P225/45/17 = p195/65/15
Discussion in 'Gen 3 Prius Main Forum' started by hschen, Aug 19, 2009.
  1. hschen
    hschen New Member
    121
    Irvine
    Anyone noticed that the same diameter tire size is not the upgrade one P215/45/17. P225/45/17 has the exact same diameter as the P195/65/15, which means no ABS concern and no speedometer error. How come Toyota will use P215 instead?
  2. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I don't see a concern with the ABS and I'm guessing they'd rather deal with a speedo error of less than 1mph at 65 than they would with a tire that is 1.18" wider than the 15".
  3. hschen
    hschen New Member
    121
    Irvine
    Wider tire is what I am looking for. Pruis stock tires are too thin. Would 1" wider cause wheel wall rubbing issue?
    Thx.
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I'm curious about this too, but installing spacers would avoid the rubbing issue if 225 proves to be too wide.
  5. NoMoShocks
    1,292
    83
    Camas, WA
    Crank you wheel all the way to the left and right, and measure clearance around each front tire at the two extremes.
  6. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    IMHO 225 is much too wide a tire, my guess is that mpg will really drop due to the added weight of the tire along with more rolling resistance due to the wider footprint.
    Like NoMoShocks said, crank the wheel lock to lock and measure to confirm.
    How come Toyota uses 215 instead of 225? See first paragraph.
    For a vehicle such as a Prius, it's mission in life is to achieve the highest mpg. Honestly, the 17's I think were more of a "fashion statement" and a way to give the car a more sporty appeal to attract a larger audience.:D Just my 2 cents....
  7. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    The 225's are about 4/10" wider than the 215's. Possibly noticble but not significantly so. The 215/17's already look good and anything wider would kill FE
