smart key one step unlock
Discussion in 'Gen 3 Prius Main Forum' started by kash, Sep 17, 2009.
  1. kash
    kash New Member
    Houston, TEXAS
    is there a way when i put my hand in driver side to unlock all doors? it sucks walking up and unlocking all the doors after i get in?
    my sisters gs unlocks rear doors when you put your hand in rear handle
    and front only when you open from the front, i know there is no rear sensor but any ideas?
  2. pfreeus
    pfreeus New Member
    62
    CA, USA
    If I remember correctly, just stand next to your driver door and hold both the lock and unlock buttons on the remote for about 5/10 seconds. You may want to check the manual to make sure.
  3. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    KASH,
    Check page # 48 of your owners manual, as you can choose the settings you want there. From single door to all doors.
    It should be relatively simple and painless.
    Good Luck!:)
  4. octavia
    octavia Active Member
    968
    137
    Beautiful Oregon
    Yep,
    Mine is set to unlock all doors. All I do is touch the driver side door handle and Wa la!
    the whole tribe can get in at the same time.
  5. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Octavia,
    Was it easy to do? Do you hold both buttons lock/unlock and then touch the door handle? I haven't adjusted mine yet but since you may have just was wondering...and then KASH can do it too. :)
  6. octavia
    968
    137
    Beautiful Oregon
    I had the preference set at the dealer. In this thread, http://priuschat.com/forums/gen-iii-2010-prius-main-forum/67909-things-can-customized.html, CSJoe created a one sheet template with all the customizable options on it. I just printed that and took it to the dealer and they made the adjustments. :)
  7. claridiva
    claridiva New Member
    109
    Dallas, TX
    Bobsprius and Kash:
    It is VERY simple. Look at page 48 in the manual as previously suggested. I just sat in my car (with it off), held the lock and unlock buttons until you hear a series of beeps (or maybe just one beep? It's been a while) from the car and then holding/touching the driver's side door will unlock all doors. It is really handy with groceries and passengers not to have to open the door to unlock all doors.
  8. bluemonday
    bluemonday New Member
    151
    26
    St. Louis
    I did it too, very easy, basically what he says above but read the page in the manual. I do think you have to be in the car to do it, not outside. Maybe that doesn't matter, but it does show something on the display area so that you can see you changed it.
  9. Tad Moody
    Tad Moody New Member
    35
    Duarte, CA, USA
    In / out doesn't matter
