2010 making funny noise's
Discussion in 'Gen 3 Prius Main Forum' started by beauimoto, Aug 31, 2009.
  1. beauimoto
    beauimoto New Member
    Vancouver
    Does anyone have issues with the car making a light screeching noise when you apply the gas or brake? It's like 2 pieces of metal rubbing together for a faint noise, also loud sometimes as well???
    Thanks a lot
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Can't say I have heard that... how many miles/km on the car? How long have you heard it?
    If it was just the brake pedal I would like it was the calipers.
    Peter
  3. beauimoto
    Vancouver
    3000 kms and only 1 month old. Heard it about a week after I picked it up
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's the regenerative braking noise.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Why would you hear it when you apply the gas if it is regen?
  6. qbee42
    3,079
    :pound:
    Sorry, I was just laughing at that funny noise.
  7. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Just the brakes. do not know what it is when gas is applied so maybe it's something else.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    There might be some linkages rubbing. If it is reproduceable on demand, take it in to the dealer for a look-see. If not, wait till something blows up and then take it in. YMMV,
    Peter
  9. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    Throttle is "Drive by Wire", NO linkage.
    David (aka Blind guy)
  10. SF Prius
    SF Prius New Member
    San Francisco, CA
    I've noticed something when going up a hill. Sounds like a rough engine noise.
  11. tiztim
    tiztim Junior Member
    49
    Chicago
    I believe that's what happens after a rain storm on your parked car: the disc oxidizes (rusts) quickly on exposure to water. This is normal as the steel is formulated for abrasion resistance, high temps and maintaining temper. Oxidation is unavoidable with this particular formulation.
    After a rain and rust to the disc, you'll hear a gentle grinding sound when your brake pads connect with the discs. The sound you hear is the pads clearing rust from the discs.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Maybe he's referring to the electrical whines when you accelerate, esp. in EV mode (when the ICE isn't on to drown out the whines) and the whines during regen?
    To the OP: If you have sufficient charge and are stopped or at low speeds, push the EV mode button and accelerate w/the windows down. Do you hear electrical whines not unlike a subway or electric streetcar?
    Also, what if you brake while in neutral? There should be no regen in neutral and you should be relying on the friction brakes alone.
  13. beauimoto
    Vancouver
    I heard the same noise on other 2010 I saw driving down the road but it still makes a loud squeal so off to the dealer it goes.....
