I visably damaged the underside of the front bumper of my brand new 2010 prius! Help!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bhpgold, Aug 18, 2009.
  1. bhpgold
    bhpgold New Member
    MA
    I
    Help! :eek:I just got my new blue 2010 prius and visably scraped the underside of my front bumper on the curb as I was trying to park! I am use to driving an Expedition and not a car with a low front. I am sick over what I did and am trying to find a way to hide the damage (plastic all scraped up) or find a way to repair what I did. Anyone have any ideas of what to do and the cost? Thanks!
  2. jwarrenjg
    jwarrenjg New Member
    27
    los angeles
    that depends how big the damage is..same thing happen to my car at the same location but is like 5cm long only so i order a touch up paint at the dealer and maybe buy a wet paper and do it myself. that small damage 'cause 200-300 to repair i called multiple body shops already here in LA and they all want to rip me off so i decided to just do it myself
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    If you can't normally see it, leave it (or cover with touch up paint yourself) for it might happen again.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Providing pix would make it easier for folks to see the extent of the damage and provide responses.
  5. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I would suggest as the other posts to use touch up on the bumper area. It depends on how much is damaged. You can have it factory new again for a couple hundred (200-300) where they will finish and paint it. I had it happen on my 2007 Civic. I drove my new prius today before delivery (Friday 8/21) and was CAREFUL to not hit the parking lot concrete stops. Once you get used to it you should do better. But may want to wait a few weeks until you get the handle on parking and distance to the bumper area...Then get it repaired if it's really annoying. It's done in the Dealer Paint/Body shop.
    Good Luck! :)
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    It's plastic. All those parts are going to get some degree of
    banged up over the car's life; I realize it's difficult with
    a new one but hopefully from the standpoint of a few years out
    you could see yourself saying "yeah, whatever".
    _H*
  7. MarvHein
    MarvHein Junior Member
    63
    Las Vegas, NV
    In my first week, I was often either three feet away from the curb or on top of it (usually the former). I did lightly scrape a high curb, but was moving very slowly and was lucky to back off at first scrape with no visible damage.
    After that, I installed a backup-sensor kit wired to my highbeam switch with the sensors on the lower grille. Easy to Google for these under $100. Installed in about 15 minutes with the controller under the hood near the fuse box. One wire to ground, one wire to a highbeam lamp fuse in the box. Ran the display cable into the cabin and put the distance display/beeper in the little space between the steering column and the dash. Now I park 6 inches from the curb everytime.
    Good luck with your repair.
  8. NoMoShocks
    1,292
    83
    Camas, WA
    I found this happening to me so often it wasn't funny. The prius is Really Really low in front, and I am not used to that. All my other cars fit up over most curbs, allowing my car's posterior to get further out of harm's way.
    What I have found works well for me is to find a reference point within your interior that from your seating position, indicates about six inches back from the curb. For me, it is the second louver in the left hand AC vent. As long as I line that up with the curb outside as indicated by yellow arrows in picture, no problems. Angle parking is a differnt story.
    [​IMG][/IMG]
  9. Blizzy
    Blizzy Junior Member
    Sacramento, Ca
    I did the same exact thing, had less than 100 miles on it. Pulled into my first angle parking, and heard that horrible noise. Went to the dealer, got a bottle of touch up, had the local body/fender guy do it for $25.00. He did three coats, and it was well worth the $25.00. He said because the rubber was exposed, he put a primer on it, before he painted it.
  10. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Bummer. I came from a car with an even lower front end than the Prius so I haven't had an issue with this so far. Always a chance I'll lose concentration pulling into a space and crunch. On the positive side plastic doesn't rust so it is strictly cosmetic damage that allows you to ignore it or delay repairing it without risk.
  11. MarvHein
    63
    Las Vegas, NV
