Gen 6 Nav Voice Recognition Commands (Fr/Sp)
Discussion in 'Knowledge Base Articles Discussion' started by Tideland Prius, Sep 16, 2009.
  1. Tideland Prius
    16,485
    Here's the list of commands for French and Spanish
    See attached word doc.
  2. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Thank you. As a native fluent French speaker (not Canadian, eh, French;)) this will be helpful.
    Do you know if the words will work in different languages by default, or do you need to switch he GPS via it's menu to go to another language before it works in that language.
    (In other words, when I get in my car to drive home tonight, as it is in English, will the French commands work, or will I need to set it for that first?)
  3. Tideland Prius
    16,485
    hmm.. lemme practice my French =P.
    Pour utiliser les commandes, on devrais utilise le systèm entière en français. Appuyer sur «SETUP» puis sur «GENERAL» et changez la langue à français. Appuyer sur«OK». Maintenant appuyer le bouton voix.
