Tail light dark out film
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Anthony, Sep 25, 2009.
  1. Anthony
    Anthony New Member
    103
    Pacific Northwet
  2. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Here are a whole bunch of threads found with a search using "tail light
    tint" as the search term:
    PriusChat Forums - Search Results
    Enjoy!
    The search tool is your friend. :cheer2:
  3. Anthony
    Anthony New Member
    103
    Pacific Northwet
    I tried that and I got 5 threads about replacing a tail light, wonder what happened. But thanks for pointing it out Capt. Obvious. :p
    And besides, I asked if anyone has used this, which in your search, has no answers.
  4. venom700
    venom700 Just call me Brian...
    196
    35
    Bethesda, MD
    Why would you PAINT tail lamps? You can get any tint shop to do them for about $50 but it will be a quick way to get pulled over all the time.
  5. Anthony
    Anthony New Member
    103
    Pacific Northwet
    From what I understand, painting them is not as dark as a tint, but still gives it a different look. When the tint shops tint the tail lights, do they take off the lights and tint on the inside? The paint is on the outside with a clear coat.
  6. hill
    8,785
    The 1st 2 years of Gen II were delivered that way .. dark on top already. But brake lights? I personally like 'em as unobstructed as possible to up my odds the guy behind me will more likely see 'em.
  7. ALL_600D
    ALL_600D New Member
    70
    25
    30
    San Diego
    here are pics of my tail-lights tinted. I even tinted the third brake light. At night, the lights pass through just fine. They are very bright and does not hinder the light output. All of my lights have been swapped to LEDs.
    I think it looks great and don't even think about spray tint. At least with vinyl tint, you can remove it without any damage done to the stock tail-lights.
    I bought the vinyl film from ebay. Just seach under "vinyl dark smoke." installing them takes some patience and its best to remove the entire light so you can wrap around the corners for a nicer clean look....good luck.
  8. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    Why would you darken something that is meant to signal to other drivers that you are stopping??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
  9. Anthony
    Anthony New Member
    103
    Pacific Northwet
    Just because you do not like it does not mean others will not. I have smoke lights on my truck and they are just fine, even brighter than stock since they are LED's. On a charcoal car the lights look like a huge whitehead pimple on a nice nice person. They have to go away.
  10. Anthony
    Anthony New Member
    103
    Pacific Northwet
    Those look real nice, and they are not too dark. Only thing is, will the film scratch, peel, etc?
  11. ALL_600D
    ALL_600D New Member
    70
    25
    30
    San Diego
    Thanks, the film is pretty resistant to scratch. Unless of course you deliberately use a key or some metal object just to see how resistant they are. Otherwise, normal usage, such as washing your car, running it through the car was and such will not show scratches.
    As far as peeling, that is why I recommend removing the whole taillight to work on prior to applying the film. Also you must use a heatgun to assist in corners, bends, and curves. Removing the lights will allow you to wrap the vinyl film around the corners. Thus far, minimizing the chance of something snagging the exposed corner and leaving it prone to peeling. After your done with the wrapping, it is recommended that you run the heat gun on the edges/corners of the film that way it adheres the vinyl film firmly in place.
    I found it to be way easier with another person assisting. Besides, if you don't think it looks good tinted, all you have to do is peel it off and....... abracadabra. back to stock.
    here is a pic of a scion tc taillight that I did just a few weeks ago. Tinted vs. Stock
  12. Anthony
    Anthony New Member
    103
    Pacific Northwet
    I have always been told the film they use on the windows is very sensitive. I have to use certain kinds of glass cleaner, ones without ammonia I think. I have also been told not to even put finger prints on the film since it may eat away. I just cannot believe people are using window tint film on the outside of their car. :eek:
  13. ALL_600D
    ALL_600D New Member
    70
    25
    30
    San Diego
    It is definitely not window tint. Its much thicker. DONT MISTAKEN IT FOR REGULAR WINDOW TINT. I got mine from ebay, search, "rvinyl smoke out tint film."
  14. sc24vr6
    sc24vr6 Member
    185
    52
    socal
    dark vinyl film is not window tint film they are total different film, I just did mine because this is first time put on so my corner doesnt look that good, will try again soon
  15. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    Ah, I just found some smoke out film and wondered if anyone had pics of it on a prius, of course someone did! :D
    Here's what I found, don't know how it compares to ebay prices:
    Metro Decals | Smoke Out Film
    How hot is that heat gun? Would a hair dryer work? I take it the heat is to allow it to stretch around corners? I'm a little worried about those pesky corners but at least I can peel it off and try again. Any tips on that?
  16. going red baby!
    610
    96
    Los Angeles
    How much did you end up using for the back? And front too if you did those. (I don't have my car yet, will have it in about a week.)
    Do you mean remove the entire light kit or just the lens?
  17. jukeboy
    jukeboy New Member
    132
    SGV, SoCal
    you can't remove the lens without having to first remove the entire kit
  18. going red baby!
    610
    96
    Los Angeles
    I see, thanks for the info.
