Voltage line cover: Rear skid plate??
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mlbumiller, Sep 15, 2009.
  1. mlbumiller
    mlbumiller Junior Member
    sage cali (near temecula)
    Has anyone had their voltage line cover (white plastic casing over the 440volt lines) damaged? I landed in the ditch, after being hit, my gas tank and line cover were damaged. Insurance questioned if that damage didnt really occur under normal driving.
    Is there a rear skid plate?
  2. kenmce
    kenmce High Voltage Member
    1,549
    522
    NY
    Look for bare metal. If it's rusted over, it's old damage. If it's bare steel it's fresh. You may also have fresh mud or grass sticking to it.
  3. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I don't think it matters how the damage happened does it? I am unaware of any "normal" damage, Is damage normal?
  4. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    Does "normal driving" include off-roading? I mean how else would you damage something like that? Curb hopping?
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i've damaged mine. it's simply a semi clear casing so safety crews know where the lines run. they are not open lines... they are coated, so they are safe to get wet. ;)
  6. a64pilot
    771
    62
    Albany Ga.
    My point is regardless of how it's damaged, doesn't insurance have to fix it?
