Possible to add sks to passenger door and hatch?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by yam, Sep 25, 2009.
  1. yam
    yam Junior Member
    64
    Austin TX
    I've got a Prius 2 with sks entry on the driver's door. Now that I've been driving it for a while, I wish I had sks entry all the way around (like they do on the higher trim models). Is it possible to add sensors on the passenger door and hatchback? Any idea what it would cost?
  2. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Wow - what a cool feature! Didn't know that if the doors are locked, I don't need to unlock with the remote - just lift the handle :cool: Very nice touch! I wonder - if this isn't programming...
  3. cpatch
    cpatch New Member
    383
    81
    Carlsbad, CA
    Actually, you just need to touch the back of the handle. And to the OP, it's not currently possible to add this feature to any of the other doors (without figuring out how to transfer the necessary parts out of another car).
    Finally, you can find a long discussion on this topic here:
    http://priuschat.com/forums/gen-iii...ossible-get-3-door-smart-key-in-prius-ii.html
    Plus another one here:
    http://priuschat.com/forums/gen-iii...fications/66867-any-way-add-sks-hatch-ii.html
    (I'm pretty sure there are more if you dig around.)
  4. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    lol!
    The problem is the SKS sensor for lower trim models is only in the left door area (and center console.) You'd need SKS sensors in the rear hatch and passenger side to make it work for all doors.
    (rrolf - at night when you walk up to the car the lights should start to turn on before you even grab the door handle!)
  5. qbee42
    3,081
    Not just programming. To lower costs, the single door SKS models lack the additional sensors.
  6. rrolff
    1,610
    246
    So Cal
    Hrmmm - I keep learning about all these features :rolleyes: Someday, maybe i'll RTFM :cool: Guess I'm not *that* observant - but I'll make sure I check it out 2night.
    This thread does seem to be the closest team working on it...
    Any way to add SKS to the hatch on a II?
    So it's likely some kind of hardware and software combo...
  7. yam
    yam Junior Member
    64
    Austin TX
    Just to clarify, I've got a 2010 Prius Gen 3, Trim level 2.
