! & headlight level alert
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by neon8s, Jun 18, 2008.
  1. neon8s
    neon8s New Member
    Milwaukee, WI
    I have a 2005 prius, pkg #6 w/ nav system.
    The not to be ignored red ! came on with the nav
    system showing the headlight level alert.
    A dealer visit was not productive as they
    could only reset the alert. It happened again today.
    We revisit the dealer tomorrow. They say Toyota
    has no info about it. The car works fine.
    Nothing I can trace sets the alert off.
    I feel I am not alone with this
    problem. Any help would be appreciated.
    Thanks
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Hi neon8s, welcome to PriusChat! :welcome:
    Look at this PDF. Does this seem like your problem?
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Yup, Bill's nailed it. That sensor needs to be replaced...should be a warranty item for an '06.
  4. neon8s
    neon8s New Member
    Milwaukee, WI
  5. Bill Merchant
    4,096
    85
    I'm glad you got the problem fixed. It's amazing how we, focused on one car, can be so much more aware than some dealers with open access to all Toyota knowledge.
  6. darelldd
    6,059
    389
    Northern CA
    it isn't rocket science to make a weatherproof enclosure. Grr. I can't believe this is still happening on the '06's!
  7. landesjoe
    landesjoe Junior Member
    St. Louis, MO
    Do you know what the resistance reading on a working module should be?
  8. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    My impression is that six volts comes in on one side, an amount which is less than six volts comes out the other side without variation, and the signal coming out the center pin varies with the load in the back. I suspect that if the signal coming out the other side pin drops below a certain level the car assumes the sensor or a wire has failed in the open position, and if it goes up to a full six volts it assumes a short.
  9. ormero8945
    ormero8945 Junior Member
    Lancaster, pa
    Neon8s, did they warranty the sensor on your 2005, or did they charge you for it?
