Mpg from 47 to 40
Discussion in 'Gen 2 Prius Fuel Economy' started by briand, Oct 12, 2009.
  1. briand
    briand Junior Member
    Charlotte, nc
    This past weekend we took a trip from Charlotte to Atlanta. My Prius is a 2004 with 108,000 miles on it. I normally get 47 mpg but on this trip I averaged 39-40 mpg. Since its fall and the A/C is running I should have got slightly better than average mpg. My tires or tire psi haven't changed.
    What could cause this drop in average?
    I have looked through the schedule maintenance book and there is no major service until 150,000 mi which is spark plugs and coolant. So what gives?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I remember the spark plugs and coolant are actually at 110-120k miles. Have you changed the engine air filter at 90k?
  3. briand
    Charlotte, nc
    Yes, I changed it at the last oil change.
  4. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Maybe your state has switched over to Ethanol gasoline which contain 10% ethanol. This will decrease your MPG up to 10%.
    alfon
  5. txtabby
    txtabby 2011 Prius 4
    139
    Austin, TX
    AGH! That's my problem. I can barely get it up to 47, and still trying for 48 on this tank. I'll start using 'better' gas (Exxon, Shell, Chevron, ect.) and see what happens. I talked to a mechanic at the dealership and he told me about the ethanol. Is there anything that can make the mileage get back up to 48-50+?? Going to make sure the air filter is always clean too.
