Clock Operation and Daylight Saving Time feature
Discussion in 'Gen 3 Prius Technical Discussion' started by Stan Ames, Sep 21, 2009.
  1. Stan Ames
    Stan Ames Junior Member
    30
    MA
    As we drive across country in our new Prius 5 I notice that the clock on ths dash display is just a dumb clock and does not change as the time zone you are in changes.
    On the NAV display there is an option for timezone and daylight saving time.
    The strange thing is that the time to get there on the NAV also does not change with respect to timezone and you must change it manually each time you change a zone. (which is a poor design for a GPS system who knows where it is.)
    So my question. What does the daylight saving time function do.
    I see no place to enter the date so what effect (if any) does the daylight saving time setting actually do?
    Stan Ames
  2. qbee42
    3,079
    When you say "Time to get there", do you mean ETA or ETE?
  3. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    David (aka Blind Guy)
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    The clock doesn't automatically change when daylight saving time kicks in, so you toggle the ON/OFF switch to display the correct time.
  5. Stan Ames
    30
    MA
    Thanks for confirming my observations. I was hoping that somehow I had just missed something simple.
    We are just about finished with our coast to coast trip in our new phase 5 Prius and our general conclusion is that the drive train and overall car represents the top end of technology but inside the electronics are a tad in the dark ages.
    Stan
  6. Jon S
    Jon S Member
    185
    84
    The Aloha State
    I can't think of any car that will change the clock's time according to changes in the zones you drive in...
    I can't even think of a watch that does that either...
  7. RodJo
    RodJo Member
    423
    56
    Boston
    The Navi knows the current time AND consequently your location. It shouldn't be that hard to do the conversion and display the local time (and date).
  8. Tideland Prius
    16,602
    Do any Garmins do that? My TomTom doesn't change time when I'm in another time zone.
  9. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    My Honda NAV does this.
  10. nylion
    nylion New Member
    167
    61
    Seattle WA
    It's not as easy as you think. The time zones do not follow straight lines. There is a lot of zigging and zagging to accomodate county and town lines, bodies of water, etc. I know someone says his Honda nav does that, but that's surprising. GPS works on Universal time (GMT). The local device (your nav) uses your setting to add or subtract the rigth number of hurs from GMT. The daylight time adjustment is a convenienc that just adds (or subtracts) an hour when you set/unset it.
    I agree that it is disappointing that the clock display doesn't get its time from GPS. In my old Acura the time was displayed on the nav screen, so it was always correct time. GPS time is extremely accurate. The standard clock in my Prius keeps very good time. Like most modern electronic clocks, it doesn't seem to gain or lose more than a second or so a month. Since it doesn't have a second display, I tell how my clock is set by listening to NPR on the hour and noting when the "All things Considered" theme starts. That is always going to be no more than a second past the hour. So far my car's clock is right on.
    BTW I maintain a public time service for computers (tick.mtnlion.com). Some very large companies use it as their time standard. I use software (NTP) that gets the time from about 10 sources. Some are atomic clock based, and some come from GPS. It is accurate to about a ten-thousandth of a second.
    When I drive, I like the clock to be accurate within a minute. The standard clocks far exceeds that expectation.
  11. wiaitchison
    wiaitchison New Member
    Oregon
    Daylight Savings Time has now come and gone, and the clock on my Model V did not change. I turned Daylight Savings Time off in Setup, but the clock still did not change.
    Any ideas?
  12. qbee42
    3,079
    The clock does not have any setup functions. All it has are H and M buttons. These advanced buttons allow you to adjust forward the Hours and Minutes of the clock. I know this is an advanced and cutting edge feature, but with time and experience you will become adept at manually changing the time twice a year. :D
    Seriously, it is surprising that a technologically advanced vehicle with an expensive GPS system requires manual clock setting, but it does.
  13. wiaitchison
    Oregon
    Well, shoot, I didn't even thing to do a manual adjustment. I thought the Daylight Savings Time setting actually did something! Thanks for the tip.
  14. Jim Calvert
    Jim Calvert New Member
    255
    28
    Worthington, Ohio
    Although all PCs automatically update the time of day, I do not know of any automobile clock that can do the same. However, there is no technical reason why this could not be done, especially for those vehicles connected to the outside world with onboard GPS systems.
    Jim
  15. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    My Honda CR-V's clock changes to and from DST automatically.
  16. Jim Calvert
    255
    28
    Worthington, Ohio
    Well then, come on - Toyota - get with it!
  17. qbee42
    3,079
    Better yet, let's get rid of Daylight Savings Time.
    Hannah Andersen likes this.
  18. Blind Guy
    352
    194
    This same basic question was asked in another Thread, and IraS answered that for those Prius equipped with Nav, the Time Zone and DST functions in the Clock Set Up was for the Clock readout in the Navigation screen, ONLY trouble is...we can't find it ANYWHERE in the Nav screen!
    If ANYBODY knows where it's located on the screen, or what needs to be activated to make that display operable. PLEASE post it here!
  19. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Looking through the Nav manual, the only time that I see displayed is estimated arrival times when doing pre-route planning, etc.
  20. rschnapp
    rschnapp Junior Member
    Related question:
    I have a 2006 model, WITHOUT the nav package. The clock is unnaturally accurate. I never have to adjust it, and it always changes the minute within one second of my WWV-calibrated watch. Other than changing the hour for each DST change, I have never had to touch the minute button since purchasing the car 3 1/2 years ago.
    Do others have similar experiences? Is the Prius clock somehow externally synchronized (like my watch)? Or does my Prius just happen to have an anomalously accurate time base.
