I've finally found the secret to increase mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by wintechsw, Aug 16, 2009.
  1. wintechsw
    wintechsw Junior Member
    36
    Vic Australia
    Background: 1. My experience is 31000km in a base II model with Lifetime Average of 20.4 km/litre or 57.5 mpg(Imperial) in Oz, mainly long distance driving at 110kph speeds on Cruise Control uphill downdale. That's 48mpg for US measuring. 2. I have a ScanGuage II installed and have one of 4 settings to display LOD which is the engine loading. My observations are that the consumption falls dramatically when the LOD is 79 or greater. So my key to Economical motoring is to keep the LOD figure below 79 at the maximum speedo reading. 3. I went for a 330km trip yesterday over fairly flat terrain, sat on 110kph(113 on the speedo) and averaged 5.2l/100km. On my return trip, after refuelling, I set my speedo at 106(actual 104kph) and the consumption average dropped to 4.7l/100km. The LOD stayed below 79 for most of the way, occassionally going over that figure for uphill gradients. 4. Coincidentally the displayed engine RPM stayed below 2000rpm whilst the LOD was below 79(not a surprising fact), but it still fluctuated wildly for level running. At 110kph, the RPM varies greatly from 2100rpm to 2500 rpm at every SGII refresh.
    My maximum freeway speed will now be set at Cruise Control 106kph.
  2. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    What you have discovered is that aerodynamic drag increases exponentially as your speed increases. At 106kph, you have not yet found the sweet spot. Try 88kph. You will be amazed.:D
  3. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    Krousdb is right. You are also correct that the engine is most efficient when working under certain load; Try to read this very interesting article by Hobbit:
    Prius throttle control
    If 88km/h is sufficient for you, you will get amazing results at that speed (assuming flat ground, no wind). Your consumption at that speed can get as low as about 3.2-3.5l/100km average, sometimes even lower. I regularly manage to repeat that feat when traveling some 55km at that speed on the highway from my apartment to my parents' house. I also try to travel behind a large truck if possible, in order to try to reduce air resistance. Of course, I always keep a safe distance behind him, which compromises the efficiency a lot, but safety should always be at the first place.
    Using this technique and well-known hypermiling tricks in the city, I regularly get 4.2l/100km per tank, including short commuting trips through the city, which are a real consumption killer. You can get significantly better than that if you can avoid short trips, which I, alas, cannot.
  4. wintechsw
    36
    Vic Australia
    Yes I agree the consumption mpg increases with reduced speed, but the tradeoff is the time difference for the trip which is from 7 mins to 45 mins of increased travelling time.
  5. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Agreed. We all have to make that decision. I would save 20 minutes a day if I increased my speed to 106kph. But saving 20 minutes does not mean that I will earn more money. It just means that I have some spare time on my hands. My choice is to give up some spare time so that I can spend less of my hard earned money supporting OPEC. It works for me.:D
  6. JimStPete
    JimStPete New Member
    Clearwater FL
    :usa2::usa2::usa2:
  7. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi wintechsw,
    You have rediscovered SHM - Super Highway Mode. Do a search on SHM here, and on CleanMPG.com for complete details.
  8. richardp
    richardp New Member
    New Port Richey, Florida
    What's a ScanGuage II ?
  9. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
  10. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    The biggest difference I've seen in the last few tanks of gas is due to the fact that I've held the accelerator steady on the highway, don't use cruise, let the car speed up and slow down as appropriate (I keep it at 5.0 or lower, thus speed is around 100 km/h).
    I saw an increase in economy from 5.4 - 5.7 down to 4.8 - 5.1 L/100km. Give that some thought, just focus on keeping your consumption on the highway below 5.0 and don't worry as much about the speed.
  11. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    Yes, I second that. Keep throttle SOLID without bouncing the pedal. If you have a ScanGauge you can program it with a "gas pedal pressure" gauge that will help you control your right foot. When you see the read-out you'll be amazed how much most people bounce the throttle without even realizing it, and Cruise Control is practically a "random throttle generator". Not good for MPG.
    11011011
  12. namasteflc
    namasteflc New Member
    47
    Georgetown Md
    Back in the good old days, some vehicles had 'hand throttles' that held the accelerator; an early form of cruise control.
    Frank
  13. eagsc7
    eagsc7 Geocacher
    Prescott, AZ
    ... 45 Minutes IF you are driving Over 400 Miles Per Trip. Yes, I did the math.
    Most people will Think that they are Saving time by driving faster... I have found out that 1 or 2 Stoplights WILL take out All the time that you save by driving faster. Yes, this HAS been tested by three vehicles at the same time. the First vehicle had a speed of 70, The second had a speed between 63 and 68, the Third was mine that I set Cruise control at 55. I caught up with the Second vehicle at the First stoplight, and the First at the Third stoplight... The total drive distance for this test was 58.2 miles.
    Oh, and As for anyone that asks..."What kind of Miles per Tank will driving 55 instad of 65 do?" That test I have also done in a rather fun manner. Both were done in the Same weather conditions, and over the same driving area. Driving 55, I got 630 Miles before the car gave the traditional Triangle of Death! Driving at 65, I only 470 Miles before the same triangle. This would be obvious for me to say that YES, I filled the tank to the same 11.85 Gallons both times(this is where you can actually SEE the fuel in the inlet).
    The Steaks
