Too many standards rant
Discussion in 'Fred's House of Pancakes' started by qbee42, Aug 27, 2009.
  1. qbee42
    3,079
    This is another one of my technical rants, or to be technical, a rant about technical issues. :eek:
    I just purchased a new Katadyn filter for my sailboat. I use a Katadyn ceramic filter to make the lake water microbiologically safe for drinking. For the past few years I've used a small one cobbled together from a small expedition filter. It worked okay, but it wasn't really designed for permanent installation and eventually the plastic fatigued at the tubing connection. Since it worked well, I decided to do a professional installation using a larger and more robust Katadyn filter.
    The new filter features a stainless steel threaded fitting on the end, used for mounting and water flow of the filtered water. I could tell by inspection that is wasn't a tapered fitting, so I knew it wasn't normal pipe thread. Katadyn is a Swiss company, so my first assumption was metric threads. I tried all of my metric nuts and none fit. I shrugged my shoulders and reached for my English fasteners. None of them fit. "What the frak kind of fitting is this?" I mumbled, while looking for my collection of thread gauges. I went through all of the metric and all of the English gauges and came up blank. Jumping Jesus Christ on a pogo stick, plumbing isn't supposed to be this hard.
    My next tactic was to drag out the calipers and measure the darn thing: 1/4" x 19 TPI. What sort of a fastener is that? Imagine my surprise when I discovered yet another standard: 1/4" x 19 TPI is 1/4" BSP, or British Standard Pipe. In particular, this fitting is 1/4 BSPP, or British Standard Pipe Parallel, which means the threads are not tapered as with NSP. I ordered a tap, knowing no hardware store within 100 miles would have one.
    :mmph:
    I now see that BSP is used in a number of areas, including hydraulic fittings. I probably should have gone to the tractor supply store. Bother.
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    We have TONS of fun when our American engineers are working with our Swiss engineers! For laughs we throw in some Germans and Italians. It's a blast!!
    Ok, it's not as bad as all that, but even though we all work for the same company, we do still trip from time to time. We laugh and get over it.
    Right now, I'm leading a team to develop a training curriculum. The team is two Americans, two Swiss and an Italian. We pilot in Asia Pacific. What could possibly go wrong?
  3. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    british standard pipe, huh? Does that have Whitworth size
    hexes on the outside too?
    _H*
  4. qbee42
    3,079
    <grin>
  5. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    The great thing about standards is you have so many to choose from!
  6. qbee42
    3,079
    :frusty:
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My advice to you is to strongly consider heavy drinking. Then throw a match to the boat.
    That's an easier and cheaper alternative to figuring out all the "standards" you're now immersed in
    Having done consulting engineering literally all over the world, I will agree that "standard" is more a matter of perspective, than a *true* standard. When in Rome, you do as the Romans do, period
    Did I ever mention that BACNet = :sick:??
    Though I still can't wrap my head around a Swiss made water filter using obscure BSPP threads
  8. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    And then there's JAVA, the write once, debug everywhere computer language.:spider:
  9. Scummer
    Scummer Eh?
    174
    29
    Munster, IN
    Metric! Nothing else matters. :D
  10. RobH
    RobH Senior Member
    2,385
    991
    70
    If metric were the ultimate answer, then you could put Italian parts on a French bicycle. About all the Italian and French parts have in common is the ruler used to describe the part. The numbers are still different.
  11. TonyPSchaefer
    14,816
    2,499
    66
    You should see what the Swiss do to BACnet! :D
    Just kidding, my loving and merciful masters.
  12. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    But if there was only one standard, how would people know it's the right one? Isn't it better to try a few first? ;)
  13. patsparks
    10,664
    567
    Adelaide South Australia
    BSP has been around like for EVER!
    BSP is the plumbing standard in Australia I think and as you say a lot of hydralic stuff is BSP.
  14. qbee42
    3,079
    The legacy of Great Briton continues.
    When I did a Google search for BSP parts, I got lots of hits for British websites, and a number of hits for hydraulic parts. I have a machine shop, and now that I have a 1/4" BSPP tap I'm in good shape.
    You have to love these projects where you spend six times as long assembling the parts as actually building anything. Now my problem is that I need a short piece of 2 1/2" schedule 40 PVC pipe. All of the big box stores carry 1 1/4", 1 1/2", 2", 3", and 4". They skip the 2 1/2" as it isn't commonly used. I'm going to have to make a trip to Traverse City during business hours to visit a proper plumbing supply shop.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    You forgot to do this:
    :hail:
    It's fun to get Swiss and Italians together at a party. Even though Italian is one of the three official languages of Switzerland, you sure wouldn't know that fact, at the party.
    Yes, it is. Since the confusion will cause you to engage in heavy drinking, then you will forget about whatever seemed so important at the time, and all will be well again
    Never caught on here, with the exception of hydraulic fittings. First time I tried to make my own hose and fittings, I had plenty of "Wth?" moments. Fortunately, heavy drinking solved those moments
    It's not too late to throw a match to the boat
