How's the spoiler holding up?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Aug 23, 2009.
  1. Tideland Prius
    16,549
    How's the black glossy spoiler holding up to car washes??
    My smart has a similar plastic panel on each side of the car as well as the top par of the rear hatch. Unless I wax it regularly, it would show scratches and most recently, it has become a faint white (fade from sun?? hard water?). Is the new Prius' spoiler just as high maintenance or is it made of better plastic (or manufactured differently)?t
  2. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Carwash:eek:
    Maybe touchless but nothing else
  3. freo-1
    freo-1 New Member
    180
    22
    Mass.
    I do not get why they went with this approach. To me, it comes across as just plain cheap. It reminds me of the older GM cars, where the bumpers were left bare on the "base model", while the higher trim models would paint the bumpers to match the car.
  4. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    I looked at mine briefly a day or so ago, and 10 weeks, a couple of hand washes, a couple of rainstorms, and about 3 touchless automatic washes, and so far so good.
  5. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    So far so good here as well. I have put a good wax on the spoiler to hopefullt lessen any water spotting etc. But I suspect it has to be handled with some care...but no marks yet. One thing don't forget if your in a garage to be sure your door is down...I almost opened the hatch not thinking and that could have been a "MARKED" disaster! :(
    But now that I almost did that once it won't happen again!
    Keep you posted if the wearability changes.
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
  7. stream
    2,977
    452
    Long Island, NY
    Almost 3 months in, mine is fine, although I've only hand washed the car so far. I don't have high hopes for it after an extended period of time, though--it looks like a scratch & finger print magnet.
  8. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Thanks Stream for the info! Appreciate it. Plus the rubber is inside so you wouldn't see it outside. I caught myself thank god! Now I have a TPMS warning and the tires all seem up to snuff...So I guess I have to take it back tomorrow to have them check it...I don't know what it was set at when build...so they may have to recalibrate...All the tires on my V seem to be up there...at 38/40
    I have to go check the door sticker to see if that's in line.
    Thanks again!
  9. stream
    2,977
    452
    Long Island, NY
    You need to initialize the TPMS system, if you didn't already--see my response in the other thread.
  10. BlueIce
    BlueIce New Member
    43
    Plymouth, Wi
    There are two handlles on the inside of the hatch to pull the hatch shut. The first time I shut the hatch, I didn't know what to grap unto. The spoiler is very light weight don't think it was design to be a handle. Hopefully it doesn't fade.
  11. stream
    2,977
    452
    Long Island, NY
    Agreed--I always use those handles, and let go about 3/4 of the way down, and the momentum closes it perfectly. The fingerprint comment was related to telltale signs left when one of my kids clearly forgot about the handles. :D
  12. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Doesn't GenIII have color-coded (same paint as the rest of the car) spoiler, in contrast to GenII's spoiler? Why would it be any different from the rest of the car?
  13. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Nope, the GIII spoiler is black regardless of body color.
    Kind of weird they went this route but I do like it on my Blizzard Pearl to be honest...
  14. Tideland Prius
    16,549
    I hand-wash mine only with the occasional touchless
    Sounds good. Yeah it does, that's why i'm asking so I have an idea of what preventative maintenance I can do.
    Colour-coded to yours cause your car is black :p. It's still black for the rest of us who didn't order a black car. The Gen IIs had colour-keyed spoilers
    Yes, don't use the spoiler to close the hatch! It's only held on by clips (the Gen II was anyway...)
  15. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I stand corrected. I actually think it looks better that way on Blizzard Pearl with SR as the black color flows throughout.
    It appears to be the same paint so why this concern about holding up? Would paint on plastic not hold up as well as metal (or plastic bumpers for that matter)?
  16. stream
    2,977
    452
    Long Island, NY
    It's not painted--it's a high gloss plastic.
  17. Tideland Prius
    16,549
    Yeah I was under the impression that it's high gloss unpainted plastic... like I said, the same one on my smart that I currently have and it's not holding up well. There are swirl marks and most recently, it has become a faint white. I don't have my wax products with me so I can't do a touch up and see if it makes a difference but I do know the two times I waxed the smart, the glossy plastic trim came back to life and the swirls marks were hidden. I was hoping the Prius' one would be more resistant to swirls and scratches.
  18. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    The black roof flowing throughout would have looked better on any color, that's why the SR should have been available even on a V, but we won't go there again... ;)
  19. stream
    2,977
    452
    Long Island, NY
    The best thing is to wax it like the rest of the car, and be careful not to scratch it when drying it or dusting the car. The best strategy to minimize noticeable scratches/swirls is to wipe with straight back and forth (not circular) motions, from the front to rear of car. This makes any scratches (which will occur no matter what you do) less noticeable.
  20. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    +1, that's how I always did it...
