JBL stereo tweak
Discussion in 'Gen 2 Prius Audio and Electronics' started by leeskarha, Jun 16, 2005.
  1. leeskarha
    leeskarha New Member
    79
    It looks like I will be getting package #6 next month so it’s time to figure out how to tweak the JBL stereo.
    I have already decided to move my Infinity subwoofer from my Subaru to the Prius. I will more then likely disconnect the center speaker but I want to hear it again first.
    My current system is using 4 Boston Acoustic Rally speakers, which I love and I have my head unit configured as follows:
    High-pass filter set at 90Hz. (Main speakers are playing 90Hz and up.)
    Low-pass filter set at 120Hz. (Sub woofer is given 120Hz and below.)
    (There is a 30Hz overlap)
    When I setup the High-pass filter, it cleaned up the Boston speakers big time. When the main speakers don’t have to deal with the low end base, the sound is much improved (cleaner and allows for a higher volume level). This lets the subwoofer do what it does best and the mains do what they do best.
    So the question is; what is the best way to add High-pass filters to the JBL system?
    Passive, active, filter, crossover, new amp, other? Just looking for input.
    Thanks…
    -Lee
  2. GAGendel
    GAGendel Junior Member
    59
    New Jersey
    Hoo Boy! Where do I begin?
    One word.... Phase Shift! The human ear is sensitive to phase shifts as little as 1% if it produces odd-order harmonics (like the system in the Prius).
    One of the most annoying features of the Prius system is that it is highly equalized to get a reasonable semblance of flat frequency response out of those crap JBL speakers. In doing so they created some hefty phase shifts. Hard phonemes in the right frequencies have a real edgy sound to them... it almosts sounds like clipping. Low end is boomy and unnatural. I can't believe that a company (JBL) with this many years of experience still can't get it close to right. In the audiophile circles I've been in over the last 35+ years JBL wasn't even on the radar for good reasons.
    Throwing on another filter will exasperate this condition further. Without a good transient analysis of the system it's all just guesswork.
    That said, it depends on where you're going to do the filtering. If it's at the last stage (power amp to the speakers) you really don't want an active crossover since it has to deal with a lot of current.
    Active crossovers work well when placed in the early amplification stage (preamp to amp connection). Since the impedence of the amp is more or less constant, you'll get better spectral behavior. The active crossover needs much less critical design than a passive one and (for the most part) won't change over time since the components aren't stressed.
    An interesting thought just occurred to me... With the inverter pushing relatively high voltage already why didn't someone harness this in an electrostatic speaker? It would require working with Toyota closely, but it has the potential to make a system that far exceeds the audio accuracy of anything on the road (as long as you're not a dB freak).
  3. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    The front speakers are already filtered digitally at the preamp stage. There are 4 front speaker outputs, not counting center (which also has a high pass on the preamp side). Right and left lower speakers, and right and left tweeters. Only the rear speaker outputs are full range, with passive highpass for the tweeters.
  4. leeskarha
    79
    I would be very surprised that the amp would have a high-pass filter.
    Here is the description from Cluchfield on what filters do:
    “Low-pass models let frequencies below the cut-off point through and filter out the highs. High-pass models let frequencies above the cut-off point through and filter out the lows.â€
    These work very different then crossovers. (Active or passive.)
    If it had a High-Pass filter and no subwoofer that would mean sound below say 100Hz would be lost.
    If did find this on Cluchfield and it might work. But we need to know if the amp is Tri-Mode or Tri-Way.
    http://www.crutchfield.com/S-PpcdDLTyXJ4/c...2600#morephotos
    I would much rather use pass filters but I don’t think there is a way to hook them up. However this cross over (TM-100) would allow us to split the low signal and sent it to the sub and the high signal to the mains. (Front and rear). The cross over point is 100 for the sub which it perfect for me. (We would need two.)
    The PAC TM-100 Tri-Way crossover allows you to power a pair of stereo speakers and a subwoofer simultaneously from a Tri-Way compatible 2-channel amp. It's a cost-effective way to drive a subwoofer.
    The TM-100 has input and output wires that you connect to your amp's speaker outputs and to the wires leading to your speakers. A 12 dB/octave low-pass filter sends frequencies below 100 Hz to your subwoofer. A 6 dB/octave high-pass filter sends frequencies above 100 Hz to your main speakers. Handles 250 watts RMS per channel. 4-3/4"W x 2-1/16"H x 3-13/16"D. 1-year warranty.
    Important Note: A Tri-Mode or Tri-Way compatible amplifier is required.
  5. wilco
    wilco New Member
    402
    Well, prepare to be surprised because Dan is right.
    Quote: These work very different then crossovers. (Active or passive.)
    Uhh... no they don't. I don't mean to sound snotty here but a crossover IS a high and low pass filter.
    Everything GAGendel said was correct too... except "phase shift" is two words :mrgreen:
  6. leeskarha
    79
    When I called Crutchfield they gave me a different answer. Here is what they said: A crossover goes on the speaker side. A high pass filter goes in line before the amp process the signal. A crossover has wires, a filter has RCA plugs. The effect is the same but backwards. (Search on Crutchfield for pass filters and crossovers.) It might just be a mater of semantics. (And I don’t think you were snotty. I am always learning.)
    Anyhow, let’s reword the question:
    How do I stop all frequencies below 100Hz from going to the main speakers? (High-pass filter, low freq crossover.) That is the effect I am after. I do not believe there is anything in the JBL system that will do this.
    -Lee
  7. wilco
    wilco New Member
    402
    You're right it is semantics. Simply put, a high pass filter is any device placed anywhere in the signal chain that filters lower frequencies and allows higher frequencies to pass through, regardless of whether it is passive, active analog, or active digital. Same with low pass, but for low freqs. A crossover is a combination of each (again regardless of position in the signal chain, and circuitry). The rest is marketing talk.
    Tri-way or tri-mode refers to using an external device that produces L, R and mono outputs (the mono generally has low-pass filtering). You could try such a device with the JBL amp to see how it sounds, but since five of the seven outputs already have filtering it could introduce a phase shift which may make it sound worse than it already does.
    The only outputs that aren't already filtered are for the rear speakers. If you really wanted to do it right, and still retain the stearing wheel controls, beeps, etc. (and have the money burning a hole in your pocket), you could do the following...
    Disconnect all of the speaker outputs and take the rear door L and R outputs and attenuate them down to line level. Run that signal into an active crossover with front/rear fade adjustment, and sub-out. Run those outputs into new amps to power your door speakers and sub (which you'll want to add), and don't connect the front center speaker at all. If you keep the JBL tweeters in the rear doors, you should remove the capacitor (high pass filter) on the back of each.
    Anything shy of that will be a compromise (which is fine if you don't want to spend the cash). Do some searching/reading of the old posts here to get a better handle on what you're up against with the JBL "Premium" :roll: system.
    I've got some other ideas that are less drastic (read: cheaper), but I've run out of time here. I'll post more later.
  8. DanMan32
    3,799
    26
    Tampa Bay, FL
    My understanding with tri-way or tri-mode is an amp system where the signal is split into 3 bands: low, mid, and high, and usually each band is then individually amplified. The amplifiers can be designed to be more efficient for the band they are intended to amplify, and the ban splitters can be designed cleaner and cheaper since they don't have to deal with high currents, and usually don't have inductors.
    I took a look at the crossover description however, in this context, tri-way/tri-mode means 3 outputs: R&L outputs with high pass filtering where cutoff is fairly low, a bit below where the sub would take over, and a mono output with a low pass filter so that the sub would not get mids and highs that it doesn't need.
  9. wilco
    wilco New Member
    402
    <div class='quotetop'>QUOTE(DanMan32\";p=\"100107)</div>
    You're probably right about that, but as you noted in the second paragraph, in this instance Crutchfield is referring to an external crossover/L+R sum sub out device. I used to work in the audio field, and they really like to invent/recycle jargon.
