tank filling drama
Discussion in 'Gen 2 Prius Main Forum' started by PA Prius, Oct 18, 2009.
  1. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    I filled our '04 this afternoon as we always do just after the last pip started blinking. 90% of the time we get 7.X gallons in, including the .2 gallons that we top off after the nozzle clicks off. With 380 miles on the tank and the MFD showing 53.3 mpg that should have been the case this time as well. I filled at our local no-ethanol station by credit card, and since it was Sunday the building was locked and no attendant on duty.
    The gas pump was pumping extremely slow, even when pulled to the fastest notch, about one gallon per minute. Since no one was on duty I sat in the car and watched the numbers slowly scroll by. I was surprised when it went past seven gallons then eight. I hit the power button twice to see if the tank was actually filling. All ten pips lit up. By this time it was up to nine gallons, so I got out and released the fill handle at 9.183 gallons. It had not shut off on its own. I then pulled out the nozzle and some gas shot out of the tank and more gurgled out.
    I am guessing this was due to the extremely slow fill, but I don't think it should have happened. I can't imagine the nozzle seals that tight when put in the tank that it would cause the bladder to deflate to the point of causing this pressure. Any thoughts?
    PA P
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Hopefully you didn't damage the vent system $$$.
  3. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    I don't know why it happens. My wife was filling the tank slowly yesterday and had the same thing happened. The gas nozzle didn't shut off but she figured the car had to be full. Upon withdrawing the nozzle, between a pint and a quart of gas gushed out. I was standing right there when it happened and I cleaned up the mess.
    On the other hand, the Prius has gone about 180 miles since then and the gas guage hasn't gone down one pip yet.
  4. richard schumacher
    7,664
    1,046
    United States
    Chronic topping-off may have damaged the tank vent flap. Bummer.
  5. PA Prius
    762
    251
    SE Pennsylvania
    What are the signs and/or implications of a damaged vent system?
    PA P
  6. DBaum
    DBaum Junior Member
    Pennsylvania
    2020 Prius
    L Eco
    Same thing has happened to my girl friend's 2009 at least 3 times so far. It doesn't shut off when filling and a bunch of gas comes out when you pull the nozzle out. She said she got almost 200 miles before the first bar on her gas gauge went off though...
  7. qbee42
    3,079
    This is a problem with the pump. The slow fill rate was a red flag.
  8. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    To answer the OP's question, yes, the seal between the nozzle and the tank is tight enough to do this. There have been several reports of this happening. It's just like when you stick a straw in a juice box, blow in it and then watch the juice shoot out.
  9. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    Perhaps this is due to the flexible bladder that is the fuel tank.
    I have not experienced this yet.
  10. PA Prius
    762
    251
    SE Pennsylvania
    If that is the case one would think there would be all kinds of blow-by or other abnormal behavior when filling at the normal rate.
    PA P
  11. qbee42
    3,079
    No, the tank is vented during refueling. However, the vent isn't capable of passing liquid gasoline when you overfill, hence the pressure build up and possible damage to the evaporative control system.
  12. DBaum
    DBaum Junior Member
    Pennsylvania
    2020 Prius
    L Eco
    The 2010's are know for this same problem, aren't they? The dealer says my preordered prius should be in by the end of this month. It would be nice to not run into the same problem.
  13. boppo
    boppo Active Member
    799
    139
    Owego, NY
    the 2010 does not have a bladder, just a tank like most other cars.
  14. lrchome
    lrchome New Member
    Port Richey, Florida
    I have had tthe gas nozzel fail to shut off several times over filling in my 2005 model, and have not noticed any problems or complications.
  15. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    First, it is normal for fuel to "shoot out" if the tank is overfilled. The nossle shutoff didn't work so the tank was overfilled.
    Second, you won't damage anything by overfilling the tank. You -can- cause damage if you then put the cap on and it's a warm day. The fuel in the tank will expand and force itself into the evap. system, possibly popping off a hose. This is between the bladder and the hard tank and cannot be repaired. New tank time ($400+).
    Third, the 2010 doesn't have this problem. It has a standard tank as stated above. You -can- overfill any tank, and I suppose you -could- overpressure any evap. system by putting the cap on when the tank was -completely- full (no air or vapour volume to take up the expansion). Fuel doesn't compress, air/vapour does, so if just fuel in there the pressure from expansion is huge.
    If this happens again, you can release the pressure in the tank before removing the nossle by pressing down on the filler nossle, creating a small gap in the top. This will -slowly- allow air/vapour out (there is some in there which is what is trying to force the fuel out). You may get a bit of fuel coming out as well, but at least with this method it doesn't shoot out, trying to soak you in fuel.
    The tank bladder is not a pressure balloon. It doesn't expand from pressure from the filler nossle (though I suppose it could). It expands from the weight of the fuel you pour into it. It also doesn't force fuel back out. It's the trapped air/vapour behind the fuel in the fill tube.
    This has happened with Pearl twice, and there was no damage (it's been over a year since the last time and no MILs have come up). You will know if you ever do damage the system. You will get a MIL (check engine light). The system senses the fuel between the bladder and the hard tank and puts up the light.
    If you do overfill the tank (you can see fuel in the fill pipe when you are done) just leave the cap on loose for a few miles. I've done this with Pearl, it didn't cause a light, it did let the fuel level drop and didn't allow expansion to over pressure the tank/system. Surprisingly I also didn't loose any fuel. Not sure why. Must be some hidden volume in there to take it up once you start moving.
    2 people like this.
  16. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yes it was probably a faulty pump and with the slow fill rate it didn't trigger the cut-off properly.
    BTW. One common cause for an unusually slow pump is a clogged filter. The pumps have filters and they're supposed to be replaced regularly, but sometimes they leave it too long and it can really slow the pump down.
  17. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Pump nozzle shutoff sensors depend on air pressure to trigger.
    If the fuel is flowing very slowly, not enough differential pressure
    will build up and the nozzle will have no idea. In most cars it's
    supposed to be the gas reaching the level of the fill nozzle that
    covers the little sensor hole in the side and triggers shutoff.
    In the Prius, there's a widget up near the level of the top of the
    filler pipe called the "fuel cutoff valve" that artifically creates
    the necessary pressure difference to kick the pump nozzle off. I'm
    not 100% sure how it works but it almost certainly depends on the
    pressure created by the incoming fuel to do its thing. If the fuel
    is coming in so slowly that air is leaking out elsewhere, like
    around the rubber filler-neck gasket and the canister and fresh-air
    valve, then the cutoff valve is never going to get the input it needs.
    http://www.autoshop101.com/forms/Hybrid13.pdf page 3-9
    _H*
  18. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    I've noticed recently that my fuel gauge gets down to one bar earlier than it should, usually at about 450 miles on the tank, when I'm averaging about 48-49mpg. I think at that point, the most fuel I've been able to put in was around 10 gallons, but not much more.
    At first blush, I would assume the OP found a bum pump. See what it does the next time you fill up.
  19. NC_Prius
    NC_Prius Member
    186
    I've had the opposite problem the past 2 fill-ups. I was down to 3 bars (well, I still am) and I couldn't even get 3 gallons of gas in the car. Try as I might, the pump would shut off right away after it hit about 2 1/2 gallons. I took out the nozzle, let it sit, tried pumping slowly, quickly -- whatever. There was no getting gas in that car this evening. And, since I couldn't get the requisite 5 gallons into the tank, the gas gauge didn't register that I have a little more fuel in the car. It's nice that the car uses such little gasoline, but it's not worth it if I can't even put the gas in that it needs. And it was 47 degrees out -- certain not so cold that the bladder should be affected that much. How did this bladder tank design continue through the entire 2G lifecycle?
  20. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Try another gas pump, it may have been faulty.
