12v battery issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dawall, Sep 20, 2009.
  1. dawall
    dawall New Member
    05' prius, 110k miles, car is driven every day. The car has never had a problem (no warning lights). Very reliable
    My wife calls me to tell me the car wouldn't open,so she used the physical key to get in. She said even when she inserts the smart key in to the slot she can not get anything to turn on and that the car is totally dead. Unfortunatley she is about 2 hours away. She has called for emergency service. Hopefully the 12v battery is drained.
    So the question is what would cause total loss of charge in a locked car in only 5-6 hours? The car is left at her office for much longer that that and has shown no signs of slow starting. No apparent signs of a weak battery that I have seen. Is there something in the car that could be left on that could drain the battery?
    She drove ~100 miles to get there and she said nothing appeared to have been left on but then again the car is totally dead .
    BTW vehicle was brought for 100k full service a few months ago.
  2. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    12V can cause all kind of gremlins I had a list of strange behavior and after a ne2 battery they are all gone
  3. dawall
    dawall New Member
    *update Car started normally after jump start with no problems. I called Toyota dealer who said they would do a load test (He said toyota wants to know how long these 12v batteries are lasting), but that it is time for a new battery anyway.
    The thing that puzzled me was, other vehicles I have owned always had batteries that lasted well longer that 4-5 years and when they go they give an indication with slow starts. I have never had a vehicles battery fail completely with out some kind of continuous drain like lights radio fan or ? I would think if these 12v batts. are prone to a dramatic loss of charge holding ability that it would be part of the maint. schedule. um maybe it is I'll have to look.
    Dan
    05 Prius
    110k
  4. richard schumacher
    7,664
    1,046
    United States
  5. qbee42
    3,079
    The Prius is a different type of car with a different type of 12V battery. The 12V battery on the Prius is only used to provide standby power and boot the systems. It never does any cranking. This means you don't see it failing. It gets closer, closer, and then gone before you really know that you have a problem. Also, as mentioned above, it's a small battery. It won't take much abuse from open doors and left on lights.
  6. dogfriend
    7,512
    1,190
    Carmichael, CA
    I have. Hot weather is particularly hard on lead acid batteries; I have had a few fail without warning when the ambient temps were high (>100°F). I also had a Ford Ranger that would go through batteries every 2 or 3 years, although my Ford Explorer battery lasted about 6 years before needing replacement.
  7. dawall
    dawall New Member
    Hey, thanks that is good info. I guess it should have dawned on me that size of abattery could not have the cranking amps to turnover an engine. So I guess it really is the bios battery for our computer with four wheels:rolleyes:
    Dan
  8. Patrick Wong
    18,210
    6,511
    Hi Dan,
    This would be a good analogy if the little battery in the computer also energized the control circuitry and a relay that allowed AC power to flow to the computer's power supply... :D
    Regarding a 12V battery dying with no warning, this happened on a 2002 Ford Taurus that I used to own. My wife was stranded at a local shopping center. I bought a new battery and installed it at the shopping center parking lot.
  9. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    From reading the forum, I know all about the 12V battery issues (and from having seen the thing, I know it's wimpy) but it never dawned on me that in a "normal" car cranking slow is a good warning that the battery is nearing the end of its lifecycle. And since our cars do not use the 12V to crank the engine, we get no advance warning. Interesting. This explains why we get all those wierd issues when the voltage is dropping - had the 12V been starting the engine, it would have been very slow and been replaced long before the point of causing computer issues.
    I had an Alfa that had similar issues - it wouldn't boot the fuel injection computer, or it would but would give sensor errors when the voltage was below the switching voltage for the transistors in the computer. It would even crank slowly but not run if the fuel injection computer wasn't switching in (obviously - no fuel).
  10. dawall
    dawall New Member
    Had new Batt. installed $166.44 + labor $49.95 which included a vehicle inspection.
    While we were at the dealer we took a quick look at the new models....nice but nothing really that compeling that would make us trade up. Maybe at 200K we'll take another look.
    Dan
  11. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    $216 for a low amp battery is a real insult. $275 for DVD updates is a huge rip off. I understand factory parts are more expensive than aftermarket, but this ain't right.
    Toyota needs to get this more in line with other cars.
  12. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I don't know the local Nissan dealer wanted $159 for my friend to buy a new battery for her Altima, Part only no installation or inspection. I agree that this seems high, but I don't think they are out of line when compared to everyone else is all I am saying. Its not like the dealer is volume selling batteries like Wal-mart at $60 each.
  13. Patrick Wong
    18,210
    6,511
    Some dealers charge as little as ~$130 for the battery at the parts counter. The battery is made in Japan and comes in very elaborate packaging (the box alone is probably worth $20... :rolleyes: )
  14. richard schumacher
    7,664
    1,046
    United States
    And the OEM battery gives the appearance of very high quality. My Optima Yellowtop works fine but looks crude in comparison.
