2010 II 12 Volt Battery Dead After 17 Days of Parking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by [email protected], Sep 10, 2009.
  1. indianapens@msn.com
    [email protected] New Member
    Indiana
    Left my 2010 Prius II at a parking facility in Chicago for just over two weeks. Upon return, the 12 volt battery was completely dead. After a $50 jump start, returned the car to the dealership for assistance. Their report:"everything is fine and this is common for the Prius as there are numerous computers that are running as well as SKS". BTW, SKS can not be easily turned on and off in the 2010 series.
    According to the dealer, Toyota's position is that anything over 10 days of storage with no driver activity will result in a discharged 12 volt battery. Both the dealer and I looked in the owner's manual and could find nothing describing this situation, but apparently they have a service bulletin that covers it.
    One possible solution when parking the car for an extended period is to disconnect a lead from the battery but that would require me to climb through the back seat area and manually open the hatch door to gain access to the battery to reconnect the lead. Another idea would be to pull a small fuse called the "short pin" located in the center of the main fuse box. Both ideas are rather cumbersome to say the least.
    Anyone have any other ideas?
    2 people like this.
  2. Vaughn
    Vaughn Junior Member
    37
    Lubbock TX
    I don't have the owners manual with me but if I'm not mistaken the switch next to the tire pressure reset switch may serve to turn SKS off.
  3. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    That's very interesting. I'm worried about this.. Anyone have any tips on how to improve the 12V battery's storage/life capacity while in storage for quite some time? Also, can I use a "battery pack" jump started to jump start the prius? I have one of those, and not jumper cables that hook to another actual car. the "battery pack" has + and - terminals. I assume I'd hook the + on the jump start location and the - on the chassis and try to start like normal eh?
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    I don't think so, that button turns off the pre-collision system in ATP cars. The Gen2 has a switch to disable the SKS but for some reason they eliminated it on the Gen3.
  5. DavidA
    2,343
    1,819
    Chicago western burbs
    no switch. That was genII cars. The III is supposed to have an automatic shut off if it sits 3+ days. It's in the manual.
  6. RodJo
    RodJo Member
    423
    56
    Boston
    How about replacing the stock batter with a higher-capacity battery? As I understand it, the Prius battery just boots the electronics so you don't have to worry about cranking amps.
    EDIT: Although moved to a Gen 2 forum, this thread (http://priuschat.com/forums/gen-ii-...-12v-battery-replacement-opinions-please.html) includes a Technical Service Bulletin for the Gen 3 that discuss what to do prior to storage and also warns about replacing the battery. You may want to read the rest of the comments.
  7. 3PriusMike
    3,097
    2,419
    Silicon Valley
    A couple of months ago I went on vacation for 14 days. Both my Gen 2 and Gen 3 started right up when I returned. The load needed to start the car is pretty small so its hard to imagine that just 17 days really drains a normal battery.
    3PriusMike
  8. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    It may sound elementary and I certainly don't mean to insult anyone's intelligence, but I'd be looking for a dome light or trunk light that was left on during the trip. There shouldn't be enough parasitic losses to drain the battery that badly in 2 weeks. As was pointed out previously, the 12V battery only has to close a contactor and boot the computer, hardly high load. So for the battery to get that flat, that quickly, it seems like it would either have to be a defective battery or some un-accounted-for power drain.
  9. indianapens@msn.com
    Indiana
    I thought that I had to have left something on too............but no! Believe me, I checked once the car was jump started and nothing was left on. Most worrying to me is Toyota's apparent position that after 10 days the battery will most probably be drained. Has anyone seen a copy of the service bulletin?
    Thanks for everyone's responses!
  10. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    I understand your position, but I have to agree that leaving something on or a defective battery are possible answers to the problem. The third is that there is something wrong with the car's "new" system of automatically disabling the SKS to prevent a battery drain.
    I would press this one much more with your dealer. If you are absolutely certain there was no light left on, you can go this route with some impunity. If you are willing to say to the dealer: "Look, I'm as positive as I can be that nothing was left on, but one never knows . . .", well then you can ask them to check both the battery quality/capacity and the auto disabling system, while still having the dealer feel like you could have caused the problem.
    Sorry, but I haven't seen an applicable TSB.
  11. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    What is SKS?
    I'm worried now. I'm planning to leave my Prius stopped and parked in Wisconsin for at least 10-15 days in December. I was planning to find a covered garage to protect it from the snow but the cold will be intense.
    Should the auto-off SKS system be enough to prevent the 12V battery from draining in that situation?
  12. a priori
    3,083
    408
    Chicagoland (West)
    I followed the link earlier provided to another thread discussing the replacement of the battery. One of the posts provided a copy of a Toyota TSB (Technical Service Bulletin) describing the activities to be undertaken to protect both the HV and auxilliary batteries during storage. Here is that TSB:
    View attachment Tech Serv Bulletin re Battery Maintenance during Storage.pdf
    For some reason I cannot understand, there is reference to a maintenance activity should the Prius be stored for 10 days or longer. It involves disconnecting a harness under the hood. Not difficult to get to, but kind of odd to do it for a 10-day storage.
    Remember, though, that this TSB addresses the handling of a brand-new Prius just delivered to the dealer and being prepped for initial delivery to a customer. It tells the dealer how to handle long-term storage and then delivery to the customer. It is not a TSB designed to address ongoing operational issues.
  13. TKY
    TKY Member
    232
    25
    Colorado
    Indyking, Smart Key System (SKS) or the key fob.
    According to my owner's manual (p.48), if the SKS entry system is not used for five days, then it disables the entry function to prevent discharging the car battery. If the entry function is not used for nine days, then the unlock function is disabled for all but the driver door, where you may need the mechanical key. This implies to me that the battery should not be dead in two weeks because the car takes preventive actions to conserve the battery. At the least, it contradicts the TSB that the battery may be dead in 10 days. --TK
  14. a priori
    3,083
    408
    Chicagoland (West)
    Smart Key System. This is what allows you to unlock or lock the doors and start or stop the hybrid system simply by having the key (key fob) in your possession.
    Yes, it SHOULD be enough to protect you. This thread, though, is all about a time when it appears the system didn't protect the owner. There is a possibility, of course, that it could have been something else that went wrong. Still, it is valuable to know what the system is supposed to do:
    This is from page 49 of the Owner's Manual:
    Battery-saving function
    In the following circumstances, the entry function is disabled in order to prevent the vehicle battery from discharging and electronic key battery from depleting.
    l When the entry function has not been used for 5 days or more
    l When the electronic key has been left within approximately 6 ft. (2 m) of the vehicle for 10 minutes or more
    l If the entry function has not been used for 9 days or more, the vehicle cannot be unlocked by a door other than the driver’s door. To unlock the vehicle, grip the driver’s door handle or use the wireless remote control or the mechanical key.
    The system will resume operation when...
    l The vehicle is locked touching the door handle lock sensor area.
    l The vehicle is locked/unlocked using the wireless remote control function (→P. 63) or the mechanical key. (→P. 541)
    5 people like this.
  15. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Dark current is the term used to describe the parasitic loads on a battery while the vehicle is not in operation. Very easy to measure, just simply disconnect the battery and have a multimeter in series with the battery with the multimeter measuring amps. Without measuring this dark current every thing is just speculation. Once you know what the load on the battery is when the vehicle is off, then you can determine battery life. And you may be able to find out what's pulling current when it shouldn't be if anything is.
    Has anything electrical been installed in the car?
  16. indianapens@msn.com
    Indiana
    NOPE! the car is just as it came from the factory with no modifications of any kind. To me, the technical bulletin T-SB-0152-09 kind of tells the story..........."To store for 10 days or more, disconnect wire harness from exclusive jump starting terminal"
  17. RodJo
    RodJo Member
    423
    56
    Boston
    I'm not sure what the difference would be. A 10-day storage at the airport shouldn't be much different than a 10-day storage at the dealer.
    That also doen't explain why it warns about replacing the battery with a regular car battery -- not something that would be done pre-delivery. Unless the dealer stores the car for years.
    But it does seem kind of silly. I'm not sure the Prius has more electronics running while off than many other cars. It seems to be just a side effect of the small battery.
  18. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    I just called the service dept. at Lompoc Toyota, where we bought our '10 II and told them we're going on vacation for 3 or 4 weeks. I asked if that would run the battery dead. He said yes it would and here is what to do: In the cargo area there is a small door that gives access to the 'small' battery. Disconnect the neg. terminal.
    I asked if we simply reconnect the battery when we return. He said, yes it should fire up, no problem. So that's what we'll try.
  19. RodJo
    RodJo Member
    423
    56
    Boston
    Isn't the problem then getting to the cargo area to reconnect the battery?
  20. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I would suggest wiring a VDC Battery Minder directly to the 12 vdc battery, like I did with my 2004 Prius. However, that doesn't do you much good if parked outside at airport long-term parking
