What tires did you get on your 2010?
Discussion in 'Gen 3 Prius Main Forum' started by Danny, May 20, 2009.
  1. blackeyed-P
    blackeyed-P New Member
    San Diego
    2010 Prius II Yokohama Avid S33 on 15" wheels
  2. Pohaku
    Pohaku Member
    143
    twin cities
    Prius II Yokohama 15" wheels. Minnesota.
  3. thothWiz
    thothWiz Junior Member
    29
    Boston Metro
    2010 Prius III Yokohama Avid S33. Massachusetts
  4. jandrgold
    jandrgold New Member
    Denver
    Prius IV Solar - Yokohama Avid S33
  5. Terpen
    Terpen New Member
    Tejas
    Bridgestone EP20 East Texas
    Looks about as random and useful as determining which colors go where.
  6. sundevil
    sundevil New Member
    34
    Gilbert, AZ
    Picked it up today in Arizona.
    Prius II - Bridgestone Ecopia EP20
  7. RenePri
    RenePri New Member
    Southwest Ohio
    Got from a dealer in the Dayton, Ohio area.
  8. MataOrtiz
    MataOrtiz Junior Member
    49
    Prius IV Solar
    Bridgestone (there's only one model, it seems)
  9. hgdempsey
    hgdempsey New Member
    Puyallup, Wa
    2010 Model III with Solar Moon Roof/Nav
    Yokohama Avid S33
  10. PrivateJet68
    PrivateJet68 New Member
    New England
    2010 Prius III Yokohama Avid S33. MA/NH
  11. nieveser
    nieveser Junior Member
    32
    Portland MI
    got it yesterday; 2010 Prius V, Michelin Pilot HX MXM4 in Michigan
  12. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    My car came with Yokohama Avid tires which I just replaced after 10,982 miles with Michelin Energy Saver AS tires, 195 X 65 X15.
    I did notice that the Avid tires are wearing very well and one should expect 40,000 miles from these tires. Also I have run those tires and my new Michelins at 44 PSI, max sidewall pressure, on all 4 tires.
    MPG with the Yoko Avid has been very good with calculated MPG for the life of the car at about 49 MPG.
    Note: my wife drives the car most of the time when I drive it is nearly always over 50 MPG calculated.
    It seem from our 60 miles of driving or so the new Michelins are perhaps having a 1 MPG to 1.5 MPG advantage over the Yoko Avid has I would expect as this tire is supposed to be the most fuel efficient tire in the world.
    Also, one more thing before I sign off; I have been using max sidewall pressure on all my cars for years. My current 2003 VW Jetta Wagon TDI has Michelin S-8 tires with 51 Max sidewall pressure which I am currently running them.
    I have about 45,000 miles and should get at least 7,000 to 10,000 more miles out of them. They are wearing normally and not in the center has people would have you believe when you run your tires at max sidewall pressure.
    This has been my expierence.
    alfon
  13. Grateful11
    Grateful11 Member
    107
    Central, NC
    Got a Prius III on Monday with Bridgestone Ecopia EP20's on 15"s
    with Center Caps on the way.
  14. Dondoh
    Dondoh Aleatory Specialist
    96
    27
    rural hall, nc
    I got my Prius II today in NC and it was shod with Yoko Avids.
  15. TracyJ
    TracyJ Junior Member
    39
    Atlanta, GA
    I just got mine today and she came with the Yokohama Avids also. My dealer threw in the wheel center caps for free but they were not in stock. I go back Wed for them.
  16. JkRbbt
    JkRbbt New Member
    Black Hills / SD
    Toyo Proxes 215x45x17 on my V! Came out of the dealership with 43# per tire! I dropped 'er back to 38 and 37 as per several comments here on P/C!
  17. Sosigenes
    Sosigenes Junior Member
    Durham, NH
    Got my 2010 Prius V yesterday. It has P215/45R17 87V Toyo Proxes A20’s in New Hampshire. Dealer pressures were the recommended 33/32 PSI.
  18. archermoo
    archermoo New Member
    118
    Pittsburg, CA
    Picked up my V with Nav yesterday. It has the Michelin Pilot HX MXM4's.
  19. prev93
    prev93 Member
    63
    Califon, NJ
    Blizzard Pearl Prius II with Bridgestone Ecopia EP20, purchased today in Wilkes-Barre, PA.
  20. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Took delivery on 9/8/09 from Novato Toyota in California.
    Prius IV - Yokohama Avid S33
    Wouldn't it also be useful to know what the manufacture date on the car is- and what plant it was made at (assuming that they have more than one plant!)??? Seems then you could have additional data to sort by. My hunch is that they just get a bunch of tires in from different suppliers and just work their way through them...so I'll go out on a limb and say that if you were to compare them by manufacture date that you'd probably see some kind of pattern?
