Which mode do you use the most?
Discussion in 'Gen 3 Prius Fuel Economy' started by pakitt, Sep 14, 2009.
  1. ECO
    63 vote(s)
    66.3%
  2. PWR
    4 vote(s)
    4.2%
  3. Normal (no mode enabled)
    22 vote(s)
    23.2%
  4. ECO city only
    1 vote(s)
    1.1%
  5. PWR city only
    1 vote(s)
    1.1%
  6. Who cares, I leave on "Normal" and enjoy the ride
    2 vote(s)
    2.1%
  7. I switch all the time between modes to (try to) achieve the best MPG
    7 vote(s)
    7.4%
Multiple votes are allowed.
  1. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Reading on several threads about the power modes and trying to get the best MPG - what is the trend among Prius drivers? does this reflect Toyota's wishes to offer different driving experiences with the different modes?
  2. Mark57
    2,945
    2,740
    OK
    I stay in ECO mode unless traffic or safety demands that I move quicker. So far I've really only needed PWR three times for short duration and they've all been on-ramps.
  3. bwilson4web
    16,195
    Although I use "ECO," mostly I maintain speed using cruise control, even in the city. Near as I can tell, none of the modes changes cruise control behavior.
  4. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    Same here, but the situation where I use power mode is changing lanes from a slow moving one to a fast-moving HOV lane.
  5. Mark57
    2,945
    2,740
    OK
    I can envision your exact scenario. We stayed in Manassas for a week last year driving back and forth into DC and the surrounding area daily. Though the traffic was heavy (fully expected), I actually enjoyed it because everyone seemed to know "how" to drive in heavy traffic. Refreshing! That's not true in many places. Now I'm hungry for Legal Seafood again.:D
  6. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    I use ECO mode all the time.
  7. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I typically use "ECO" mode all the time, except for getting on to the Interstate On Ramps, and when I need to make quick acceleration count with oncoming traffic in a turn that is 45MPh+. That works nice to get me into the traffic flow quickly without getting a "finger" in my mirror....:(
  8. Tideland Prius
    16,549
    ECO as the default unless the situation requires otherwise (e.g. short onramp or steep hill, then I'll be in PWR Mode)
  9. edmcm2000
    edmcm2000 New Member
    Arizona
    What's with "normal" mode, I always drive in eco, and thought I had to use either ev, eco or power. How do you set up to drive with no mode enabled??? Edmcm
  10. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    Been in ECO Mode since I bought it.
  11. donalmilligan089
    239
    22
    virginia usa
    Please explain to this dummy how you change modes. When you say power button or eco button I have only a power on button on 2005
  12. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    If in eco or power mode just push that button a second time and it will go into normal mode. Push it again and you go into that mode again.
  13. MarvHein
    MarvHein Junior Member
    63
    Las Vegas, NV
    PWR disables itself when you turn off the main power switch but ECO is persistent unless you intentionally switch it off by pressing the ECO switch again or switching to PWR. If neither ECO or PWR are enabled, the mode is considered "normal."
    Some are debating whether there is any real difference between the modes other than pedal sensitivity. I personally use PWR all the time so I have the juice instantly if I need it in traffic, but that comes with a requirement to use a light foot the rest of the time to achieve ECO-like mileage. I'm actually beating my best ECO numbers by a little.
    Haven't tried normal mode yet.
  14. Tideland Prius
    16,549
    A 2005 doesn't have any driving modes. The POWER you're referring to is to start/stop the car.
    The PWR Mode button we're referring to is a separate button that changes the feel of the accelerator and changes the way the hybrid system responds to it. The other models are ECO and EV Drive mode. If nothing is selected, it'll run in the default driving setup.
  15. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Here are the buttons we are referring to:
    I used to use ECO exclusively, but now I leave it in normal. I use ECO only when in true stop and go traffic. I have been getting 4mpg more using normal believe it or not. I think using normal I accellerate up to speed a bit faster but then glide quite a bit more than when i was using ECO where I used to stay in battery too long and end up just draining it too much... I use PWR if getting on a short ramp to a highway, on hills/mountains or when i want to jumo off the line a little bit...
  16. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Hmmmm yours are reverse from mine:confused:
  17. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    That's not mine, it is an image I used from the net... It is probably from a right hand drive vehicle. ;)
  18. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    Haven't taken it out of ECO yet...
  19. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I think I tried Power mode once to check it out but other than that it has been ECO since I picked it up.
  20. Tideland Prius
    16,549
    lol.. and just to confuse people, you decided to show a pic of a RHD model :p
