VIN & Assembly
Discussion in 'Gen 3 Prius Main Forum' started by DeanFL, Jun 11, 2009.
  1. mcamp52
    mcamp52 New Member
    32
    Central Florida
    Congratulations on your new ride. I'll have mine sooooon. I know my VIN but I don't know how to find out when it will arrive in Jacksonville. Do you know how to find out?
  2. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    Mine, made 7/09, is A5 and 6 ( not 7) digits of serial number, a little over 035000.
    Ar there 6 or 7 digits for the serial number?
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Some VIN info:
  4. Jabber
    Jabber Chicagoland Prius Guy
    703
    213
    Chicago
    Good info Paradox. Just a word of caution though. Only Toyota follows that format as explained. Other makes are a little different. GM for example uses xx1xx where the "1" is actually the brand within GM instead of whether it is a sedan or coupe. 1 is a Chevy, 2 is Pontiac, 4 is Buick, 6 is Cadillac, 8 is Saturn. All GM cars start with XG#. X= country of origin, G for GM, # for make. The more I look at it, the more GM is different on a lot of the spots... And I thought every company had to use the same format... unless they changed it and I didn't get the memo :D
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    A: model year 2010
    5: Toyota Autobody Fujimatsu plant ... 0,1: Toyota Tsutsumi plant
    a little over 035000: serial number
    Ken@Japan
  6. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    JTDKN3DUXA004893*
    Manufactured in 08/09
