Changing the Brake Pads
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vhmarx, Apr 28, 2006.
  1. vhmarx
    vhmarx New Member
    I was wondering, have any of you out there changed the brake pads on the Prius yourself?
    If so was there any additional difficulty due to the regenerative aspects of the brakes?
  2. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(vhmarx @ Apr 28 2006, 01:14 PM) [snapback]246818[/snapback]</div>
    I have not done it or had it done. I just got to 30k and the mechanic was amazed at how little ware there was. The friction brake pads are just that you do not need to mess with the regenerative part of it at all.
  3. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    oh we will change them ourselves... in about 10 years. ;)
    the "additional difficulty" from the regen brakes is trying to wear the brake pads down enough to need to change them!
  4. 200Volts
    200Volts Member
    434
    45
    Northern CA
    80k miles on my 04, just had brakes inspected by dealer, All OK.
  5. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    The regenerative aspects all happen before it gets to the pads. The pads are only used at under about 9 MPH or in a panic situation. They are standard pads and easy to change. I plan to begin looking into new pads at around 100,000 miles.
  6. rick57
    rick57 Member
    572
    Circleville, Ohio
    The procedure is the same as any car with front disc brakes. I have only replaced a few sets and they were on the 1st Gen models( have yet to see any probs with the 2nd Gens). Suprisingly it is around 70-80k that they needed replaced. Not because they were worn but because the pad had dislocated from the metal backing plate. Thickness was still about 7-8mm. Must have used some poor glue on those, :lol: .
  7. genalex
    genalex Member
    265
    Jersey suburbs of Phila.
    <div class='quotetop'>QUOTE(200Volts @ Apr 28 2006, 07:10 PM) [snapback]246891[/snapback]</div>
    One Toyota salesman I talked to claimed the brakes would go for 200k miles, since they see so little wear.
  8. dacrecc
    dacrecc New Member
    Boulder CO,
    My 2005 has 103K, and Dealer said all is OK. Which I take to mean more than 50% left.
  9. jdenenberg
    jdenenberg EE Professor
    3,921
    1,919
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius brakes are at 158,000 and counting. 200k life is a reasonable estimate.
    If you DIY the pads, just be careful not to open the hydraulic lines since you need a special computer tool to bleed the brakes properly.
    Jeffd
  10. ragman
    ragman New Member
    25
    Chichester, NH
    I've heard and read on this site 2 different things. One says you have to wait 2 minutes from power down to compress a caliper because you have to wait for the ecu to power down. The other referred to the braking power backup taking 5 mins from shutdown to discharge...
  11. jonathonp
    jonathonp New Member
    New Jersey
    I have a 2004 Prius with 78k miles on it. Bought it used and seemed to be fine. Took it to have the tires rotated and balanced, change oil, and alignment. They told me my front brake pads needed to be replaced and that that the rotors needed to be replaced. Does this happen on a Prius with 78k? According to the previous posts, the brake pads are rarely replaced on them and should last a long time.
  12. qbee42
    3,076
    It's possible. Brake wear is a function of miles, driving style, conditions, and time. Brakes rust away with time even if not used.
  13. jonathonp
    New Jersey
    Thanks. they want to use ceramic pads. the forums I've seen say say stay away from them because of squeaks, and use OEM pads. Is that true or just a rare case?
  14. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    What I wouldn't worry about is paying extra for ones that wear more slowly... whichever ones you put in will last longer than the car has left.
  15. qbee42
    3,076
    Use the OEM pads.
  16. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
  17. didnotwantaprius
    didnotwantaprius New Member
    Brick, New Jersey
    well i did it i changed my front break pads and made the tragic error of bleeding the lines the old fashoned way by placeing my check valve in fluid and pumping new fluid through lines, now i've got a christmas tree on my dashboard.
    I hate to say it but car is going to dealer i hope it is not broken.
    if any one has done this let me know thanks
    didnotwantaprious
  18. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    how in the world would you have needed new pads on a 2008 already
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Nothing is permanently broken, but if you go to the post I linked, and download that section from the factory shop manual, you will learn that the Prius brakes can NOT be bled the old fashioned way
    At the dealership, they will use their Panasonic Toughbook scantool to run the car through the proper brake bleed procedure. The brakes should be fine afterwards
    Do not attempt to drive the car, have it towed. You won't have any brakes
  20. uart
    uart Senior Member
    4,220
    1,209
    Australia
    You've probably already got this fixed, but anyway I saw this in another thread where someone posted a fairly simple procedure for clearing those error codes.
    See : http://priuschat.com/forums/gen-ii-...ar-dtc-when-not-using-intelligent-tester.html
