Dashboard Dimmer
Discussion in 'Gen 3 Prius Main Forum' started by fromano, Aug 18, 2009.
  1. fromano
    fromano New Member
    Santa Cruz, CA
    On my Gen II I could adjust the dimmer both when the headlights where on or off, I noticed today in my V AT that the dimmer doesn't do anything when the headlights are off, another thing is that when the headlights are on I can't set the dimmer to full brightness like the brightness of the dashboard when the headlights are off.
    Anyone else see this or is it something I need to get fixed
  2. fuzzy1
    10,516
    When the roller switch hits the end of its travel, push it further until it clicks. Then you should get full headlight-off brightness.
  3. fromano
    fromano New Member
    Santa Cruz, CA
    Thanks you're right I didn't roll it up hard enough, but now when it clicks it's fully bright
    Can you also confirm that when the headlights are off the dimmer doesn't do anything
  4. xanmato
    xanmato Junior Member
    31
    Seattle
    I find it annoying in the dark when you are trying to set it to night mode, I can't find the damn thing most of the time.
  5. fromano
    fromano New Member
    Santa Cruz, CA
    True, Can you also confirm that when the headlights are off the dimmer doesn't do anything
  6. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    My dimmer switch doesn't adjust anything when the headlight switch is in the off position.
  7. cmalberto
    cmalberto New Member
    95
    Sour Lake, Texas
    Oddly enough mine was in full brightness and I was trying to adjust the blinding display by turning down the nav. Glad to have found it though.
    --Mickey
  8. IraS
    IraS Member
    165
    Austin, TX
    I believe that in my 2004 Prius the dimmer control only worked when the headlights were on, the same as in the 2010 Prius.
  9. fromano
    fromano New Member
    Santa Cruz, CA
    Interesting, In my Prius 2008 it worked on both, that's why I was confused with the 2010
  10. RickFlashman
    RickFlashman New Member
    141
    31
    Winter Park, FL
    The dashboard dimmer is my biggest complaint. If I decide to leave parking lights on as daylight driving lights, I have to turn it up (past the notch) to get full brightness. Then, at night, I have this SUPER BRIGHT dash I have to manually reduce. Light sensors for cars are probably $0.01 cost parts, they really should have added one to have the dash respond to night vs. day for those who use parking or headlights during the day.
  11. fromano
    fromano New Member
    Santa Cruz, CA
    You're absolutely right
