How to disconnect 12v battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tredstone, Oct 5, 2009.
  1. tredstone
    tredstone New Member
    116
    Queens, NY
    I tried to do a search but couldn't find a good how-to thread. Does anyone know the proper way to disconnect the 12V battery? I'd rather not wing it and get electrocuted. :eek:
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The 12 vdc battery is a bit of a PITA to get to, but I have found it helpful to disconnect the actual ground wire bolt first. IN this photo
    the terminal nearest the camera is the positive, the one further away with the little white rubber band is the ground.
  3. ceric
    ceric New Member
    1,114
    Fremont, CA
    12V will not electrocute human (higher resistance - small current flow thru human body).
    Anything below 40V is pretty safe as far as human is involved.
    That said, disconnect the (-) terminal, not the (+).
  4. richard schumacher
    7,666
    1,047
    United States
    What they said, but: why do you want to disconnect it?
    Sorry, I don't know where there are clear online instructions for accessing the battery.
  5. tredstone
    116
    Queens, NY
    Richard - I'm finishing reupholstering the seats in my car with leather, and I'll need to disconnect the battery because of the front seat airbags.
    Thanks for the info guys! :)
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    There are important warnings and safeguards in the shop manual regarding the SRS. Make sure to follow them for your safety
