Why not Energy Star rating for dryers?
Discussion in 'Environmental Discussion' started by Celtic Blue, Oct 13, 2009.
  1. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Okay, this seems like an absurd hole in the Energy Star ratings and Energy Guides to me. Why don't we have Energy Star ratings for dryers? There is clearly an advantage for moisture sensors vs. time dry for example, but that just scratches the surface.
    There appears to be a tremendous amount of room for improving U.S. dryer performance. Europe has condensing tumble dryers for example. I would like to hear more about those, in particular whether they are manually drained or if it is a seal overflow drain. My father-in-law described the one he was using as manually drained. The second concern for me is whether or not the cross exchanger system requires annual or other moderate frequency cleaning by the homeowner.
    And yes, line drying is nice where allowed and when/where possible. However, it hasn't worked decently for about 6 months of the year in the last two local climates I've been in. Those with dry desert, mountain, or high plains climates wouldn't have this problem.
  2. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
  3. Celtic Blue
    2,224
    139
    Midwest
    Wanna bet?! What you really need to do is have standardized measuring and reporting of actual energy use so that consumers can decide if a feature makes a difference. If you have no standardized test and reporting then how is the consumer going to know?
    Reread my original post rather than parroting what they've said. That may be the claim, but it is bogus from what I can tell. There are already designs in other countries that apparently do better, and moisture sensors in the U.S. certainly make a substantial difference already. So why not do what the agency is supposed to do, encourage best practices rather than an inefficient status quo?
    The govt. claim is just lame. If any heat recovery is done there will be a difference in performance. Plus there are other tangential aspects such as air infiltration into the home. I'm not sure what the performance is of the condensing systems, but it isn't hard to see that not having to fully heat an extra 5-10,000 cu.ft. of air in the dryer, then dumping it for every load will make a difference.
    Besides, even if they were all identical they should still have Energy Guides. People should be informed about what energy the appliance will use. This is especially true for folks comparing gas and electric options.
    By the way, the same applies to ovens and ranges. Consumers need measures of the operational cost of each appliance.
  4. mikepaul
    1,763
    Columbia, SC
    Parroting? I thought I was answering your question of "Why don't we have Energy Star ratings for dryers?".
    You apparently think moisture sensors work forever. The ones in my Duet dryer haven't worked right in quite a while, so I just use the timer now which might not be Energy Efficient but the clothes aren't wet when it stops. And I'm not spending money on repairs when I have a viable workaround.
    Hopefully I haven't upset your soapbox...
  5. Politburo
    Politburo Active Member
    971
    208
    I didn't read through all the details, but what I got from this link is that condensing dryers aren't that great. In fact their conclusion is that they use more energy.
    Condensing (Ventless) Clothes Dryers
  6. fuzzy1
    10,446
    Thanks for this link. For those of us unfamiliar with condensing driers, this helps.
    It appears that most of these units use cold tap water for condensing. There is no heat recovery. And in much of the U.S., that trades one scarce resource for another, so any tradeoff benefit is very unclear.
    The air cooled units do have heat recovery, but that would be inappropriate in cooling-dominated climates. I think that more of the U.S. population is now in cooling-dominated, rather than heat-dominated, zones.
    We need more information about what condensing driers on the market before passing real judgement. With tradional diers, performance is driven mostly by how well the washer wrings out water in the spin cycle.
  7. a_gray_prius
    2,927
    783
    IL
    I would argue that the lack of dryer ratings makes sense if you think about the concept of efficiency as "how much input energy is being used to do what I want"? For example, an incandescent bulb in a cold room (that has to be heated) is 100% efficient because it provides the desired heat and light. I will make the assumption that it takes a rougly equal amount of energy for the motor to spin the tub across models. After that, the only energy consumed is heating the air, which goes directly into the tub. This is a process that is not really subject to much difference in terms of efficiency because you simply need a certain amount of energy (in Joules) to heat a certain volume of air by a certain amount.
  8. Celtic Blue
    2,224
    139
    Midwest
    Yes, parroting. When you repeat something back verbatim without even thinking about it or considering what was originally posted it is simply "parroting." Did you really think I hadn't read that exact same nonsense?
    That's really intelligent: waste money on extra electricity when you might repair it. I never said anything worked forever.
    But let's say as a result of the failed sensor you over dry by 20% on average (say 10 minutes on what should be a 40 minute dry.) It's not just a waste of energy, but hard on the clothing. My old dryer had no moisture sensor, and that was one of the reasons to replace it.
    Furthermore, what is the most efficient way to dry? Warm and slow (high volume), hot and fast (lower volume of air)? I'm not sure but this does not appear to be a "one size fits all" answer with respect to energy consumption. If you have to heat an extra 5,000 cubic feet of air that you then expel outdoors, there is a cost to doing that. How efficient is any given dryer at actually contacting a load with the airstream and making use of the driving potential of the heated air?
    No, you've fired me up instead. I've had some pretty good projects arise out of frustration with bewildering complacency or lack of intellectual curiosity of my coworkers. Low expectations produce poor results. Some people like being treated like 'shrooms, I'm not one of them.
  9. Celtic Blue
    2,224
    139
    Midwest
    This I agree with. The Canadian report is full of self-contradiction. If any climate would benefit from the safe heat recovery indoors, it is our northern neighbors. Furthermore, the report leaves me wondering if an engineer even was involved in writing it...or if they were, did they skip the heat & material balances course in their freshman year?
    Even in the U.S. in a cooling dominated climate, air cooling could still fare better than simple resistance heating. In the humid South one is sucking in air that must be both cooled and dehumidified, then is rehumidified in the dryer (via resistance heating) and expelled. So how would instead removing the heat in a COP 2+ refrigeration cycle (AC or heat pump) be less efficient?
    The one my father-in-law described using in Europe was air-cooled. With efficient heat recovery, the primary heat that would be rejected in the form of condensing water. But remember that that condensed water was originally...liquid water...not steam. Now if the Canadian authors can explain how this would be inefficient, I would like to see their thermodynamic basis.
    I would really like to hear some reports of folks who had compared these kind of units side-by-side. Combination units with cooling water don't interest me in the least, but any stand alone unit designed with air cooling and heat recovery in mind should spank the single pass, zero recovery units we use in the U.S.
    Expelling hot, humid air without heat recovery is wasteful. I've been through this sort of battle in commercial interchanger/preheater design. (Take a look at the core exchanger in a cracking plant, if you want to see the ultimate in this sort of thing--damn those are cool to work with.)
    The telling line is, "There is no test standard to measure the efficiency of condensing dryers." Exactly, that is the problem...that and the fact that noboby is even measuring the efficiency of them at all. Here it is, the single largest electric user outside fo the HVAC or electric water heating, and it is being completely ignored. One needs to define some standard laundry loads (top loader, front loader, etc.) and some climates to do a full box analysis. It won't be perfect, but holes in standardized tests can be accounted for later.
    And as I've pointed out before, the Energy Star/Energy Guide ratings for washers don't account for how well washers remove water before drying. The Energy Guide info for washers is only capturing a small fraction of the real value of a front loader.
  10. Celtic Blue
    2,224
    139
    Midwest
    Partially correct as best I can tell:
    1. Incandescents put much of that heat in places that don't need it so the efficiency is nowhere near 100%. Typically that input is high and in more frequently used rooms. Where it is most needed is low and in less used rooms. We tend to set thermostats to keep the less occupied (but still used) and lower level rooms warm enough. Pick an appropriate fraction out of the air to determine what percent of the heating input is useful during the heating season.
    2. The heat from incandescents is useful to me about 4-6 months of the year. In the other periods I'm trying to get rid of that same heat...and for about 4 months use AC to do it. In some southern climates the net of the two cases will be a wash...but the wasted electricity is still wasted.
    3. The "certain volume of air" is by no means fixed. Efficiency of the air mixing in the drum is important as well. Ideally air leaving the drum would be 100% saturated (in a zero heat recovery case)...but that is highly unlikely. If I lived in an arid climate I might want the dryer to draw arid outside air...and might only need "fluff air" or the lowest heat setting to dry.
    4. The quantity of heat required to dry is not fixed. It can vary greatly depending on how much is recovered--very little in current U.S. systems. At present much of the heat added is expelled outdoors. I can actually see the impact on nearby vegetation which shows faint evidence of warmer/higher humidity conditions...this is apparent in spring and fall. Conditioned air (from heating or cooling) is consumed in the process and must be regenerated.
    5. The amount of water left in my typical load is less than 5 lbs (yes, I actually measured several loads to establish that.) The latent heat of vaporization of water is roughly 1,000 btu/lb, so the duty to expell the water as vapor would be 5,000 btu/load if it simply boiled away, that's roughly 1.5 kwh. Actual drying in my current machine was measured at about 2.6 kwh/load.
  11. LeadingEdgeBoomer
    289
    29
    New Mexico
    Is this anywhere in the vicinity of being relevant to this forum?
  12. Celtic Blue
    2,224
    139
    Midwest
    You can't be serious! Are you telling me that energy conservation is not relevant to the "Environmental Discussion" forum?
    Please explain yourself.
  13. mikepaul
    1,763
    Columbia, SC
    Yes I thought you hadn't read it, but apparently self-righteous dimwits ask questions for which they don't need answers.
    Then when someone points out they are fools, they refuse to give up because God or some other diety has denied them that ability.
    Waiting for your next dose of idiocy about how you are right in all things...
  14. qbee42
    3,079
    Let me step in here for a moment and post something slightly off topic. Shawn and I have gone a lot of rounds punching and counter punching. We may have even resorted to name calling. There was a time that he was on my short list of "most despised PriusChatters". I generally remain civil in my postings, but Shawn tested my resolve.
    Oddly enough, though, with time I realized that Shawn and I generally agree on most topics. Often we were in violent agreement, beating each other over the head while making the same point. Fortunately we now seem to get along fairly well.
    I believe what causes these threads to derail is that Shawn is a tad bit aggressive in expressing his views. Shawn, I know it's hard to do, but if you could dial back the confrontational tenor of your posts just a bit your points would come across more clearly. As it is, people tend to feel threatened by them and then the thread devolves into a fight instead of a discussion. I understand this because I have the same tendency, but I work very hard to keep it under control.
    By the way, Shawn, I do appreciate our improved relationship, and I value and respect your opinions.
    Back to the fight, er, discussion.
  15. Celtic Blue
    2,224
    139
    Midwest
    So you admit you started off with a faulty assumption and continued to make more. And you can't be bothered to fix an appliance or even notice that the Energy Star statement about dryers fails the simplest logic test...as I pointed out about moisture sensors in my original and subsequent posts. No, instead you parroted the easily disproven. Maybe you should have nominated yourself as "self-righteous dimwit?"
    As for me, I'm still wondering about actual measured performance of condensing dryers, heat recovery systems for dryers, etc. I'm also wondering why Energy Star hasn't reconsidered at least requiring Energy Guides for the appliances and coming up with some standardized testing in case there really are differences in performance. If they don't have any sort of standardized testing and report results, then they really can't claim there is or is not any difference.
    Were you looking in the mirror when you wrote that? Seriously, that's some incredibly ironic stuff. :D
  16. qbee42
    3,079
    The broader question is why not Energy Star rate anything that uses power? If all devices of a certain type rate the same, it tells us something. If the ratings differ, that also tells us something. The information is useful either way. More information makes for better decisions. Better decisions pressure vendors to make better products.
  17. Celtic Blue
    2,224
    139
    Midwest
    Precisely. Adding to that, once you have a published metric it becomes an incentive to finding ways to differentiate and improve...as in reducing power consumption. Would insulating the drum or cabinet of a dryer improve it's efficiency by a few percent? Condensing operation? Moisture sensors? Sealed designs drawing outdoor air? More complex controls?
    Ovens and ranges are an example of the need for a metric. Together they are the next largest user after the dryer, and just in front of the modern refrigerator if I'm not mistaken. I suspect (but lack data to prove) that a ceramic rangetop is more efficient than open elements. I've read that with ovens self-cleaning models are more efficient to operate because they require additional insulation.
  18. fuzzy1
    10,446
    I very strongly suspect that with the other appliance standards, independent knowledge of substantial differences preceded the creation of any standardized tests. Creating standardized test in case there are differences seems a bit more proactive than I would expect from this branch of government.
  19. rpatterman
    rpatterman Thinking Progressive
    756
    226
    Boulder, Colorado
    My guess is the appliance industry has blocked attempts to measure performance. The air cooled condensing (ventless) dryers seem to be a plus in heating season in that they release heat into the room without the moisture. Also since they do not exhaust 200cfm (10,000 cf/load)of house air that must be cooled, they might also not be so bad in cooling season. A very tight home will have aproblem with 10,000 cf of air exhaust in the winter when it is closed up.
    Could the heated air be exhausted into the house during the heating season and vented to the outside during the cooling season? Or could the heat be used as a preheat for the DHW? Moisture sensors seem like a no brainer over a timer. And a front loading washer will spin more water out than a top loader.
    Another great way to save on dryer use is to hang thinks like towels and jeans on a line in the laundry room for 24 hrs then toss in the dry to finish off. Works great if the washer spins enough water out so they are not dipping.
  20. burritos
    burritos Senior Member
    4,946
    253
    It is a curiosity why the industry hasn't created a more efficient dryer. This would be an optimal innovation to generate the "obsolescence" that we typically find in today's products.
