do besides wait as patiently as possible and trust that someone at Toyota will figure this out.
    Does anyone out there have any advice?
    Thanks
  2. qbee42
    3,079
    This has been discussed in any number of threads. Take a look at this search:
    Google
  3. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    Yes, but they've already replaced the lights and the computer, and the problem is not fixed. And they have no idea what to do next.
    And this is a large dealership that has sold and serviced many Toyota hybrids, so it's not like I'm dealing with someone who rarely services them.
  4. qbee42
    3,079
    If you have power, then it's either the capsule, the computer, the socket, or the wiring. It's not rocket science. My first guess, and it's only a guess, is a bad capsule. Simply swapping in a new capsule doesn't mean the new one works. All indications are that the Gen II HID system is very touchy about capsule compatibility. It appears possible to have a "good" capsule that won't work with a particular car. I'd try another one, or swap in the one from the other side as a test.
  5. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    Well I have an update. The problem is that they are not able to reset the system after installing the new computer. They have basically consulted with everyone in the service department at this dealership, which as I mentioned is large and has worked on many hybrids over the years, so lack of experience or knowledge is not a problem here. They have also been in consultation with people at Toyota HQ in California. So far nothing has worked.
    There is one more thing they are going to try, and if that doesn't work, they may have someone from California fly here to Virginia to look at the car. And/or they might wind up replacing the entire computer/inverter system.
    (I hope this all makes sense - I was not able to take notes during the conversation.)
    So, this sounds like it might be an epic fail for the car. At least it's still under warranty. I'm just hoping it will all be resolved soon.
  6. ceric
    ceric New Member
    1,114
    Fremont, CA
    What I don't get is that it seems to me the auto-leveler is the one that should be looked at.
    Why the computers? (by that, did you mean the blasters? or the BCM (body control module)?
  7. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    When I brought it in last week, I explained the issue with the lack of brightness in the distance and said that the auto-leveler probably was the problem. They expected to have it fixed and back to me in a couple of hours, so I think they thought the same thing. But late that afternoon they called and said that further examination showed that they needed to replace the computer that controls all the lights, and that the car was unsafe to drive because the headlights could fail at any time. Since it costs them more to give me a loaner and install a new computer, I would think they looked at the leveler first and determined that was not the problem.
  8. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    So, tell me again.... Why do people want HID lights? Aren't halogens bright enough? Or are they not a cool enough colour? Not efficient enough?
    2 people like this.
  9. Patrick Wong
    18,210
    6,511
    Regarding the OP's issue, it also sounds to me like the level sensor located at the rear axle should be replaced. As Tom indicated in post #4, there are a limited number of parts that make up the lighting system, so worst case, replace them all...
    My 2004 has HID lights as well as the fog lights that have cosmetic functionality only. The HID lights are OK but I wouldn't go out of my way to seek out a vehicle with those lights.
    Considering the ~25 vehicles that I have owned in the past, the best headlights were on my 1988 BMW 325i convertible. The halogen lights were round and had glass lenses, not some weird shape with plastic lenses that discolor over time. This meant that the light beam could be focused sharply. The low beams had a very sharp cutoff which was friendly to oncoming traffic.
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I feel sorry for you if you are having problems with the HID. But it is quite correct that there are numerous threads on this issue. IMO, it is a problem. There is a reason the 2010 Prius abandonded the HID. Many owners struggle with dealing with them. Some with more success than others. Investigate the other threads and good luck.
  11. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    I've searched for other threads on HID problems, and I haven't seen anything like this. It seems like it is a beyond just a headlight problem. Everyone in the service department has looked at the car. Engineers from Toyota are involved. I'm pretty sure someone already looked at the leveling sensor.
    They're spending a lot in man-hours on this so they really want to solve it and get my car back to me. They've dealt with HID problems before and they've told me that they've never encountered this anything like this.
    Thanks.
