Gen III, a step backward?
Discussion in 'Gen 3 Prius Fuel Economy' started by a64pilot, Aug 24, 2009.
  1. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    OK, before I get flamed let me explain. My only real experience with a Gen II was last year when I rented one for a week, but it seemed easier to get phenominal mileage out of it. I mean consistentatly in the 70's and above if I tried and conditions were just right etc. I know you can't get much of a comparison with just one car so maybe it was just a "good" one?
    I just can't do it in the Gen III. I can get mid 60's in it pretty easily, but I can't "game" it as easily and get the consistent 100 MPG bars like I could in the Gen II. MY Gen III isn't broken in yet and the Gen II was. Will it get easier as my Gen III breaks in? Or is the Gen III more of an advance in building a better car for the masses by being bigger, heavier and more powerful, but not as good at great mileage as it's predecessors?
    I'm beginning to believe Toyota built a car for the general public and made concessions as far as fuel efficiency is concerned. I'm also wondering how much of the increased mileage that I hear about from a Gen III is form the inaccurate FCD as opposed to an actual mileage increase.
    How many of the Gen II owners that now have a Gen III are there seeing better mileage?
  2. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    There's a thread about this with a hypermiler and his followers and someone else going back and forth on this very topic. If I could remember what to search on, I'd post a link.
  3. john1701a
    john1701a Prius Guru
    12,819
    5,304
    58
    These graphs of my real-world data speak for themselves...
    So for in August, my average is 53.9 MPG.
    The 2010 is clearly delivering higher SUMMER efficiency and I suspect WINTER will be quite a bit more pronounced of an improvement (due to heat-retention design upgrades).
    2 people like this.
  4. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    huh.. couldn't find it.
    Here's the rundown from my 35 minutes in a Gen III.
    1) Make sure to monitor tire pressure, I've seen dealers lower it to "cush" the ride, but not usually on new cars.
    2) Check oil level. MANY of the factory Prius are past the Over-fill, although this issue may have been resolved in more recent shipments.
    3) Batteries do break-in, give it about 30,000 miles for this to complete, most of it will be done in the first 10,000 miles though.
    === The above will make negligible improvements ===
    === These will make serious improvements ===
    1) Be sure to put in in ECO-Mode. That's what the button is there for.
    2) Drive less aggressively (slow steady acceleration, slow steady deceleration).
    3) Put the AC "auto" mode with the temp at something a site less aggressive than 60 degrees.
    4) Force S4 (every few minutes when your at a complete stop hold the brake (hard) and tap the gas until the engine comes on. Stay stopped for 10 seconds and see if the engine turns off. Practice this somewhere open and deserted so you don't rear-end the guy in front of you the first time you try it. Once the car is warm enough (should happen within 5 minutes for a Gen III) your in S4 and your in-city driving may be greatly improved.
    I believe that the Gen III is as capable with less work than the Gen II, but unfortunately there are less tools for the Gen III for those who aren't afraid of the extra work.
    Eco-Mode in a 10,000 mi + Gen III with a "just drive it" mindset should net better numbers (on a like terrain and commute) than a "just drive it" mindset in a Gen II. It was certainly my experience (all 30 minutes of it).
    11011011
  5. a64pilot
    771
    62
    Albany Ga.
    Wow, I didn't realize that cold wx made that big of a hit in fuel consumption. I can see why it would for many reasons, just didn't know it was that big. Do you keep it in a garage? Do you pre-heat the engine? I guess neither can be done at work though.
    My impression is that if driven "normally" the Gen III get's as good as or maybe even better than a Gen II, just the Gen II is easer to get really great mileage if conditions were right. I know, I like to "play" and seeing multiple 100 MPG bars is fun. I gave up trying to get to the no arrows state on my Gen III and just thy to use the HSI for energy management.
    Maybe it's just GEN II's techniques just don't work well with the Gen III? It is a different animal after all
  6. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    As far as I could tell every Gen II trick worked in the Gen III. The big difference was RPM -vs- SPEED -vs- GAS-PEDAL-PRESSURE. ECO-Mode does some throttle adjustment that I wasn't expecting and it took me a while to figure out the "curve" so to speak.
    If your serious enough to drop a few hundred, I'd recommend one of Danny's Scan Gauges. It will give you the RPM and that should get you on the right path for sure. Otherwise just be patient feel your way through.
    11011011
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    There have been several threads about Generation 3 and how people like it, or dislike it.
    One thing I think everyone needs to keep in mind is that change was inevitable. Toyota had to update The Prius. So like the 3rd generation or not, it was coming.
    Overall, I think it's seems to be a sucess. I think Toyota did an excellent job of improving some mechanical tangibles. No Gas Bladder, Thermos, New Beltless Engine, Heat exchange system. I personally think they did a great job freshning the external look, while maintaining a "Prius" benchmark.
    I'm not going to comment on interior, because I haven't lived with either Generation 2 or Generation 3, and I think you judge an interior after you've lived with it for a while. First impressions? The 3rd generation seems more "normal" car like. People loved the 2nd generation, I loved the second generation, but Toyota couldn't continue to sell that car unchanged forever.
    To the original poster, if you can get mid 60's MPG in your 3rd generation then I don't think there is much to complain about.
    Step forward? Step Backwards? Neither...inevitable change.
  8. a64pilot
    771
    62
    Albany Ga.
    I'm digging my Auto-tap out of storage. I plan on using it with a Dell netbook to see what data it will display from the Can-bus. It's excellent for a GM, but I think I had heard somewhere that Toyota didn't release what it put's on the bus. I should know by tomorrow.
    Oh and I'm not beating on the Gen III. I bought one, I love it. I just think it's part of the evolution of almost every "ground breaking" car to evolve into something more mainstream. The Datsun 240Z and Miata are / were excellent cars, but became more luxurious and heavy, but less sporty.
  9. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Thanks John for the nice post. A question seems that your mileage dropped in July/August some, and just confirming, I suspect due to the A/C use? Did you use it often?? You have the ominous cold winters like Buffalo so I am hopeful as well, that the New thermal change with Exhaust Gas will cause better mileage as well.
    Thanks for the post...
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    OP, 70+ mpg in a Prius requires gliding, so I'll rephrase your question as "how do I glide in my G3 Prius?"
    It isn't obvious from the HSI I gather, so I guess you will need to hook up a scangauge or similar device and learn to correlate to the HSI. High MPG is doable, as Ken from Japan has demonstrated.
    Have fun, and expect success.
  11. anne1965
    anne1965 Gotta love the game...
    131
    Leiden, The Netherlands
    I
    Just weighing in to confirm that I definitely get lower fuel consumption in my Gen III. After three tanks, I am at an average (calculated) of 4.13 l/100 km. The third tank included some quite sinful :eek: driving at 120-130 km/h. My BEST single tank in the Gen II was 4.06 l/100 km.
    I am not a hypermiler. I just put my cruise control at 96-98 km/h on the highway, and look ahead as far as possible to maximize glide opportunities. In city driving I try P & G, but I have no scangauge or any other add-on, so I am probably doing it all wrong. I drove my Gen II in exactly the same way.
  12. anne1965
    131
    I
    I thought the glide was when you have no bar in the HSI (meaning: no regen bar to the left or propulsion bar to the right).
  13. a64pilot
    771
    62
    Albany Ga.
    Me too
    My Autotap won't work with the Prius, I'll have to upgrade it. I'll do that next month. With it I should be able to tell a whole lot of what's going on under the hood I'm afraid the Gen III may be a better car, but may have made some compromises in fuel consumption to get there.
    Maybe Gen 3.5 will be better:) I assume the plug in won't be a whole new Gen?
    I do expect a pure electric vehicle in the future, maybe with onboard re-charge capability, that would be the volt though wouldn't it:D
  14. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    In addition to what others have pointed out about mileage, I'd say that the Gen III "concessions to the general public" were necessary. They fixed issues ranging from less-than-succesful emissions experiments (gas tank bladder, thermos) to poor handling and poor seating (both the seats themselves and rear seat headroom), etc.
    If there were no Gen III, I probably would not have bought a Prius. I never drove a Gen II, but from everything I've read ,the Gen III moved the Prius from "quirky with great strengths" to "simply great".
  15. MikeDS
    MikeDS Member
    298
    Los Angeles
    I didn't own a Gen II, but I have agood friend who did, and I drove and rode in the car a lot. I always liked it....to me the Gen III is a way better car in look, feel, and all around experience. I live in hilly partso of So-Cal, so its hard for me to consistently get high MPG, but I'm still averaging over 50mpg in the 1000 miles I've owned the car.
  16. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    The 3'rd gen is clearly a more efficient car due to upgrades in the power control electronics and gas engine. The highway improvement is easiest to see but in the city its still more efficient if driven AT THE SAME SPEEDS as a 2'nd gen. The bigger 1.8l engine make it harder to keep the driving as easy in the city for some because now there is more power available.
  17. msirach
    msirach Member
    321
    Southern Illinois
    You are right about the GenII versus GenIII. If you are used to getting mega mileage out of a GenII, the Gen III won't achieve the same level. If you are a driver that gets near EPA average it will show some improvement.
    Overall, I prefer the added "creature features" of the GenIII.
  18. fuzzy1
    10,575
    It was in this thread, but an admin purged the bubbling flame war. Notice the 4 day gap between posts #7 and #8.
    A post in that thread contains a link to CMPG with extensive reviews from the hypermiling viewpoint.
  19. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    How many miles and what type of roads did you get that over in the GenII? (Did you get to run a tank through it so you could do an actual calculation?) More importantly what was the weather like? Were you needing AC or heat? The Gen II is sensitive to outside temps. Mileage rises with temp, until about the point you seriously need some AC. AC use doesn't have much effect on the open road, but in town it can quickly dent your averages.
    Good luck with the service dept. in Albany, they lied to me repeatedly, didn't properly repair my truck, and wouldn't honor their own warranty--worst experience I've ever had with a service dept. My advice is to take it to Tifton or anywhere else for service. Edit: Because of the local dealer I would never have bought another Toyota if I was living in Albany, and no, that is not an exaggeration.
  20. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Yes, that is the glide. Sometimes people confuse it with the stealth which is when you are powering the car solely on battery.
    I unscientifically track weather temps with tank averages, you can clearly see a direct correlation.
    Yeah, sorry 'bout that (not really). The flamewar did get out of hand and was doing no one any good. If anything, it was causing some really bad vibes among established and respected long-term members. I pruned it.
