Tank MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by Indyking, Sep 10, 2009.
  1. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Surprisingly, I could not find any threads on Tank MPG for gen 3. Most of what is posted regards to short trip MPGs, which has little value in my opinion, because often circumstances are optimized for enhanced fuel efficiency. So, to address that need, I decided to open this thread.
    I got impressive 61.1 MPG in my last tank after driving 513 miles! There was just one pip left on the fuel indicator.
    Weather was mostly dry (rain can have a negative impact) with temperatures between 50's and low 80's (it's the Midwest, what do you expect?). Winds variable but often calm and humidity normal to high (60-90%) (Winds can definitely have an impact but not sure about air density).
    Driving on ECO mode all the time, AC on 76-78 F for about 50% of the time, 70% city driving.
    I was consistently getting 57-58 MPG but boosted it up to above 60 by just changing my commute route a little bit. Now, I’m leaving a bit earlier and driving on the back roads.
  2. qbee42
    3,079
    What is the tank MPG for an M1 Abrams?
  3. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    300 miles at .6 MPG:D
    M1 Abrams Main Battle Tank
    Specifications
    M1 / IPM1 M1A1 M1A2
    Manufacturer General Dynamics (Land Systems Division)
    Crew 4: Commander, Gunner, Loader & Driver
    Weight 60 Tons 63 Tons 69.54 Tons
    Length (Gun Forward) 384.5 inches 387 inches
    Turret Height 93.5 inches
    Width 143.8 inches 144 inches
    Ground Clearance 19 inches
    Ground Pressure 13.1 PSI 13.8 PSI 15.4 PSI
    Obstacle Crossing 49 inches 42 inches
    Vertical Trench 9 Feet
    Power plant AGT-1500 turbine engine
    Power Rating 1500 HP
    Power to Weight Ratio 25 hp/ton 23.8 hp/ton 21.6 hp/ton
    Hydro Kinetic Transmission 4 Speed Forward
    2 Speed Reverse
    Speed - Maximum 45 mph (Governed) 42 mph (Governed)
    Speed - Cross Country 30 mph
    Speed - 10% Slope 20 mph 17 mph
    Speed - 60% Slope 4.5 mph 4.1 mph
    Acceleration
    (0 to 20 mph) 7 Seconds 7.2 Seconds
    Fuel Capacity 498 gal (1,885 liters) / 505 gal (1,907 liters)
    Cruising Range 275 Miles 265 Miles
    Fuel Consumption A tank will need approximately 300 gallons every eight hours; this will vary depending on mission, terrain, and weather. A single tank takes 10 minutes to refuel. Refueling and rearming of a tank platoon--four tanks--is approximately 30 minutes under ideal conditions.
    0.6 miles per gallon.
    60 gallons per hour when traveling cross-country
    30+ gallons per hour while operating at a tactical ideal
    10 gallons basic idle
    A mine plow will increase the fuel consummation rate of a tank by 25 percent
    Main Armament 105mm M68A1
    Rifled Cannon 120mm M256
    Smooth Bore Cannon
    Commander's Weapon .50 Cal M2 Machinegun
    Coaxial Weapon 7.62 M240 Machinegun
    Loader's Weapon 7.62 M240 Machinegun on Skate Mount
    Basic Load Main Gun 40 rounds (M1A2 42 rounds)
    Commander's 50 Caliber MG 1,000 rounds
    M240 7.62 MG (COAX)/Loader's M240 MG 10,800 rounds
    Smoke Grenades 24 rounds
    NBC System 200 SCFM - CleanCooled Air
    Inventory US Army 4,393 586 M1A2
    588 M1A2 SEP
    Inventory USMC 403
    Inventory Other 777 Egypt 315 Saudi Arabia
    218 Kuwait
    Unit Replacement Cost $4,300,000
  4. qbee42
    3,079
    Good to know. Why do you suppose Indyking was interested?
  5. a64pilot
    771
    62
    Albany Ga.
    Indyking, your right, we can all pull miracles out of a hat for short distances. My best tank MPG was 64.3 and over 700 miles. Can't take a pic because I stupidly disconnected my 12V battery when I didn't need to, so all my trip data was lost.
    Give me a week
  6. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    Even MPG over a tank is suspect, due to possible variations like overfilling, underfilling, etc. The average MPG over a few thousand miles, always filling with the same gas at the same pump will reduce the impact of those vairations.
  7. Indyking
    1,280
    No picture... all false information until proven otherwise...
    :D:D:D
  8. Indyking
    1,280
    Hey clows, I'm careless about bloody M1 Abrams...
  9. qbee42
    3,079
    Here is a picture:
  10. Indyking
    1,280
    Agree, but tank MPG is a lot better than "Hey fools, I got 90MPG", of course, the hidden part is: after a short trip downhill as many are reporting here...
    Just as a FYI, my lifetime MPG is 57.8 after 3968 miles at 35 MPH.
    My lifetime is going up after every tank now, it used to be 54!; however, it will start to drive down in few days as my new commute will change to 95% hwy, 5% city driving :(
  11. Indyking
    1,280
    Men, you're funny... what a fool...
  12. Indyking
    1,280
    Here's why we should all remain skeptical without further evidence:
    Gen 3 Prius tank capacity: 11.9 gallons
    Your claimed tank MPG: 64.3
    First grade math: 11.9 x 64.3 = 765.17 miles
    We all know that the MID in gen 3 is too optimistic for their estimated MPG, so adjusting your numbers according to Bob's data:
    (64.3x 0.85) + 4.3 = 58.955 for calculated "real" MPG. Let's round it up to 59 and redo the math:
    First grade math: 11.9 x 59 = 702.1!
    Conclusion: We must remain extremelly skeptical…
    :D:):D:cool::eek:
  13. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    My best "tank" MPG? 61.3 for 503.8 miles at 26mph.
    Other "bests" are shown in my signature, below, as well as my lifetime numbers for City, Highway and Overall. At 7,081 on the odometer, yesterday, my lifetime fuel economy (from the MID) was at 56.8MPG. The total calculated fuel economy, for 15 tanks, is at 54.1MPG.
    My mileage has taken a "hit" lately, as I've been taking my new Prius to the body shop a bit too often.
    (Ref.: Again!! Second Prius to be Hit -- Back to the Same Repair Shop, I Guess and Again & Again!! Third Time to be Hit in Four Months -- Back to the Same Repair Shop . . Again!)
  14. Indyking
    1,280
    Very nice, you beat my best "tank" MPG by 0.2! :)
    The explanation may be your average speed was 26 mph vs 31 (mine).
    Just curious, how are you calculating your lifetime combined mileage? I'm not sure what the best way to do it is...
  15. hill
    8,903
    Nice! keep up the good stats, and hurry up with the first Gen III 700mile per tank. I still remember how jazzed I was about doing my 1st 700 mile tank. Immediatly I was encouraged to shoot for an 800 mile tank. whew! that tough! ... still workin' on it ... but it's closin' in ;)
  16. a priori
    3,083
    408
    Chicagoland (West)
    hill, you are the MAN, and I will never reach your numbers. I just don't have the commute for it. My daily drive kills my mileage, and the only way I get really good numbers is when I am doing long drives to out-of-the-way places. I get a few of those trips each year, but only one of those, typically, will be long enough to give me a tank's worth of gas. If that trip is in the late spring or early fall, when A/C use is lower, then I may have a shot at a high tank. BUT, I also need to start the tank early in that trip, otherwise I just get two tanks with little increases!
    Think about this: My most recent fill showed a tank at 54.0MPGs at 483.0 miles (20mph). This tank covered 26 days, and the last 93 miles were in one day. That means the previous 390 miles happened across 25 days -- fewer than 16 miles per day. Now a good week of that was while the car was in the shop for repairs, but think of the great mileage it was getting at the hands of those folks. Can you imagine what it got during the test drives and moving it around the yard? Eck!
  17. Indyking
    1,280
    What? Your numbers are right there in the high end of what has been reported here and there (above average)... Your commute may not be the ideal but you're doing a great job!
  18. a priori
    3,083
    408
    Chicagoland (West)
    Don't worry, you'll be getting better tanks along the way. I expect you'll pass me by soon enough!
    For calculation of lifetime combined mileage, I divide the total miles by the total gallons. When it comes to using the MID info to do this calculation, I simply determine the gallons used (according to the car's calculations) by taking the MID's displayed miles and dividing it by the MID's displayed miles per gallon: Miles/(miles/gallon) = gallons.
    I don't know how other folks do it, but I've been a bit worried that people simply take ten MPG readings, add them up and divide by 10. If each MPG reading was for the same number of miles, then there would be no error. If the MPG readings were all for tank fills, and each tank fill was pretty darn close to the same mileage each time, then the error would be fairly small.
  19. qbee42
    3,079
    I take my best single segment mileage and claim it as my mileage. It has no basis in reality or accuracy, but it feels good. Besides, always remember that you can hit Reset if your tank mileage looks too bad. :D
  20. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Pictures!!
    Wayne
