Dead car -- is my diagnosis correct?
Discussion in 'Gen 2 Prius Main Forum' started by DrD, Sep 26, 2009.
  1. DrD
    DrD New Member
    Reston, VA
    I installed the wiring for a trailer hitch a couple of days ago. Yesterday I drove some 50 miles to the place where I bought the trailer. [I plan to haul one or two motorcycles to track days and such.] Got home about 5 PM. It took much back up, pull forward nonsense to get the trailer backed into the garage. Since I am a bit sick with a cold, I just wanted to get done with the thing. So when my friend said the trailer tires were in the garage, I put the car in Park, put on the brake, then hopped out. I unhitched the trailer and pushed it the rest of the way into the garage, stood it up (nice Kendon trailer), tucked the trailer wires into the back of the car, then went inside for a beer.
    This morning I get in the car to go on some errands. Car is dead as a door knob. I jump it -- following the owner's manual instructions -- and now it seems fine.
    OK, it could be two things: First, leaving the car 'On' all night drained the 12V battery. Second, I messed up on the trailer wiring and it is draining way too much power from the battery. [Note: while driving home with the trailer everything behaved normally.]
    I think it was simply leaving the car 'On' all night, but I can't be sure. What do you think? Any way to test the trailer wiring for problems?
  2. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    DrD,
    Two questions:
    When you say, "leaving the car 'On' all night," do you mean in the
    "Ready" condition? (Ready light on dash is illuminated.)
    After you jumped the battery, when you first started the car, can you
    say how many bars showed on the SOC, and what color were they?
  3. qbee42
    3,074
    If you leave a Prius on in Ready while in park, the 12V battery will be charged as needed. I suspect you left a light on or a door open.
  4. DrD
    DrD New Member
    Reston, VA
    Yes, in the 'Ready' condition. I didn't get back in the car and power it off.
    The SOC bars were over halfway up and blue.
    BTW, I used a Modulite trailer wiring module. It tested OK when I installed it.
  5. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    The pieces aren't adding up right here, something's missing.
    As I understand it, if the car was in Ready, and running, even if the
    12v battery was dead, there would still be 12v from the DC to DC
    converter. And the ICE would cycle on all night as needed to keep the
    HV battery at a low charge.
    So no matter what the origin of the draw on the 12v system, the car
    should have been running all night...
    But, if you hit the Power button first thing in the morning, having
    forgotten that the car was in ready, it would have shut everything
    down. Now, if the 12v battery was shot, when you hit the Power
    button again, nothing would happen.
    Is this the missing piece of information?
  6. DrD
    DrD New Member
    Reston, VA
    You are losing me here. Will the car run the ICE to keep the 12V battery charged? A regular car will not run up the RPM of an idling engine if the voltage is dropping on the battery.
    If the car was in 'Ready' and there was 12V power, I would have seen the normal screen display. There was nothing showing. IIRC, I hit the 'Power' button again, thinking maybe I had hit the bezel instead of the button. Nothing. Then I noticed that there was no lights at all, which seemed wrong. Before my blood pressure went too high, I got out of the car and paused a couple of minutes (remember, I was, and still am, a bit sick). Then I got back in the car and went through the normal start procedure, paying close attention to what I was doing. It was dead.
    I drove around a bit and everything seems OK. In fact, another data point (or superflouous info): When I connected the Modulite, I accidently disconnected the 12V ground wire when attaching the ground for the Modulite. When I started the car after that and put it in reverse, the reverse beep was back on. I went through the procedure to turn it off. After the dead car and recharge event, the reverse beep was still off. That makes me think there was a trickle of charge from the battery, but not enough to get the systems going.
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    DrD,
    If the car is in Ready, yes by running the ICE to keep the HV battery
    charged, the 12v bus will remain 'hot," providing power to all the 12v
    electronics and keeping the 12v battery topped off.
    Are you absolutely sure of this? If there were no dash lights or MFD,
    then the car was not in Ready, or you had run out of gas during the
    night. If it was not in Ready it was in either Off, On, or Accessory. To
    be in either one of these, the night before you would have had to turn
    the car first to Off, and then to one of the other two.
    The simplest explanation that seems to fit -- Occam's razor --- is that in
    a moment of abstraction, inattention, or preoccupation due to the
    illness you did turn the car Off the night before, and the battery was
    drawn down during the night.
    Well, at this point the 12v battery was truly dead. The question
    remains how did it get that way.
    As it sounds like the trailer wiring harness has at least the negative
    lead common with the battery, and not connected to the tail light
    wiring, there may be some fault in the trailer wiring or hook-up such
    that it is directly draining the 12v battery, or...
    you turned the car to either Off or ON (one push of the Power button
    with the brake pedal not depressed) the night before and, as was
    suggested by qbee42, in a moment of distraction you left
    an interior light on or left a door or the hatch ajar.
    While you're thinking about these things, better check to be certain
    that the 12v battery ground connection to the body is tight and secure.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    DrD....its very simple. You left a door or the back hatch cracked and it killed the boot battery because you did not observe what almost every single person who comes on here and reports dead boot battery and that is you do not lock the door with either the fob or press the outside door button setting the alarm.
    There's been a few "I left the car running all night" posts here lately too and thats why.
    Which is no big deal as the car's engine will happily come on now and then regularly all damn night to keep everything charged and will contiunue to do so unitil it runs out of gas. Or it gets stolen.
    If the car is READY and you get out and try to lock it , it will not allow a lock and beep one long beep and if front door cracked will do the same. Get in the habit of locking the car every single time even in the garage. FOB or door button.
    I know you have the FOB on you.
    Good Luck.
  9. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    It's also the time to point out that once you've drained a 12V, it will never be the same again. It has lost a lot of capacity due to this event.
  10. DrD
    DrD New Member
    Reston, VA
    This morning I checked the car and everything is fine. From what I've read here, I am still confused (though I am also still sick and I know I am not thinking straight). However, there are enough other reasons as to why the battery was dead that I a believe the tailer wiring is OK.
    Thanks for the input.
  11. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Yeah lead acid batteries don't like to be fully discharged, that's for sure. Recharging it promptly as the OP did can minimize the harm though. If you let a lead acid battery go completely flat and then leave it like that for a few months then it's often completely unserviceable.
  12. qbee42
    3,074
    Just for the sake of completeness, not that I'm suggesting it happened in this case, but it is possible to run down the battery with the Prius in Ready. If you leave the car in Neutral, it will not start the ICE and charge the HV battery. The HV battery will slowly draw down until it reaches a critical level, and then everything will shut off with an impressive display of warning lights. If a light is on, the 12V battery will then draw down because it is not being charged by the dc to dc converter. Note that the Prius warns you about this if you leave it in N.
  13. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    A depleted battery will also freeze... breaking lots of the insides. Don't let a lead acid battery get very far down at all if you park in freezing temperatures.
  14. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    I would agree, you probably did turn the car off, but something was still on, maybe a door ajar.
    In that situation, whatever was on was running off of the 12v battery, draining it.
    The SOC of the traction battery being up in the blue reinforces this, as well as the fact that it was not out of gas. With the 12v battery dead in the morning, when you tried to start the car, you would get nothing. The 12v battery starts up everything else and throws the relay to the traction battery. Without the 12v battery, the traction battery cannot be connected to the system - thus no power, no nothing.
  15. vkykam
    vkykam New Member
    27
    Where were you when you powered off the car? Did you reach in from the passenger side?
