Question about synthetic oil and warranty
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tredstone, Aug 26, 2009.
  1. tredstone
    tredstone New Member
    116
    Queens, NY
    If you put synthetic oil in your car, you should be able to go about 10,000 miles before your next oil change, right? I'm wondering if Toyota can void your warranty in cases of engine trouble if you change your oil every 10k instead of 5k miles? (e.g. do they insist you still make 5k oil changes whether or not you use synthetic)
  2. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    If there is no sludge buildup, they have no case. Just say you change it yourself every 5K and don't keep detailed records.
  3. dogfriend
    7,512
    1,190
    Carmichael, CA
    In the Owner's Manual and Warranty Booklet, they make no distinction between using dino or syn oil. They only provide the min spec and grade for use. Therefore, to comply with the warranty requirements you still should follow the 5000 mi / 6 mo (whichever occurs first) interval.
    If you really want to extend to 10k OCI (oil change interval), then you could also have UOA (used oil analysis) performed to verify that the oil is still working properly at 10k. This would give you independent proof that the oil is not the issue if you had a engine failure while in warranty.
  4. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    It would probably be a good idea to change every 5k miles anyway, or at least get a UOA as mentioned. I use Mobil 1 full synthetic, change every 5k miles since it's so easy and don't need any warranty hassles. However, I often wonder how the Toyota oil filter holds up after 5k miles, hence the UOA.
