My Prius after 1 year...
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bino, Apr 6, 2009.
  1. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    finally got the tanabe coilovers to replace my TRD sportivo suspension....
    here it is installed...
    by the way... I'm selling my TRD sportivo springs and shocks.... currently looking for local buyers for now(SoCal).. thanks...
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    handling differences?
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    What is the height did you use? I believe it is adjustable. Did you use the lowest setting?
  4. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    yup it's adjustable..... i'm using the lowest setting right now which drops the front about 2.2 in and the rear about 2.5 in
  5. jestoy7
    jestoy7 New Member
    238
    25
    Jacksonville, FL
    Nice car, that is what I'm thinking of doing with my Gen III. Red tails, black roof and wheels...all in due time.
  6. a_gray_prius
    2,927
    783
    IL
    You could be the only Prius in the HellaFlush club:
    HellaFlush?
  7. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    correction on this statement.... setting is not the lowest setting.... sorry about that....will play around with the adjustments soon.....
  8. turnerdhr
    turnerdhr HellaFlush(TM) Prius
    SINGAPORE
    make that 2.....
  9. Yont283
    Yont283 Junior Member
    34
    Livonia, MI
    2014 Prius v wagon
    hows the vinyl on the roof holding up? I really want to do this to mine.
    LOVE the car!!!!!!
  10. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    vinyls are holding up pretty well... considering that I'm parked outside (under the sun) during the day from mon-fri........ on weekends I usually spray plexus on it to clean it (it was the cleaner advised by the installer)........
    2 people like this.
  11. Yont283
    34
    Livonia, MI
    2014 Prius v wagon
    hmmmm.... do you think paint would be a better option for the long run?
  12. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    not really sure if paint would be a better choice.... i went with the vinyls because i just have to remove it if i don't want it anymore...
