MPG in Winter????
Discussion in 'Gen 3 Prius Main Forum' started by PriusRoadWarrior, Sep 24, 2009.
  1. PriusRoadWarrior
    76
    Wisconsin
    Just wondering from you members that have had previous Priuses. I am from Wisconsin and my 2010 Prius is getting on average 55 mpg, with best on a trip being mostly on cruise of 63.5 mpg. What can I expect to happen with my MPG when we get temps down to zero. I have heard of some people say they get around 30 mpg, is that a strech of negative input or is that what I can expect? What State, and average Winter temperatures do you have and what have you gotten for mileage?
  2. dfran1
    dfran1 New Member
    89
    17
    MA
    With our 2005 Prius that we traded in (for a Prius 2010 IV) here in MA, we averaged about 44 mpg in very cold weather and about 46-48 mpg the rest of the time and summer was about 52 mpg, all on trip (but my calculated was about the same).
    If you only travel a few miles to work then you will get bad MPG's, the car will not heat up in time (the engine needs to get wormed up before it starts to shut down).
    Hope this helps.
    Don
  3. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    We hope the Gen III will do better, but I think nobody knows yet. Pretty sure preheating your engine helps, and I assume if it stays in a heated garage that would help too.
  4. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    Here's my 5.5 years of data driving in Minnesota...
    46.5 = Spring
    51.3 = Summer
    47.6 = Fall
    43.7 = Winter
    The 2010 will clearly do better. Toyota did a lot for thermal management. I'm totally looking forward to this cold season.
  5. Pohaku
    Pohaku Member
    143
    twin cities
    Are you running snow and ice tires in winter?
