when will the ice kick in during acceleration
Discussion in 'Gen 2 Prius Technical Discussion' started by J_w73, Sep 24, 2009.
  1. J_w73
    J_w73 Junior Member
    67
    I just bought a used 2007 prius. I'm in California and it is very warm. It seems like the ICE will kick on during the slightest acceleration from a stop even if I don't try to accelerate very fast. I wish it would have just a bit more pep at the start without the ice coming one.. I don't mind the ice coming on and realize it needs to at some point to recharge the batteries but in stop and go traffic or going down a road with many lights it would be nice to be able to go at a pace that the person behind me doesn't want to shoot me and still have the ice not come one..
    I do notice that when the batteries are in the green you can do alot more with the electric motors..
  2. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    The less you accelerate with the batteries, the better mileage you'll get.
    The green batteries symbolizes the charge level
    it'll turn different colors based on how full or empty the batteries are. look at the number of bars on the battery, you'll see it'll have different colors based on how many bars it has.
    And to answer your question: the ice will kick in unless you wanna accelerate really slowly. That's what its designed to do for optimum mpg. Second-guessing the programming will only hurt your mpg.
  3. J_w73
    J_w73 Junior Member
    67
    what is "really slowly" what is normal??
  4. Bob64
    1,540
    93
    Virginia
    Really slowly is probably the throttle position you have to push so the engine doesn't come on while the charge is blue
    Normal is any position after as soon as the ICE turns on + a little bit extra to eliminate it directing most of the electricity to the batteries instead of to the electric motors. Approx 1300rpm and up to approx 2400 rpm. Any higher and it'll probably be wasting gas due to pumping losses as well as the adjustment of fuel injection for more power instead of efficiency.
    Just accelerate at the same speed of traffic. Just don't purposely go slower so the engine doesn't come on. Because after awhile, the prius WILL FORCE the engine to come on at the SLIGHTEST push of the accelerator.
    Heres why using the battery is bad:
    Energy is lost converting mechanical energy into electric, then chemical energy, and then back into electrical and then back into mechanical.
    Think about it: the electricity comes from GAS. Converting gas to mechanical, then to electric, then to chemical, then back into electric, and then finally back into mechanical is even less efficient then simply leaving all those other conversions out and just use gas into mechanical energy LIKE IT WAS DESIGNED TO DO.
    The whole point of the battery is to capture BRAKING ENERGY: Which is the energy that would otherwise be LOST in the brake pads and converted to useless heat.
  5. J_w73
    J_w73 Junior Member
    67
    this is just creeping right.. I know it is hard to describe in words.. just seems like with the slightest push the ice kicks on..
  6. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    Install an EV switch.
  7. Bob64
    1,540
    93
    Virginia
    That's normal, depending on how low the battery is. Whats the color of the battery? purple? red? Blue?
    Battery power accelerates ~three or five times as fast as creeping.
    If you really wanna figure this out, get/borrow a scangauge so you can tell exactly how much energy is coming from the battery.
  8. J_w73
    J_w73 Junior Member
    67
    I have a scan gauge already.. I'm gonna hook it up tomorrow so I can monitor the load , rpm, and the battery like you said..
    I've never been in the red.. never really seen less than half but once..
    usually at 6 segments in the blue.. never been completely full to 8.. get to 7 green during city driving.. I guess the regeneration?
    from what I have seen and the fact I am on the freeway mostly at 65+ speeds I think these battery levels are pretty good... NO ??
  9. J_w73
    J_w73 Junior Member
    67
    I have read this about the EV mode..
    EV mode will automatically disengage
    when: your SOC reaches 2 bars; you step too hard on the accelerator;
    you reach 34 mph; or your battery gets too hot
    how much more accleration can you do in EV mode before the ICE kicks on
  10. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    J_w73,
    There is significant difference in the greater EV acceleration you can
    get with an EV mode switch. If you already drive gently, it feels like
    gentle ICE use and its easy to forget you're using EV mode and run the
    HV battery down to the red/magenta bars. In stop and go driving it
    takes a really long time to get back to 5-6 blue bars. At 65+ it
    wouldn't take so long, but in both cases the recharge has a big MPG
    hit.
    I've got an EV mode switch, but I've gotta say that I hardly use it
    any more. The conversion losses in energy going from ICE to HV
    battery and then on to MG1 to power the car just kill your FE/MPGs.
    FWIW, you can quickly drop out of EV mode at any speed or SOC
    (HV battery) level with a quick, half-throttle punch on the go-pedal.
    You don't seem particularly concerned about maxing your FE/MPGs, so
    you just might be one of the rare cases/people where heavy EV use
    and the attendant FE/MPG loss isn't an issue.
  11. J_w73
    J_w73 Junior Member
    67
    I want the mpg.. I just thought that running on the electicity would be more efficient and the regenerative braking and ICE generation at +34 mph would be enough to keep the batteries charged.. I am just seeing the threads about using solely EV being inefficient..
    It is just counterintuitive.. because the addition of the EV with the ICE gives you the greater MPG/efficiency.. so you would think more EV equals more MPG/efficiency..
  12. qbee42
    3,081
    It's a common misconception. Say this over and over until you believe it: "Using the battery is bad for mileage." For the very best mileage, avoid braking and avoid using the battery. The brakes and battery are there only because we drive in the real world. Ideally we wouldn't use either.
    Think of it like this: the gas engine is the only prime source of energy for the Prius. All other energy sources simply store energy from the gas engine, with subsequent conversion losses. Think of the battery and motors as a big electrical flywheel that stores energy from the engine and gives it back when needed. The flywheel has some losses. Driving the wheels directly from the engine is more efficient, but not practical for all speeds and loads, so we sacrifice some efficiency to make an automobile drivable.
    Regenerative braking is absolutely the worse, least efficient form of energy that the Prius uses. Why use it at all? Because it is essentially free. If you are going to brake anyway, it's better to recover a small portion of the energy than to toss it all away. It still doesn't make it great, but it is better than zero.
  13. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Also, the bigger the battery cycles, the fewer cycles before you're buying a new battery.
    BTW, when playing with how much acceleration you have in ev mode, you had a warm engine, right? 'Cause an engine as cold as, say, 70C will turn on whenever you leave full stop.
  14. J_w73
    J_w73 Junior Member
    67
    I don't have ev mode mod.. just pushing the gas a little so the ice doesn't come on..
  15. J_w73
    J_w73 Junior Member
    67
    Is there a thread that talks about what the mileage would be with a "prius like" ICE without the electic motor assist..
    one that turns the ICE off at stops and when taking your foot of the gas.. I wonder if some sort of air compression assist from braking would be any advantage so that you could use the air pressure when you moved from the stop..
    is there a thread about this sort of thing.. what ifs ??
  16. Bob64
    1,540
    93
    Virginia
    This would ONLY be true IF the energy didn't come from gas in the first place. Your using energy that will be eventually be less-efficiently replenished by gas.
