Hit a high curb and dented lower door panel -what will it cost to fix?
Discussion in 'Gen 3 Prius Main Forum' started by nemrut, Aug 31, 2009.
  1. nemrut
    nemrut New Member
    57
    san francisco
    So i hit a neighbors excessively high driveway curb trying to make room for another car coming in the opposite direction and this is the result:
    Any guesses as to what it might cost to fix? the bottom part is plastic so that should be easy but the door...oh the horror. I keep reminding myself life happens and it's just a car.
  2. kaptmorgan
    kaptmorgan Junior Member
    33
    marietta Pa
    Around $500.00:mad:
  3. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    That lower rocker panel is not plastic, at least not on my Prius V, it seems like it would be aluminum. I was quoted about $500 to have it replaced, and painted to match. Luckily, in my case, the door has no damage. If you need to get that repaired, I would assume it would potentially cost a few hundred more, depending upon whether the scratches there break the paint, etc.
    Please keep us posted, so that we all know what these repairs cost.
  4. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    It doesn't look like there's any break in the paint on the lower rocker panel so you can buff them out to make them unnoticeable. However, you're stuck with fixing the door or learn to live with it. It's not that bad.
