USB issues
Discussion in 'Gen 3 Prius Audio and Electronics' started by DarioBarrera, Sep 24, 2009.
  1. DarioBarrera
    DarioBarrera New Member
    24
    So I just got my new Prius IV this Sunday and I was lucky enough to get the Safety Connect and USB and I was wondering if anyone has the USB plug and can help me out with a few things.
    Well I will just list the most important and that is the issues with my iPhone. When I connect the iPhone I get a message on my screen saying that it's not compatible and after a few minutes I get a message on my Nav screen saying it's not working properly. Is this common with iPhones?
  2. eaglesight333
    eaglesight333 Senior Member
    7,173
    83
    Northern, IL
    I have read different things about this, and since I dont have an Iphone yet. (I will soon). I am not sure what the answer is. I read something about a firmware update that Toyota has to do, but not sure if that is correct. Do some searches, and you may get more answers.
  3. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Same issue here. My iPhone says that, when I plug it into the USB port via the apple USB connector, that it doesn't recognize whatever my car is as a compatible device.
    FWIW, I have the 9.1 Nav software and the latest Apple 3GS software.
  4. Snapperoo
    Snapperoo New Member
    Burbank, CA
    The documentation that comes with the car regarding USB/Safety Connect indicates iPhones are not compatible.
  5. IrishGuyJay
    IrishGuyJay New Member
    Los Angeles
    I am also having problems with the USB connectivity. I tried my iPhone and had issues which I mentioned in a different thread and won't repeat here. So earlier today, I tried attaching my iPod via USB and my music would not load on the NAV screen. Instead, my iPod said "Do Not Disconnect" and looked like it was trying to sync (as if it were attached to iTunes). It is an older model iPod (circa 2004) so that might be an issue, but I hope there is a way to get it to work.
  6. pri-serious
    pri-serious New Member
    32
    LA
    iphones are definitely compatible, if not, you might need to contact your dealer.
    this is another post of the similar issue http://priuschat.com/forums/gen-iii...8432-will-iphone-work-2010-usb-interface.html
    I have a prius iv as well and apparantly for my situation, the problem was that BT connection had caused USB to show "device not compatible" even though it played a day before. When I deleted pairing and paired BT again (both phone and music through iphone) everything works fine again, and music plays either way.
  7. bighouse
    822
    126
    Guerneville, CA
    pri-serious,
    Snappero is correct. Page 7 of the USB Interface Owner's Manual says this:
    Non-Compatible models:
    (a) iPhone, iPod min, iPod shuffle
    (b) iPod photo and 4th generation and earlier models of iPod are nto compatible with this system.
    It does list a whole bunch of different iPods as being compatible. So, I have a hunch this is why we all get that "incompatible device" message when we try to USB ours in. I sure hope the USB port is compatible for charging purposes and we're not damaging our iPhones by using it for such???
    This kind of sucks, bigtime. You'd think Toyota would remedy this situation immediately with some kind of a software of firmware fix.
  8. pri-serious
    32
    LA
    Hmmm...that is strange, because it works just fine with my Prius IV
  9. ad2001
    ad2001 Junior Member
    Seattle
    That message is more for precautionary than actual error message. It's more like saying that Apple has never tested it for the iPhone, and Apple will not answer any customer support call due to the usage with this device.
    I have the IV (with the Safety Connect thingy) and iPhone 3GS, and the USB works although I don't use it now because of the stupid control.
  10. gryphoness
    gryphoness New Member
    East Bay, CA
    Hi all. My first post on these forums.
    We just picked up our 2010 Prius today -- IV, solar roof -- and I tried to use my iPod shuffle with the USB and it wouldn't recognize. Found this thread while searching for answers. Haven't tried USB with my iphone, or playing music, but the bluetooth successfully connected, pulled contacts, etc.
    Kind of a shame if it doesn't recognize the shuffle ever -- but it does seem to charge it.
  11. Grateful11
    Grateful11 Member
    107
    Central, NC
    You won't be able to control an iPod with the little Aux. jack but you'll get better sound.
    My former car, Scion xA had both iPod connector and the Aux. jack. With the Aux. jack
    you can use the iPod's built in equalizer but connecting via the iPod connector it will
    bypass the equalizer in iPod. Biggest drawback is you can't control the iPod with the
    steering wheel controls and it's very dangerous to try to find songs while driving.
    I suggest that if you connect via Aux. jack that you create Playlist's that you live with
    and just let it play.
  12. lawboy
    lawboy New Member
    53
    The playlist idea is a good one, whether you use the AUX connection or the USB connection. The USB interface takes a long time to scroll, so the use of several playlists is a must to shortcut the process.
    Personally, I think the sound is better when using the USB, but that's just an opinion. If I am going on a long trip, I use playlists on my 5g iPod via USB. If I just want to hear a song or two on my way home, I stream from my 3g iPhone via Bluetooth.
    Whatever your preference, it is sure nice to have options.
