Does the EPA test car's with 10% Ethanol
Discussion in 'Gen 3 Prius Fuel Economy' started by alfon, Sep 30, 2009.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Well, pretty soon the EPA will test the new 2010 thru 2011 cars for Miles per gallon.
    Does the EPA use the required gas mixture of 10% Ethanol mandated by several states, Oregon, where I live, is one of them?
    This could be the reason why many 2010 Prius owners are not getting the average benchmark by EPA of 50 MPG.
    If the gas used for testing was pure regular unadulterated gasoline the EPA figure of 50 MPG average would be easlily attainable.
    But with Ethanol there is a loss of MPG's. That could be the reason why so many people only report in the high 40's MPG for their 2010 Prius.
    I bet if you did a poll states with mandated 10% Ethanol would get less MPG than those states where regular gas is allowed.
    alfon
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    In theory, in general, ethanol has higher octane, but lower energy, by 30% (many premium blends have less energy than regular, they just resist knock better.
    So again in theory, in general you would expect a 3% reduction in mileage with 10% ethanol. The various Prius engines, (Gen I to Gen III) may do better or worse than 3%, like all engines. Engines that like higher octanes will do better, but the Gen II has no preference for higher octane. So far as I know, no one has exhaustively tested Gen III.
    http://en.wikipedia.org/wiki/Ethanol#As_a_fuel
  3. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    The impression I've had with several vehicles (single tank measurements) is that ethanol mpg loss exceeds 5% and is not compensated for by reduced price.
  4. john1701a
    john1701a Prius Guru
    12,803
    5,287
    57
    You'd likely not have a large & accurate enough sampling to properly conclude that.
    The average for my Prius is 54.3 MPG, despite only using E10 and just driving it.
  5. angelrob
    angelrob New Member
    94
    Rochester, NY
    In Illinois, where I visit my family, the E10 is cheaper. In upstate New York, where I live, only a few stations have E10 and the price is the same as regular gas. :mad:
    The last 3 half tanks I had (I was traveling) ended up being E10 and my mileage dropped from 58ish to 53ish. Note that it may have been due to the different driving (almost entirely highway/thruway and a bit hillier vs my normal 50/50 with a few small hills) but I didn't spend time searching for regular gas, just chose the closest stations.
    On another note, my latest full tank, purchased at my regular station is yielding in the low 50s on my regular commute. A coworker (Prius II driver) stopped by yesterday and asked if my mileage had dropped in the last week. His did and he thinks that the winter formulations have been started :eek:
    Robbin
  6. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    The original question is a good one. I would doubt they use E10. Good question though, and one I would like to have the answer too also.
  7. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Now that it's hard to find 'real' gas anymore, perhaps that's why I only average like 43MPG anymore. It was 50MPG up near Buffalo in August, but now I can't recall what those pumps said. I thought it was the terrain.
    Where do you FIND non-E10 gas anymore? I thought the required pollution-reducer they used to use was banned?...
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Don't know the answer but they use a special blend of gasoline for the test.
    Why do you think that owners of any car should necessarily get EPA "benchmark" mileage? See the two links at http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html for info about the test.
  9. angelrob
    angelrob New Member
    94
    Rochester, NY
    I'm near Rochester and I've only seen a few stations with E10 (Delta Sonic was one, a local Gulf was the other). I usually go to BJ's since the price is good and I was just below 55 calculated MPG (58.x reported)
    Robbin
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Sure would be nice if the EPA advised us consumers, who pay for the EPA, if they use 10% Ethanol in their testing as many states in the U.S. now require, mine included, all year long, not just winter.
    I believe if the EPA did you would see a 5-8 % drop in MPG across the board.
    Look at E-85 the so called enviormentaly friend gas that gets nearly 40% less mpg than regular gas.
    So you use nearly twice as much gas to go the same distance. That is really saving the enviorment.
    alfon
