"Running on Empty"
Discussion in 'Gen 3 Prius Main Forum' started by lutece7, Sep 24, 2009.
  1. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    I have been driving a 1985 Land Cruiser for 24 years. I have run out of gas in it 3 or 4 times. The manual says the gas tank hold 22.2 gallons, and I have put in 22.1 at least a dozen or more times. I am not worried about the crud in the bottom of the tank because this vehicle has a fuel filter. I have never burned out the fuel pump because it is next to the motor and gets hot all the time. I think fuel tanks have baffles in them to greatly minimize the effects of going up hill or downhill.
  2. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    David Beale, I think having a free and open exchange of information without getting on your high horse and putting other people down is the right attitude!
    I have a great gas can that is practically bullet proof. YOu can run over it and it won't even leak enough to produce and fumes what so ever. It is used by the off road community. They are called Scepter Military Fuel Cannisters. I have complete confidence that they wouldn't spill a drop in a roll over.
    Scepter Military Fuel Cans - Pangaea Expeditions
    You learn something everyday, David!
    Chris
  3. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    secondly, my hands will not get smelly, because have and ingenious syphon that requires no sucking. I have used it many times when I take my Land Cruiser to the Moab area for a 2 week expedition. It is powered by ratting a large ball bearing in one end. Works great. Then I transfer the syphon, when done, to a plastic bag. I've done this a lot on expeditions: What I learned in the Maze
    I still don't think the fuel pump will be damaged. I don't see how. They aren't very expensive anyway. No one said anything about this doing damage to the fuel system. Rather, damage to the fuel pump. I think I will stop using the pump when I run out. So I do not see a problem over heating it.
    Don't any of your guys have a thirst for knowledge? THAT is the bennefit, Patsparks. Knowledge. To know your car. It is a car. A wonderful car. But you are making too big a deal out of the risks, in my opinion. I will take my Prius to a parking lot the first ice storm and push it till it spins out, just so I can gain more knowledge about it. Is that going to hurt it too?
    just want to get to know my car. And I am being called stupid for wanting to learn.
  4. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    Because I don't have a supply of gasoline at my house.
  5. georgew
    georgew New Member
    129
    If it makes you feel any better, I don't really think anyone is calling you stupid.
    I'm on the other side of the spectrum..I fill up once a week regardless. The plus side is it doesn't take very long and if something ever happens to prevent gas stations from operating, I'll still be good to go.
  6. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
  7. Spartane
    Spartane Member
    149
    43
    Mississauga, Canada
    WOW - this topic seems to have really hit a nerve with a lot of people! I admit that all of my arguments are weak, but you asked "why" so I tried to respond.
    Looking at it the other way:
    1. The electric fuel pump is mounted to the bottom of the gas tank, so most likely the tank itself will heat sink the pump and protect it from overheating. And we know that Bob has already done this experiment on multiple occasions with no apparent ill effects.
    2. Unlike the previous generation Prius, the 2010 reserve fuel capacity is very predictable, with about two gallons remaining after the the gauge shows empty. So if you're driving a road that you're familiar with, it's fairly easy to predict your mileage (e.g.) at 55mpg you've got 110 miles reserve, so 80 or 90 miles is fairly safe, even without a spare can of gas. And unlike most cars, you don't need to worry about major traffic jams running you out of gas since the Prius doesn't burn any fuel when you're not moving.
    3. Who cares about crud plugging up the fuel filter -- the 2010 is new and it typically takes years for that kind of crud to build up.
  8. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    well, now that I know for sure, that I have about 100 miles after my tank reads 0 miles to next fill up, then I will not drive til I run out of gas. I am glad I know that I have this reserve tank.
    In the future, I will not even think about getting gas until I hit the 0. When I am on the road to Alaska or Newfoundland or Big Bend, I will have confidence that I can make it to the next gas station even if my guage is very low. I can know for sure the range of my vehicle.
    thanks to all who participated in this discussion. And remember, not ALL gas cannisters are unsafe. the one I have is amazingly safe and odor free.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    If you are refering to my post in the above quote I would like to bring your attention to something. I didn't call you stupid, I'm sure you are not sir, what I said is the behaviour is stupid, that is all.
  10. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    As of this post lutece7 has 38 posts. Here is a guy new to forum with a somewhat different but valid question and he is welcomed like this. I would ask all of the people in this thread to evaluate your responses and consider how you would feel if you were a new guy asking questions.
    Now for my comment on your question. I think it is a valid thing to know how many miles or how much gas is still available when the ticker goes to zero. I welcome your findings. Be safe.
    Some of the points made by above posters are good points. I wish the people that did berate you were more considerate.
    So let me welcome you to the forum. There is a lot of good information here. I hope you have not been turned off by the attitude of some.
    3 people like this.
  11. bwilson4web
    16,388
    The 2010 Maintenance Manual shows that the fuel pump assembly can be replaced. The North American Prius had a bladder so the whole tank had to be replaced and there was a real risk from over-filling.
    Galaxee's DH disassembled a bladder tank and posted the photos a year or so ago because it had been overfilled. The former tanks were sealed units so the whole tank had to be replaced at about $1,500 ... non-warranty repair. Worse, the fuel indicator from flash to empty ranged from as low as just over 25 miles to a high of 134 miles.
    Now I want to make it clear:
    • Running out of gas is not recommended - because there is no warning light when the last of the gas is gone. If someone is not aware of this, they can run their traction battery down before they find a safe place to park.
    • From FLASH there is ~2.1 gallons remaining - reset one of your trip meters and use the distance and fuel consumption rate to calculate the amount of fuel remaining; cut your speed to maximize your range; and fill-up at the next opportunity.
    • Testing for fuel gone - punch the accelerator to see if engine spins; watch the traction battery SOC and see if it is going down.
    So let's also address some vehicle risks:
    • fuel pump overheating - the fuel pump is driven by the ignition controlled battery bus. Turn off the car and there will be no more electrical energy going to heat the fuel pump. Turn off the car when it is out of gas. However, you may need to run the emergency flashers (I need to find out if the emergency flashers run when the car is off.)
    • catalytic converter burn-out - when the engine runs out of gas, it rapidly transitions through lean to no longer producing heat. It would take sustained operation at high heat to do damage to the catalytic converter and the transition to 'out of gas' is pretty rapid.
    It is easy to avoid running out of gas. But sometimes, sh*t happens and when it does, DON'T PANIC. If you catch it soon enough, use the traction battery to get to a safe place and then get some fuel. If not, your car will soon lose traction battery power so coast to the least bad place to stop and then get some fuel.
  12. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    I thought that the person actually doing the out-of-fuel testing (you?) said that once the gas was gone, the 2010 Prius would NOT continue to run on any remaining traction-battery power.
    I thought that the NOT being able to use the battery to get to the side of the road was exactly the safety issue with the 2010 Prius.
    Am I wrong?
    Added: I now see that you later discovered that the 2010 Prius WILL continue to run on the traction battery, though perhaps only for a very short distance - depending upon the state-of-charge when the fuel runs out.
    Also, there is no obvious warning that one is out of fuel, so the event (and the resulting transition to battery-only power) can be easy to miss. So, you recommend: Plan Ahead to NOT run out of fuel.
    THANKS for the update here in this thread, or I might have missed it.
  13. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    As I'm sure you know :) it's not going to hurt a thing and it's a very good test. I've done the same thing on dry pavement, you need a very large very empty parking lot. It's good to observe the operation of the VSC system and notice what the lights do and what the effect on the throttle is. It's also good to know what the car feels like near the limit of adhesion. I test my ABS by using it on an empty stretch of highway at several different speeds so I will know what to expect if (or when) I need to use the anti-lock brakes for real.
    Keep experimenting, I think it makes us safer and more knowledgeable drivers as long as we temper our experiments with a little common sense.
    :rockon:
  14. bwilson4web
    16,388
    It took three fuel exhaustion tests to figure it out:
    1. I was on a down grade so gravity, momentum and a handy parking lot and I was able to park out of traffic and add the extra gallon. The only indication I had was the "electronic steering error." In this case, I had no reason to try the accelerator so I didn't realize the traction battery power was not available.
    2. In this case, I was at about 45 mph on a gentle up grade when the "electronic steering error" came on. I was surprised to find there was no remaining traction battery power. Fortunately it was about 3:00 AM and there was no other traffic. I had enough momentum so I shifted into "N" to inhibit regenerative braking and coasted into a parking lot about 100 yards away. This really bothered me because I didn't know if between the actual last gas burn and the "electronic steering error," there was any traction battery power. Also, the error light was misleading.
    3. This last case, I was on I-565 at 70 mph and knew it would run out of fuel any moment. Since I was approaching an area I didn't want to run out of gas, I took an exit to make a U-turn. When I started to accelerate on the on-ramp, I realized the engine didn't start and it was truly out of gas. But I was only down one bar on the traction battery SOC. I was quite relieved that I could use the traction battery to move down the shoulder ~200 yards where I put in the spare gas.
    But sometimes it is hard to get this across in a posting.
    No problem! I fully realize how difficult it is to get something as involved as running out of gas described in a way that everyone understands. I have no problem with sharing my 'lessons learned' if it helps folks to understand and deal with it.
    I ran the car out of gas deliberately because I also like to do gasoline studies and this is the best way to switch between gasolines with a minimum of mixing. The earlier NHW11 and NHW20 were very good about throwing up a dashboard full of error lights when the last of the gasoline was gone but our ZVW30 doesn't.
    I understand Toyota believes this 'stealthy' behavior meets the vehicle design specifications. As I've pointed out, I think it is far safer to give the driver some indication when the last of the gas is gone so they can use the remaining traction battery power to reach a safe place.
    My best estimate is the PriusChat community is a small fraction of the total Prius owners, less than 1%. If my worst fears are realized, something bad may happen in the pool of the other 99% of Prius owners. That will be reflected in an accident statistic but hopefully NOT BY ANYONE HERE! It would be best if I am wrong but a simple risks analysis suggests otherwise. I'm patient ... and sharing what little I've learned with the community.
  15. garygid
    379
    Orange County, CA
    I, for one, APPRECIATE VERY MUCH your sharing and your careful observation of your thoughtful experiments.
    I agree, there should be some very noticable "gas gone" indication.
    Please, what are the NHW and ZVW designations - where do they come from?
    Oh, from the Prius Glossary, I see that there are "chassis codes":
    NWH-10 = Japan Only = 1997-1999 (Gen0 ?)
    NWH-11 = Gen1 = 2000-2003
    NWH-20 = Gen2 = 2004-2008
    ZVH-30 = Gen3 = 2010-...?
    What happened to 2009?
    Probably NWH-20 also (Gen2)?
  16. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    Thank you very much bestmapman! I appreciate your coming to my defense!
    I got up to 92 miles over "0 miles to next refill" display. I was satisfied. I saw a gas station with $2.18 gas and filled up the tank. It too on 11.84 gallons of gasoline. I didn't run out of gas, and I learned first hand exactly how far I could go on a tank of gasoline. I trust my guage now. When it says 234 miles to next fill up, and can just add a 1 to the first digit (334). I will, fill up when it hits "0" miles left (2 gallons in the tank) the vast majority of the time. But it is is late, and I am driving a long abandoned stretch of highway, in a remote part of the country, at least now, I know how soon I absolutely HAVE stop and get gas. I know it first hand. And that could be a great comfort one day.
    thanks to all that helped me on this. I am satisfied.
  17. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i will tell you how far i have gone past zero on DTE if you tell me what your avatar is supposed to be. i m guessing its a car on a lift, but what car is it?
  18. lutece7
    lutece7 New Member
    62
    132
    Irving, Texas
    its my Prius
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    oic...i guess??
    why your wheels so bent out like that?? is that a parallax/fisheye/ photoshop kinda thing??
    anyway.
    on one tank, i did go 73 miles past the DTE Zero mark. or 121 miles past the "beep"
    pretty sure i had another 50 miles to go
  20. Spartane
    Spartane Member
    149
    43
    Mississauga, Canada
